Sadly those pictures have been lost
.   Things done to the bike.
Front to back:
Front disc brake caliper replaced (new pads seals ect) (Polished)
Rebuilt master Cylinder
Front fender replaced due to dents
Replaced Front and rear wheel bearings
Fork rebuilt and new seals (Polished)
Found replacement turn signals front and back as it had no turn signals orignaly
New flasher
Tank had some nasty funk in it.  Put a couple hundered BBs in the tank along with some degreasers and shook it all up the BBs scrubed the inside the tank pretty nicely.
New in tank fuel filter/strainer
The carbs were pulled striped all the way down and went into my ultrasonic cleaner. These carbs had some sort of blackish green stuff growing in them.  Very Nasty!  All new brass and rings and bench synced.  (BTW the carbs in the inside especialy carb 4 is prety badly scard from the gas eating the metal #3 also damaged but not as bad as 4, will want to repalce at some point let me know if you have one!)
Removed all side covers for polishing.
Polished covers(THIS TOOK FOREVER!)
adjusted tapets, points and cam chain
Removed drive chain it too went into the ultrasonic with degreaser
New battery
New air filter
New rubbers for side covers
New tires
replaced rear fender due to being twisted
All fresh fluids
And im sure there are some minor things along the way i replaced as well.  Main thing now is that she runs good and she is pretty to look at.
