Author Topic: RE: Almost went down today hard!  (Read 6576 times)
Offline chewbacca5000
  • I polish covers!
« on: May 26, 2015, 02:49:24 PM »
I was so excited when got my K1, aka Pop-A-Wheelie on the road with a nice red inspection sticker to match the ruby red paint.  So I decide to go for a short ride at a "responsible speed".  Man I love this stupid bike, it accelerates like you would not believe.
When cruising along I start to think my 14 mm wrech for tweaking my mirrors is gone and I decide to get off at the next exit.  Well as I am getting off the rear tire breaks loose completely and I almost went down hard in traffic.
I get to the gas station and my rear wheel is coated in oil all coming from the sprocket.
I checked all hoses and oil pan and all are dry.  No cracks in case.  Looks like the rubber stopper on my auto chain oilier took a dump shooting oil everywhere.
Offline Sdsbassist
  • Gus, Austin, MN.
Re: RE: Almost went down today hard!
« Reply #1 on: May 26, 2015, 02:56:26 PM »
Glad you are safe friend
Gus, Austin, MN.
Current Bike:  75 750F
Past bikes: 76 750K - "Iowa Blue",78 750K Craigslist find - "Black Beth;" 77 CB750K Basketcase, with a 75K engine; 1970 Cb750 K1, "Rosa Luxembourg"
74 cb750, 75 cb550, 77 kawa 650, 81 virago 750, 83 virago 920, 80 Honda Twinstar 200, 71 Honda CT70, 1971 Honda CB750 Rat Project "Black Dahlia Bitsa"
« Reply #2 on: May 26, 2015, 03:00:02 PM »
Nice save Chewy, get that oil off the tire ASAP. if left it can screw up a tire... ;)
« Reply #3 on: May 26, 2015, 03:01:11 PM »
Yikes -  rocky start on your new relationship. Look it over well, sounds like quite a bit of oil cut loose somewhere. Good job staying upright !!
Offline lucky
« Reply #4 on: May 26, 2015, 03:01:44 PM »
That oil on the rear wheel could have cost your your life!!
Now you are on life#2.
« Reply #5 on: May 26, 2015, 03:03:58 PM »
Glad you're ok Chewy.....
PM 754 for an oiler plug  ;)
Offline RevDoc
« Reply #6 on: May 26, 2015, 03:10:08 PM »
Wow! Glad you weren't in the middle of commutor traffic on 81 or Hiawatha Blvd, Chewie!  :o
Dana
'78 CB550K--Angie
'82 CB750 Custom--Eva
As soon as you straddle a bike expect every other driver on the road to suddenly start competeing for the title "Dumbestsonofa#$%*inallNorthAmerica!!"
  • I polish covers!
« Reply #7 on: May 26, 2015, 03:26:52 PM »
Thanks Guys!  Lucky is right on life #2 now.  Guess the big guy is looking out for me.  I will be sure to PM 754 and get this sucker plugged up for good.
No it was no on 81, but was getting off 81 at the brewerton exit.  Going down there would have been a good chance of getting hit.
Wiped the excess off immediately, but will hit it again with decreaser.
Offline oldhatt45
  • The person called in at the last minute to share the blame is the...
  • Just an Old Guy that's gone to the Dogs
« Reply #8 on: May 26, 2015, 03:36:55 PM »
A Prayer of Thanks has been said in Your Honor Chewey.
Charlie
  • I polish covers!
« Reply #9 on: May 26, 2015, 03:41:14 PM »
Charlie
If Jesus were here today I beat he would ride a Honda.
« Reply #10 on: May 26, 2015, 06:20:20 PM »
I am very glad you did not go down. Ride safe!
« Reply #11 on: May 26, 2015, 06:50:43 PM »
+1. Maybe you should ship that bike to Texas if it has too much power for you?!
  • I polish covers!
« Reply #12 on: May 26, 2015, 07:04:01 PM »
No I don't think so.  Doesn't yours do 90 MPH once you get past 1/4 throttle? ;D
« Reply #13 on: May 26, 2015, 08:44:07 PM »
Yes, in 2nd gear!
  • I polish covers!
« Reply #14 on: May 26, 2015, 08:50:29 PM »
Yes, in 2nd gear!
Maybe over the winter I will send it off to one of the Honda masters to make it even faster!  Sure would be nice to know what it has for internals.  Right now having too much fun riding it.
I have not found the top end.  It just keep going faster.
« Reply #15 on: May 26, 2015, 10:40:10 PM »
Are you sure all that oil came from the front sprocket? Is the oilier screwed in tight? I had my K1 dump a bunch of oil in front of the rear tire when I first got it, but it was due to improperly connected oil tank lines. Also, if a bike has been sitting, and wet-sumps, it's common to fill the tank, and after running, the tank is over-filled when the scavenge pump forces the extra oil out of the sump, puking oil out of the tank vent.
« Reply #16 on: May 27, 2015, 03:36:23 AM »
  That's why  I also mentioned "to look it over well" as that sounds like quite a bit of oil. You sure do not want a repeat performance.  Is the chain oiler adjustment completely removed on the shaft and you popped a cork ?  There is some type of a cut up spark plug mod I think to plug the hole also I believe. An old Champion would work well maybe with its smaller bolt head.
« Last Edit: May 27, 2015, 03:46:01 AM by ekpent »
« Reply #17 on: May 27, 2015, 04:01:14 AM »
Very glad you stayed upright!
Offline Restoration Fan
  • My wife will never call me
« Reply #18 on: May 27, 2015, 04:39:23 AM »
Bikes are replaceable, you aren't.  Glad you're ok.
  • I polish covers!
« Reply #19 on: May 27, 2015, 05:17:18 AM »
Thanks guys I am glad I am ok too.  I looked at the tank and everyplace and all the oil was on the drive side.  The oil is coming from the chain oiler, but could be the counter shaft seal as well.  When it is parked I get the classic little puddle run down the kickstand.
I sliced a 3 mm o-ring and threaded it through the oilier hole and cut the excess then reinstalled the sprocket, retainer, and chain oilier.  Plan is to go for a couple miles pull over and check for oil, and repeat until I am satisfied.
It appears as though the little rubber stopper on the end is wore out.  The left side of the rear tire was and wheel well was completely coated with oil.  What a mess.
I'm going to test out the fix and will let you guys know how it goes.
Offline qside
« Reply #20 on: May 27, 2015, 05:20:56 AM »
Wow, like I just saw you 5 minutes before that!
Glad your ok.
Just after I left you I had to help a guy pull his Harley out of a ditch on 481.
I guess the Bike gods were angry yesterday
  • I polish covers!
« Reply #21 on: May 27, 2015, 07:51:45 AM »
Last night I threaded a 3mm o-ring in the oilier hole trimmed the excess off and reassembled.  It seems to have worked as there was no oil on the tire or rim and this is after 10 to 15 miles highway speeds.
Lubed up the chain and I should be good to go with no more oil slick worries.
It does have a bit of a head shake / hop at 40 to 50 MPH, but smooths out after that.  Not sure I want to do head bearings if it can be put off until later.
Offline RevDoc
« Reply #22 on: May 27, 2015, 07:59:38 AM »
Really? You just survived a potential life-ending hiccup due to maintenance/faulty parts and now you are rolling the dice again with a known issue? I have to question your logic and senses here, Chewy. Nobody wants to work on things, but to operate a motorcycle with known stability/safety issues is just plain foolhardy. Sorry if thats too blunt.
+1 on that! None of us wants to hear of you ending up "Road Pizza"!
Dana
'78 CB550K--Angie
  • I polish covers!
« Reply #23 on: May 27, 2015, 08:01:49 AM »
I hear ya Cal, maybe I should order up an all balls kit and be done with it.  Such a PITA taking the front end apart.  It only seems to do it at 40 to 50 MPH maybe it just the rim or tire out of true?
Offline RevDoc
« Reply #24 on: May 27, 2015, 08:07:00 AM »
Yeah, Kyle, I did see that occur with a bike that came in down here recently. Checked balance & true. Found someone had put almost 5 grams of wgt on that were totally unnecessary. Rebalanced & true was o.k. No hop after that. Hope that's what you find.
Edit: Just remembered another bike with slight hop. Problem was a bad wheel bearing. Hope you get lucky & it's something simple like that.
« Last Edit: May 27, 2015, 11:01:11 AM by RevDoc »
Dana
'78 CB550K--Angie
