Author Topic: NE Kit Headgasket fitment  (Read 1446 times)
Offline Moffman
  • 1979 Honda CB650
« on: April 18, 2015, 09:48:28 AM »
About to put the new head gasket on my '79 CB650. Top end kit provided two o-rings that are close but they seem to a little small for comfort. I know o-rings swell up but do these look the right size?
« Last Edit: April 18, 2015, 08:34:24 PM by Moffman »
Re: Cylinder block oil passage o-ring size?
« Reply #1 on: April 18, 2015, 10:16:04 AM »
Did you check the microfiche for what size is called for in that recess?
Offline Moffman
  • 1979 Honda CB650
« Reply #2 on: April 18, 2015, 11:15:17 AM »
Microfiche?
Offline Moffman
  • 1979 Honda CB650
« Reply #4 on: April 18, 2015, 11:39:17 AM »
Thanks I'll go measure it, the old ones are supple and not cracked so I'm considering reusing them but let me see first.
Edit: Measuring it again the new o ring appears to be OD 9mm/ID 5mm/ Thick 2 mm and the old one is OD 10mm/ ID 5mm/ thick 2.5mm.
« Last Edit: April 18, 2015, 01:05:12 PM by Moffman »
Offline Moffman
  • 1979 Honda CB650
« Reply #5 on: April 18, 2015, 12:46:37 PM »
O-ring on the left is the old one. I'm not sure I'm measuring these rights but here is a visual difference. Suggestions? I'd really like to get this back together for tonight.
Offline Moffman
  • 1979 Honda CB650
Re: Cylinder block oil passage o-ring size? / Edit: Headgasket fitment
« Reply #6 on: April 18, 2015, 01:45:09 PM »
I decided to use the old o-rings since the new ones weren't the right size but now I've ran into an issue with the head gasket, the bolt holes cut out don't seem to be spaced correctly as the gasket on the dowels is pushing my o-ring out of it's recess. I'm starting to doubt the quality of this top end kit. It's an NE kit from david silver spares. What a bummer, doesn't look like I'll be riding tonight. Anyone use this kit before?
Offline DaveBarbier
« Reply #7 on: April 18, 2015, 01:59:32 PM »
Can you flip the head gasket around? I think I see cutouts on the gasket that need to be on the other end. Where the cam chain guide goes.
Maybe I'm wrong though.
Also, maybe someone else can chime in about the orings. Id hate to have you rush to put this together only to have it leak. Better to play it same in my opinion.
1978 Honda CB550K
Offline Moffman
  • 1979 Honda CB650
« Reply #8 on: April 18, 2015, 02:20:11 PM »
I thought the same thing at first but realized something was wrong when the holes for the dowels were on the opposite side so I checked a picture of when I took off the head and I'm positive it goes this way, don't ask me why.
