Author Topic: Idle won't go below 1250RPM  (Read 3455 times)
Offline Johnny340
« on: November 05, 2015, 08:45:50 AM »
My idle won't go low enough on my '81 CB650.
I synced the carbs to the #2 carb (which is not adjustable) but the idle is too high even after backing out the adjuster to the point that it stops making contact.
Any ideas?
1975 CB750F0 Super Sport
1972 CB750K2
1981 CB650
1974 T-500
2003 GSXR750
2006 YZ250
Re: Idle won't go below 1250RPM
« Reply #1 on: November 05, 2015, 08:51:09 AM »
Verify your idle mixture is correct.
My 750 idles best at that rpm.
I don't see an issue with it.
Offline Johnny340
« Reply #2 on: November 05, 2015, 08:54:57 AM »
I'm trying to set the mixture screws as per the manual and it says to get it to 1050 RPM and adjust the screws to see 50RPM increase, etc.  It seems it idles higher the more I back out the adjusters (till they fall out)..
1972 CB750K2
1981 CB650
1974 T-500
2003 GSXR750
2006 YZ250
« Reply #3 on: November 05, 2015, 09:02:10 AM »
Set your mixture screws based on plug color (light tank insulator tip) not on how low you can get it to idle.
This was a new plug after a 5min idle 1200-1250.
Once mixture is correct, adjust your idle set screw to a comfortable idle AFTER the bike is fully warmed.  There will be no need to adjust it again.
On starts, use decreasing choke until the bike is up to op temps.
« Last Edit: November 05, 2015, 09:11:21 AM by flybox1 »
« Reply #4 on: November 05, 2015, 09:50:48 AM »
Throttle cable stuck?
« Reply #5 on: November 05, 2015, 09:54:41 AM »
Or the "A" cable may be too tight. It should be adjusted at the bellcrank so that there is about an 1/8 turn slack in the twist grip. Once you're sure of that, you can take a little of the slack out of the cable at the twist grip.
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #6 on: November 05, 2015, 01:34:53 PM »
All of my old Hondas have idled best at 1200+ RPMs. I don't think a couple of hundred RPMs is a big deal for an engine that can cruise at 9000+. If it were over 1500 idle speed then I'd probably look into it.
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
Offline Johnny340
« Reply #7 on: November 05, 2015, 06:49:12 PM »
The cable is not stuck nor too tight.  I'll do a plug check with new plugs because I do need to sort out the mixture screws.  It just doesn't have good acceleration right off the bottom or good response when blipping the throttle for a downshift..
1972 CB750K2
1981 CB650
1974 T-500
2003 GSXR750
2006 YZ250
« Reply #8 on: November 06, 2015, 06:52:56 AM »
Air/Fuel mixture issue.
Mixture should always be checked/adjusted from largest to smallest fuel contributor (main jet->needle clip pos->pilot jet->mixture screw)
If done in the reverse, the correction introduced can effect mixture/throttle response in the higher throttle positions.
Fine tuning (mixture screw) always comes last.
Online Deltarider
« Reply #9 on: November 06, 2015, 06:55:24 AM »
Do yo know how accurate your tachometer is?
Offline Johnny340
« Reply #10 on: November 06, 2015, 08:48:19 AM »
The tach I used is accurate to a a tenth of an RPM.  The engine runs perfect on the top end and middle but seems lean on the bottom.  The pilot jets are pressed in so I didn't change them.  Can anyone tell from the picture if the needle height is adjustable?  They're just visible in the bottom of the pic and I remember not seeing slots to change a clip position..
1972 CB750K2
1981 CB650
1974 T-500
2003 GSXR750
2006 YZ250
« Reply #11 on: November 06, 2015, 08:54:48 AM »
looks like you could shim those needles, if warranted.
Offline Johnny340
« Reply #12 on: November 06, 2015, 09:02:29 AM »
Does shimming seem warranted?  I know it overlaps the low RPM range but is there anything else I should consider first?
I cleaned the carbs with an ultrasonic cleaner because that was the only way a couple stubborn pilot circuits would clear.  Afterwards, I could spray carb cleaner through all passages.   The only mod is a 4 into 1 pipe.
Shouldn't the mixture screws be somewhere in the neighborhood of 2T out?
1972 CB750K2
1981 CB650
1974 T-500
2003 GSXR750
2006 YZ250
« Reply #13 on: November 06, 2015, 09:23:10 AM »
if you complete an accurate plug chop at 2/3 throttle position, and your plugs are near white, then yes, a shim is warranted.
The BOOK setting for your mixture screw is a baseline setting for a bike with a stock intake and exhaust.  Fine tuning is always suggested.
If your intake or exhaust is different, then mixture screws should be adjusted based on your PLUG COLOR after an idle chop.
Offline Johnny340
« Reply #14 on: November 06, 2015, 10:25:17 AM »
OK, I'll get new plugs and do that.  Thank you.
If I do need to richen up the needle after, I assume I would simply put a small washer over the needles before putting them in?
1972 CB750K2
1981 CB650
1974 T-500
2003 GSXR750
2006 YZ250
« Reply #15 on: November 06, 2015, 10:37:30 AM »
Correct.
IIRC they were M2.5 x 6mm (.5mm thick)
I can measure one after work.
« Last Edit: November 06, 2015, 10:41:55 AM by flybox1 »
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #16 on: November 06, 2015, 01:51:20 PM »
Do your CVs have the air cutoff valve? Those can cause trouble if not clean and the diaphram isn't in good shape. I have a CX500 with those simlar carbs and a total PITA to clean and rebuild compared to older type carbs. The press in pilot jets were not a good idea but they can be removed. My guess is the pilots need cleaning both for gas and air orifices. Also the passageways that feed the pilot jets should be cleaned too. The CX500FORUM.com has a lot of info on taking these carbs apart.
1974 CB360T
2015 BMW F700GS
  __o
_- \_<,
« Reply #17 on: November 06, 2015, 02:20:06 PM »
I know you're adjusting/fine tuning the carb. jetting but just wanted to ask if you're sure that you're mechanical ign. advance assm. is working well? and if you lightly lubed the moving parts & checked the 2) springs for proper tension before you set the timing w/ a stroboscopic timing light.
I think that needs to be done first before synching or fine tuning the jetting.
Offline Johnny340
« Reply #18 on: November 07, 2015, 08:39:17 AM »
These carbs do not have the air cut off valve but were a total PITA to clean anyway.  With non removable pilots and passages that bend 90° I could not use a wire or anything to ensure everything was clear.  The intake to the pilot jets (arrow in pic) are clear but passage seems to split into several smaller holes that enter the carb under where the star is in the pic.  I can spray carb cleaner through here but maybe it is still partially plugged up??
Thank you for the ignition suggestion because that makes sense too.  I'll check that before pulling these carbs...again.
BTW, has anyone simply put a 4 into 1 exhaust on a 650 and had to make the needles richer or needed any other of jetting changes?
1972 CB750K2
1981 CB650
1974 T-500
2003 GSXR750
2006 YZ250
« Reply #19 on: November 07, 2015, 03:35:55 PM »
only a few plug chops, or time on a (dyno) gas analyzer can tell you if jetting is necessary after an exhaust swap.
IMO, its usually under 1/4 throttle and over 2/3 throttle needing (slight) adjustment.
Offline harisuluv
« Reply #20 on: November 07, 2015, 04:31:51 PM »
What jumps out to me is a common mistake.  The carbs can all be synced to each other, however, they can be UNsynced with the idle adjust screw.  To be very clear, each carb can be synced perfectly to each other and still botched because they are not synced in relation to the idle adjust screw.
With the DOHC carbs, they are EXTREMELY sensitive.  They can be very tricky to bench sync well and often times need a vacuum sync.  Did you use the drill bit method?  On these I just sync based on light I can see from the other side (flashlight).  If you used a drill bit, you will run out of idle screw before you get them closed enough.  And almost always, you will at least need to loosen the screws to finely adjust the placement/seating of the flaps so that they can seal correctly for syncing.
You should be able to basically turn the idle down til it dies, if you can't do that, you might need to resync them.
Offline Johnny340
« Reply #21 on: November 07, 2015, 05:47:30 PM »
I vacuum synced the carbs at around 2000RPM and they were very sensitive but I eventually got them exact.  Are you saying that at a lower idle they could be out of sync?
1972 CB750K2
1981 CB650
1974 T-500
2003 GSXR750
2006 YZ250
Offline harisuluv
« Reply #22 on: November 07, 2015, 05:53:26 PM »
No.
Let's say you have all four exactly right.  Ok.  Got it.  Irrelevant.
The sync of all four has to be synced IN RELATION TO THE IDLE SCREW.  You do not have adjustment lower.
« Reply #23 on: November 07, 2015, 07:43:25 PM »
No.
ok,
Are you saying to Johnny340 that he needs to establish a type of 'base idle' w/ #2 carb. along w/ all the rest..,possibly a lower rpm to synch ?
