Author Topic: no spark, cycle x power arc ignition  (Read 5352 times)
0 Members and 11 Guests are viewing this topic.
Offline 75 super sport
« on: May 08, 2015, 11:03:38 PM »
Finally got the bike wired back up and I have no spark. Seems everything is hooked up correctly. Static timing light is flashing and power to coils. Any ideas? Would greatly appreciate some help. Been building this bike for 3 years and I just want to hear it run for the first time. Please and thank you
"Smoke em if ya got em"
Offline FunJimmy
  • Who you calling
  • Vancouver
Re: no spark, cycle x power arc ignition
« Reply #1 on: May 09, 2015, 06:47:31 AM »
Have you checked with Power Arc?
« Reply #2 on: May 09, 2015, 06:49:25 AM »
Resting battery voltage is 12.65, and it is about the same at the coils. Am I supposed to pull my power lead from switched 12v, or constant 12v?
« Reply #3 on: May 09, 2015, 06:50:37 AM »
I'm not sure what you mean about checking with power arc?
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #4 on: May 09, 2015, 07:14:54 AM »
C5 Ignitions (PowerArc) has very specific installation and wiring instructions and precautions. You may want to pop over to their web site and download them. Follow the procedures and go.
« Reply #5 on: May 09, 2015, 07:56:25 AM »
K. I'll give it a shot. Any other tips would be greatly appreciated. Thank you
« Reply #6 on: May 09, 2015, 09:56:10 AM »
So just wire it to a kill switch then?
« Reply #7 on: May 09, 2015, 01:54:14 PM »
Anyone have suggestions? I'm at all loss, everything is worked correctly. It should be firing, but isn't.
Offline Bill/BentON Racing
    • BentON Racing
« Reply #8 on: May 09, 2015, 03:14:37 PM »
Want to  hear it quick? Throw in stock ignition or better a DynaS and 3 ohm green coils, it will run, Bill
BentON Racing Website
BentON Racing Facebook
Online scottly
« Reply #9 on: May 09, 2015, 06:30:28 PM »
The red wire from the Power Arc harness should be connected to the black/white wire from the kill switch, that used to connect to the stock coils.
Not that way I'd do it, as the KILL is also switched voltage and susceptible to fluctuation. Wire to solenoid stud or battery POS. (If voltage issues are your problem).
How do you turn the motor off with the ignition wired directly to the battery? ??? ??? ::)
Offline Medyo Bastos
  • Gusto mo titi ko?
    • project
« Reply #10 on: May 09, 2015, 08:32:31 PM »
contact gary at powerarc
Online scottly
« Reply #11 on: May 09, 2015, 08:44:19 PM »
The motor is turned off by the key or the kill switch as normal.
Not with the ignition wired straight to the battery!!?? Read the instructions, Cal. ;)
Online scottly
« Reply #12 on: May 09, 2015, 08:56:05 PM »
The Power arc coils are connected to the Power arc harness, with a loose red wire that connects to switched 12v+. There is no direct connection to battery +, at least in the instructions I have been looking at??
Online scottly
« Reply #13 on: May 09, 2015, 09:06:08 PM »
From PowerArc:
>> One thing I want to suggest (I don't have all the manuals updated) is we now recommend taking each of the coil power leads (red) and connecting them both to your main fuse or battery positive terminal. The starter solenoid power lead also works.
Please post a link. Thanks Cal.
Online scottly
« Reply #14 on: May 09, 2015, 09:20:00 PM »
NO, it is NOT all clear now! >:( According to the Power arc instructions, there is a common red wire that feeds both the coils and the module.
Online scottly
« Reply #15 on: May 09, 2015, 09:37:47 PM »
Are you kick-starting the bike or spinning the motor with the electric starter when checking for spark? The Power arc system requires the crankshaft to rotate a certain amount before a spark will be generated. If the static timing light lights up at TDC, and the motor is rotating over 360 degrees without making a spark, the unit is likely faulty.
« Reply #16 on: May 09, 2015, 10:21:21 PM »
I am spinning the motor with the electric start. We tested the coil, and it is sparking when grounding the signal wire. Just seems we are not getting signal from the module itself. Is there a way to test the module for signal?
Online scottly
« Reply #17 on: May 09, 2015, 10:28:53 PM »
No, not that I'm aware of. You are using the matching Power arc coils, correct?
« Reply #18 on: May 09, 2015, 10:40:46 PM »
Yes, they came with the kit.
« Reply #19 on: May 10, 2015, 07:57:48 AM »
Ok I will give it a shot. But since the static timing light is flashing, shouldn't it be sending signal to the coil?
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #20 on: May 10, 2015, 10:12:41 AM »
The static TDC timing is picked up by a small slot closer to the centre of the disc.
The outer marks are used for coil control. You might want to try selecting an alternate advance curve too.
« Reply #21 on: May 10, 2015, 10:29:42 AM »
Will do. Thanks! What do you think the chances are that I have a bad module? Just curious if many people have had this same problem, and if it turned out to be the module. We have power to both the coil, and to the module. If we unhook the module from the coil, and supply power to the coil and ground a signal wire, the coil sparks. But as soon as we plug in the module to the coil and turn it over we have no spark. This was hooked up correctly from the beginning and there is absolutely no way that we fried the module, it would have had to come faulty and I don't see a very big chance of that happening?
« Reply #22 on: May 10, 2015, 10:41:25 AM »
Resistor caps and resistor type plugs. Everything is "by the book". I have studied the instructions carefully, numerous times
 Everything is as it should be, it should be firing but isn't.
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #23 on: May 10, 2015, 11:01:26 AM »
Sounds like the module is faulty.
Send it in for replacement but be very careful with the coils though.
They will heat up and burn out if powered to long.
  • Gusto mo titi ko?
    • project
« Reply #24 on: May 10, 2015, 03:44:56 PM »
maybe the timing slot is too thin.  i had to take an dental probe and scribe it out a bit.  gary sent me a new setup once this was figgered out. never had an issue one things were put in place.
