Author Topic: Racer head count for Valdosta.Man Cup  (Read 13722 times)
Re: Racer head count for Valdosta.Man Cup
« Reply #75 on: November 02, 2015, 06:39:25 PM »
Welp, one truck in the shop getting a range sensor replaced, the other decided to puke all its coolant from somewhere behind the motor.. if neither is ready in time I might not have a ride  :-\
Now im nervous
What is a "range sensor"? I've heard of oxygen sensors, MAP sensors, throttle position sensors, etc.
What truck is puking coolant? I had a Ford with a leaky freeze plug in the back of the head, and rather than pull the head, I cut a hole through the firewall and replaced the plug from inside the passenger compartment.
Offline dragracer
  • CB750F Dragbike
« Reply #76 on: November 02, 2015, 11:02:33 PM »
Benton probably has 4 bikes down there about ready to race. Pick one, he won't mind!!! Lol
Offline NalleyRacing
  • 1972 Cb750K dragbike Instagram: Drag_racer736
« Reply #77 on: November 02, 2015, 11:30:24 PM »
Range sensor for my 2006 f150 fx4.. its part of the transmission and tells it what gear it should be in. Ive had it doing this for some time down. Can feel hard downshifts as im braking and sometimes goes between gears while on the highway trying to find the right one. Im worried the wiring harness to the transmission may be at fault as well..
The one leaking coolant is a 2002 f150 4.2l v6, 220k miles and hasent been on the road since 2011. Ive been trying to get it back to driveable the last few weeks. I noticed the coolant had been slowly lowering in the resivour so I knew there had to be a leak somewhere.
After taking the 06 back to the transmission shop I came home and gave the other truck a once over before going to run errands and just happened to notice coolant pouring out from under the motor and onto the ground pretty rapidly.. I noticed a small puddle under the intake manifold but havent located the source of the leak. But the entire resivour was drained in about 2 minutes of idle run time.. not good  :-\
« Last Edit: November 02, 2015, 11:33:17 PM by TreyAllen »
Offline dusterdude
« Reply #78 on: November 03, 2015, 03:05:50 PM »
Trey,2 fords,both broke.dont ya think god is trying to tell you something?
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Offline Tintop
« Reply #79 on: November 03, 2015, 03:50:05 PM »
 ;D ;D ;D ;D ;D ;D ;D Fix Or Repair Daily
1980 CB750F (project)
77 CB550 Cafe build
550/750 Filter Thread
Sidecar Rebuild Thread
Offline POPS 911
« Reply #80 on: November 03, 2015, 04:51:11 PM »
TREY: Hang in there as that race is not the last one in your life = 25 years down the roads and tracks from Palmdale, California [ NOW CLOSE ] and Englishtown, NJ will be a ride down the road for a few seconds of getting that win ticket .......... Hold your head up and not down you got years, ask FRANK.
« Reply #81 on: November 03, 2015, 05:17:32 PM »
Meh, weve had both trucks since new. 180,000 miles on the 06. Its made 2 round trips to Georgia, round trip to Memphis, as well as another to Colorado all since last November. Truck has done some work..
And the other truck is another story.. sat up 4 years in harsh summers and cold winters, just need some tlc ;)
Vehicles are all the same, its how you treat them that mtters. Except Kia's... Fu€k Kia's..
 ;D
Dont count me out yet ;)
« Reply #82 on: November 03, 2015, 05:37:59 PM »
A friend had a Ford that would start up fine, but as soon as he shifted the trans into drive, the motor would die. Long story short, the trans got it's RPM signal from the ignition module, and that portion of the module had failed. Just something to keep in mind, if the new range sensor doesn't fix it..
Offline larry hayes
« Reply #83 on: November 08, 2015, 02:12:04 PM »
loaded and hope ready see everyone there!!!!!
Offline Bill/BentON Racing
    • BentON Racing
« Reply #84 on: November 08, 2015, 02:53:05 PM »
K, we are going to camp around the 1000-1200 ft mark, see you there! Bill
BentON Racing Website
BentON Racing Facebook
« Reply #85 on: November 08, 2015, 05:42:28 PM »
Packing tonight. My ride will be here at 5:30 am.
