Author Topic: My newest edition. 850 Norton  (Read 11267 times)
Offline rtbmrgl
  • Got Points! Roseville, Ca
« on: July 14, 2015, 04:50:40 PM »
Look whats in my garage now.
thanks, Mark
Roseville, Ca
Got Points!
1973 CB500 back yard find 1243 orig mi,  http://forums.sohc4.net/index.php?topic=124285.0
1976 CB750 Restoring,        http://forums.sohc4.net/index.php?topic=132997
Re: My newest edition. 850 Norton
« Reply #1 on: July 14, 2015, 04:53:05 PM »
Very nice, at least you should be able to do some miles on that one, it looks like the interstate model with the big tank.... ;)
Offline rtbmrgl
« Reply #2 on: July 14, 2015, 05:50:35 PM »
thanks, yeah the big tank is nice, I had a 750 commando back in the day and 100 miles on a tank was it.
Its a nice runner, needs TLC, no oil leaks or electrical problems................yet.
It came with lots of extra seals, gaskets and parts. Almost all stock, except Boyer ign, single carb.
I also have all of the repair paper work since bike was new.
The only bad thing is I had to give up one of my bikes ('76 CB750), financial and room.
thanks, Mark
Roseville, Ca
Got Points!
« Reply #3 on: July 14, 2015, 06:16:27 PM »
Congrats!  Looks super clean.  How 'bout a ride report, how does it compare to your soon to be forgotten K6?!
Offline BPellerine
« Reply #4 on: July 14, 2015, 06:32:08 PM »
that is a nice bike,the 74 850 was the best,yours is a 75 e start ,but I kind of liked the 750s.the single carb mikuni is one of the best mods for a driver,as is the boyer,the response is much better,you can also add an extra plain plate in the clutch which will give a nice light pull,steel tank?bill
« Last Edit: July 14, 2015, 06:35:26 PM by BPellerine »
1978 CB 750K ard and webers
another anfob
Offline rtbmrgl
« Reply #5 on: July 14, 2015, 08:50:43 PM »
I just drove to the bike home, a short distance. I'm going to take it down a frame down and repaint (not tank) and replace a few things. There are some issues, loose bolts here and there leaking forks, cracked tires are 15yrs old (date 0200). An old bike I really don't fell comfortable riding until I know what I got.
The guy I bought from didn't do any maintenance for the ten years he owned it,  he hardly rode it. When i say no maintenance I mean no maintenance, never changed the oil or battery, or anything else.
So you ask what did the oil look like, well surprisingly good and and primary case oil was fine also. The orignal owner had a maintenance record.
Ill give a full report when completed.
thanks, Mark
Roseville, Ca
Got Points!
Offline rtbmrgl
« Reply #6 on: July 14, 2015, 08:56:49 PM »
Yeah the single  carb  they say is a nice setup. I wish it was a Mikuni but it has a square Ama,l like the one I had on my '76 Bultaco. Yes steel tank. 34mm new Mikuni can had for about $80, might go that route.
thanks, Mark
Roseville, Ca
Got Points!
Online scottly
« Reply #7 on: July 14, 2015, 10:19:42 PM »
VERY NICE!!!  :) :)
Offline Desert-SOHC
  • It's old
« Reply #8 on: July 14, 2015, 11:42:09 PM »
Nice...............I had a 750 Commando with the interstate tank. Shook like hell, but was nice at highway speeds
90 F350 Lariat CS S/C Dually
90 S&S 11SC Cabover Camper
97 FLHTP (under construction)
11 Ranger S/C 2wd
Offline rtbmrgl
« Reply #9 on: July 15, 2015, 09:04:43 AM »
Yes they do shake until about 2K rpm.
My Norton buddy says the 750's were quicker handling than the 850, due to fork geometry. i haven't looked into it but I believe the fork angle was increased.
thanks, Mark
Roseville, Ca
Got Points!
Offline faux fiddy
  • bike in a box
« Reply #10 on: July 15, 2015, 02:14:53 PM »
My friend is working on getting one back on the road tight now. I would recommend going through the transmission because they are notoriously designed and manufactured with a bunch of slop which causes failures- broken teeth  and bent shafts. You can bend the shafts back a bit and there is a bushing kit available to tighten up the gearbox, which is highly recommended if you plan on putting any significant miles on the bike.
^^^^^^^/l^^^^^^^^^^^^^^/l^^^
Offline rtbmrgl
« Reply #11 on: July 15, 2015, 03:33:26 PM »
Thats true, my 70 commando had trans problems, I plan on looking at it. I believe the 850 had less problems, up-dates.
thanks, Mark
Roseville, Ca
Got Points!
Offline BPellerine
« Reply #12 on: July 15, 2015, 05:09:51 PM »
yes the 850s had a lot of upgrades,better swingarm,the 75 had adjustable isolastics,no shimming,the gearbox has some thicker gears too.80mph was criuzing speed on the highway on my 750 with 21 tooth front sprocket.only thing I did not like about 75 is all the extra gear for the electric assist as they were called,they also have a better head steady.steel tank is a good thing!bill
another anfob
Offline rtbmrgl
« Reply #13 on: July 16, 2015, 09:20:09 PM »
Your right Bill about all you mentioned, Im in a learning curve on the bike and I like it. Last eight years Ive been fixing up or restoring mostly Hondas, Its a nice change.
 Ill tell you one thing Its easy to see why these Neanderthals didn't make it in the age of the evolving Japanese bikes.
thanks, Mark
Roseville, Ca
Got Points!
Offline Greggo
  • Somebody's
  • Helmets Save Lives. Period.
« Reply #14 on: July 16, 2015, 09:47:38 PM »
Nice bike!  Nice garage too!!
« Reply #15 on: July 17, 2015, 03:56:07 AM »
Following.
Sooooo, are you gonna cafe it?  ;D ;D
Offline BPellerine
« Reply #16 on: July 17, 2015, 01:57:03 PM »
if I can be of any help give me a scream,I built a few of these and loved them.bill
another anfob
Offline rtbmrgl
« Reply #17 on: July 17, 2015, 05:32:25 PM »
Great, Ill use all the help I can get.  8)
thanks, Mark
Roseville, Ca
Got Points!
Offline rtbmrgl
« Reply #18 on: July 17, 2015, 05:36:22 PM »
Following.
Im a stock bike guy, I love the orignal beauty.
Check out jaguar thread he just started. Hes got a 750 Commando, I believe its headed for the Cafe,
DO THE TON
thanks, Mark
Roseville, Ca
Got Points!
« Reply #19 on: July 17, 2015, 05:39:37 PM »
it was a joke :)
Offline rtbmrgl
« Reply #20 on: July 17, 2015, 10:31:20 PM »
thanks, Mark
Roseville, Ca
Got Points!
Offline BPellerine
« Reply #21 on: July 18, 2015, 04:26:14 PM »
well it looks like you have the clutch tool!wireing looks patched in to the boyer?bill
another anfob
Offline Killer Canary
  • Typical Bran Muffin
« Reply #22 on: July 18, 2015, 04:46:41 PM »
A friend told me a few years ago that there's kit available to convert the shifter seal from an o ring to a lip seal. Might be worth it if that's a problem area.
Kawi GPz900, H1
Offline Rocky2010
  • Live in Strayla
« Reply #23 on: July 19, 2015, 08:16:26 PM »
Nice bike always like the Norton Commando  :)
2010 Harley Fatboy Lo
1972 Honda CB750/4 Under Restoration
1971 Honda CB500/4 Original Condition
1972 Honda CB350/4 Original Condition
1972 Honda XL250 Motorsport Under Restoration
1967 Honda C90 Original Condition
1968 Honda S90
1962 Triumph Speed Twin
1952 Triumph Speed Twin
1970 Bultaco Sherpa T
1971 Bultaco Alpina
1958 Moto Guzzi Zigolo
1970 Moto Guzzi Ambassador Original Cond
1973 Yamaha RD250
1948 Velocette x 2
1942 WLA Harley Davidson
2006 Kawasaki ZX12R (Sold)
1980 Corvette
Offline rtbmrgl
« Reply #24 on: July 24, 2015, 07:37:53 AM »
Thanks for all input and info, Ive been out of town and all I can do is look my pics of the bike  >:(.
thanks, Mark
Roseville, Ca
Got Points!
