Author Topic: cb550 top end, new threads for middle front bolt  (Read 1179 times)
Offline BigBird
  • learning and doing
« on: October 17, 2015, 01:32:23 PM »
I was torquing down my top end [first 10lb ft, then 15] the last bolt at the middle front overturned and the thread in the aluminium cylinder block was gone with bolt intact. I can't thread it without taking the cylinder block off again. I left the engine torqued 24hr ago, and now I realise i have to take it apart again. Is it necessarily bad for the bottom and head cylinder gasket? They were put in dry and clean.
Thanks in advance!
Offline CBGhia
Re: cb550 top end, new threads for middle front bolt
« Reply #1 on: October 17, 2015, 01:44:48 PM »
It won't hurt anything.  Take it apart and put a case saver insert or whatever.
Offline DaveBarbier
« Reply #2 on: October 18, 2015, 04:36:09 AM »
Isn't the recommend torque for those bolts 8 ft lbs? I just use a 1/4" ratchet and choke up on it then give it a firm twist. But again, as everyone knows I have baby hands.
Offline alacrity
  • Ride, Optimize, Repeat
« Reply #3 on: October 18, 2015, 08:09:57 AM »
It's possible you can get a bit extender to allow you to drill tap and then fit a helicoil (or similar) without pulling the head back off.   Try sliding the bit extender into place, then fitting the bit into it?
I recently restored and sold a 77 cb750f, and am nearly finished with a (former basket case) cb750k5.  This is a place to share, learn and enjoy.  I am grateful to and for 99+% of this site's membership.
Offline strynboen
« Reply #4 on: October 18, 2015, 09:45:26 AM »
can you not use a vaccumcleaner(støvsuger)..and drill and tap helicoils in the 4 holes..
i hate all this v-w.... vords
Offline MickB
« Reply #5 on: October 18, 2015, 10:06:08 PM »
Plug all the openings with rags, and tape over the bearing surfaces and use a helicoil and as you use the tap have a mate with a vacuum cleaner to suck up all the metal shards that come out of the tapped hole.
It works, I had the same problem with my head and didn't want to have to pull the cam out, I had rags blocking the bearings and other openings, used a hand held vac and no problems.
Offline BigBird
« Reply #6 on: October 19, 2015, 02:08:00 AM »
Thank you very much for response. I pulled the head off, tapped a size up and put in a steel thread that matches the old bolt. Head mounted and torqued for re-torque and startup in a few hours.
Will now be skimming through build threads to look for first startup tips
