Author Topic: 12 volt accessory power outlet?  (Read 3534 times)
Offline mcswny
« on: June 03, 2015, 06:45:10 PM »
Has anyone hooked up a 12 volt accessory power outlet to their CB750?
Wondering if it's an option for my stocker K2 (with a good charging system).
1972 CB750 K2
1997 XR600r (street legal)
1975 XL250
198 XR80
Re: 12 volt accessory power outlet?
« Reply #1 on: June 03, 2015, 06:52:01 PM »
Yes......
Offline mcswny
« Reply #2 on: June 03, 2015, 07:09:55 PM »
Yes......
Any advice?
1972 CB750 K2
1975 XL250
198 XR80
« Reply #3 on: June 03, 2015, 07:15:36 PM »
Yes......
Any advice?
Due to the low amp capacity of the elec system, dont do it unless you really feel the need to.  I didnt.
Offline mcswny
« Reply #4 on: June 03, 2015, 07:23:08 PM »
Yes......
Any advice?
Thanks Steve-o. More of the answer I was expecting, but not hoping for. Doing a 2k trip in July up into New Brunswick and Nova Scotia and was hoping to be able to keep my phone charged.
1972 CB750 K2
1975 XL250
198 XR80
« Reply #5 on: June 03, 2015, 07:37:59 PM »
Here's Anders thread on the 32 amp upgrade that Cal mentioned...
http://forums.sohc4.net/index.php/topic,117735.0/topicseen.html
Offline mcswny
« Reply #6 on: June 03, 2015, 08:22:12 PM »
Thanks again guys, I'll
Look into anders thread
1972 CB750 K2
1975 XL250
198 XR80
« Reply #7 on: June 03, 2015, 08:49:47 PM »
If you don't have a battery maintainer type charger like the Battery Tender you should get one. The charging pigtail that you attach would work as a nice power outlet. You'd just need to get an adapter to plug into it. Small things like what you want to use shouldn't have an effect on the system. Larger loads can compromise a weak charging system.
Offline flatlander
« Reply #8 on: June 03, 2015, 11:10:13 PM »
i haven't done this but it's one of the things i'm thinking about. occasionally charging smaller things like phones, should be no problem. especially when you ride longer distances where the battery is actually charging. i'll try to see if i can also charge camera batteries this way and leave enough in the bike battery to run the bike the next morning. with a charged phone and camera i'd be all set on longer trips. but this will be a winter project...
if you need more, especially things that you want to keep powered during riding like heated gloves or similar, the charging system would need upgrading.
definitely put in a disconnect switch like cal says.
« Reply #9 on: June 03, 2015, 11:40:24 PM »
Ofcourse you can do this. No problem. Believe me, this 'discharge thing' is only a topic in this forum and everybody happily repeats everybody.
Although the output is certainly not overwhelming there's plenty juice for normal riding and some extra's.
Since decades the little PA slideswitch (to give lightsignals) on mine is lame. I always ride with headlight low beam on. The number of times that I discovered (for example when entering a tunnel and seeing the blue high beam idiot light on) that the slide switch must have accidentily slided in the on position causing both the low and high filament in the H4 to be on... Yet I never had a depleted battery.
Use the bike for what it was intended and choose a moped or pedal bike for in the city. You'll have no problem.
« Last Edit: June 03, 2015, 11:44:23 PM by Deltarider »
Offline Bailgang
  • Scott
  • Indiana
« Reply #10 on: June 04, 2015, 01:25:57 AM »
The stock 750 charging system isn't stellar but it isn't that god awful bad either if it's in good shape. My 77 F2 has a boyer electronic ignition plus I wired up a 12 volt power outlet (cigarette lighter) under the seat to power my Garmin gps that I use on long trips and so far my F2's stock stator, regulator and rectifier haven't had any problem keeping it's plain old lead acid battery happy.
Scott
71 cb350 twin
77 cb750 F2
83 gl1100 Interstate
« Reply #11 on: June 04, 2015, 04:08:39 AM »
I found an adapter from SAE to USB.   On the battery I have permanently mounted SAE pigtail for the battery tender.    Because of the SAE I did not want to use a car lighter outlet, the SAE is much better sealed and holds better.
Anywat the SAE - USB plugs in the pigtal and leads to the tank bag where I charge my phone or whatever needs it.
Edit:  exactly what Wilbur said  ;D
« Last Edit: June 04, 2015, 04:11:12 AM by 70CB750 »
Offline Grinnin
« Reply #12 on: June 04, 2015, 05:05:29 AM »
My K5 runs a GPS plus a 70W jacket just fine.
This pic shows 2 black boxes on the handlebars.  Behind the brake reservoir is a voltage display that also includes a 5mm coaxial outlet for my Aerostich heated jacket.  Between the speedometer and clutch handle is the GPS under the sun shade.
For these devices I use a single fused 10awg circuit.   Smaller wire would work fine but with a 6 amp load the voltage drop would increase and the volt display would be inaccurate.  I also want the highest voltage for my jacket so riding on cold Maine mornings is comfortable.
For each bike I make up a pair of wires with ring terminals and a blade fuse holder near the battery and an SAE connector at the steering head.  Preparing a bike for a tour means connecting whatever I need to that SAE connector
The SOHC 750 charging system is big enough and very durable.  I do, however, recommend a voltage display if you have larger devices like heated gear.  Also a good idea if you make many short rides and use electric start.
« Last Edit: June 04, 2015, 05:17:54 AM by Grinnin »
Offline Proto
  • 1976 CB750F
« Reply #13 on: June 04, 2015, 05:07:17 AM »
Been running an accessory plug on my 1976 750F for about 20,000 miles now, using it mostly for charging my phone.  No problems.
1976 Honda CB-750F1
2013 Harley Davidson Ultra Classic
Offline mcswny
« Reply #14 on: June 04, 2015, 05:36:39 AM »
All good info, thanks guys!! Maybe I'll run a test before my bigger trip.
1972 CB750 K2
1975 XL250
198 XR80
« Reply #15 on: June 04, 2015, 05:49:00 AM »
Where are you headed?
Offline mcswny
« Reply #16 on: June 04, 2015, 05:55:51 AM »
We're starting in NYC, heading northing to the Green Mountains in Vermont, shooting over to the Whites in NH, riding through interior Maine up into New Brunswick, over to Halifax Nova Scotia, crossing Fundy on the ferry then back down to NYC and looking for any and all swimming holes along the way. I'll be the only CB on the trip (two KLR's and one triumph Scrambler) hopefully I don't slow them down too much!
1972 CB750 K2
1975 XL250
198 XR80
« Reply #17 on: June 04, 2015, 05:58:44 AM »
Looks like fun  ;D
Have a safe trip.
Offline mcswny
« Reply #18 on: June 04, 2015, 06:50:40 AM »
Looks like fun  ;D
Have a safe trip.
Will do!
1972 CB750 K2
1975 XL250
198 XR80
Online Don R
« Reply #19 on: June 04, 2015, 07:08:23 AM »
I did what Jerry said, I used the plug harness in for the battery maintainer (already fused) and made up a power outlet cable, it went into my tank bag and I could keep the phone and charger under the clear cover to keep it charged and where I could see it if I needed to pull over and check the GPS or whatever.
« Reply #20 on: June 04, 2015, 07:21:35 AM »
if you dont have a charger/maintainer harness to connect to, get one of these little numbers off ebay.
long lead.  runs right off your batt.
http://www.ebay.com/itm/251563567606
Offline mcswny
« Reply #21 on: June 04, 2015, 08:04:17 AM »
Thanks flybox. I always have my tenders quick connect pigtail under my seat, just I can just plug and play with one of the many ones on eBay.
Definitely going to do a test weekend with it before the big trip to make sure everything is kosher.
1972 CB750 K2
1975 XL250
198 XR80
Offline flatlander
« Reply #22 on: June 05, 2015, 01:05:12 AM »
keep in mind that there are 1 and 2A USB ports. some devices need 2A but those that charge on 1, also do it on 2.
Offline mcswny
« Reply #23 on: June 05, 2015, 06:55:17 AM »
thanks for this, had no clue.
1972 CB750 K2
1975 XL250
198 XR80
