Author Topic: 2nd gear feels like it's not getting gas at high rpms  (Read 4970 times)
Offline bookah
« on: November 29, 2015, 11:00:57 PM »
Title. All other gears feel fine, when in 2nd and in the upper band the engine feels like it just isn't getting gas. Anyone know what this is all about?
1978 cb550
Re: 2nd gear feels like it's not getting gas at high rpms
« Reply #1 on: November 30, 2015, 04:23:00 AM »
Could it be the gear dogs?
« Reply #2 on: November 30, 2015, 07:06:34 AM »
positive it isn't a jetting issue?
« Reply #3 on: November 30, 2015, 07:08:49 AM »
 Just guessing but could the floats be set low and in second when it's pulling hard the fuel is running up the back of the bowl?
« Reply #4 on: November 30, 2015, 07:11:35 AM »
Usually the 3rd gear seas the hardest acceleration, if it starves for fuel, that's where I would expect issues.
Offline bookah
« Reply #5 on: November 30, 2015, 10:01:29 AM »
I think you might be right. This morning I had a really hard time kicking her over. Sparks firing, gas flowing to bowls, compression is fine. My guess is the floats are set wrong and it's having a hard time sucking anything up. Once I kicked it over I had no problem kicking it over again, but getting that initial grab was like pulling teeth.
1978 cb550
« Reply #6 on: November 30, 2015, 10:10:06 AM »
clear tube test, asap.
Offline bookah
« Reply #7 on: November 30, 2015, 11:09:57 AM »
1978 cb550
Offline bookah
« Reply #8 on: November 30, 2015, 11:32:38 AM »
Well the jets were working perfectly. I recently replaced the carb bowls but I didn't touch the floats or jets. Now this.
1978 cb550
« Reply #9 on: November 30, 2015, 11:39:43 AM »
by "jetting issue' i mean your air/fuel mixture could be off, lean or rich, and giving you no throttle response.
doesnt mean your jets are bad, just incorrect for that throttle position.  Fuel starvation maybe?
the clear tube test is used to see what the fuel level is inside your carb bowls.
too high and you'll run rich, to low and you'll be lean.
http://forums.sohc4.net/index.php?topic=149299.0
« Last Edit: December 01, 2015, 07:05:34 AM by flybox1 »
« Reply #10 on: November 30, 2015, 11:45:07 AM »
Why would a PO or anyone else set the floats wrong?
« Reply #11 on: November 30, 2015, 11:50:59 AM »
Because if it isn't broken, they HAVE to fix it  ::)
Offline bookah
« Reply #12 on: November 30, 2015, 11:51:23 AM »
Perfect thanks. Can I run the tube off the overflow drain, or does it have to be in the drain screw hole?
1978 cb550
« Reply #13 on: November 30, 2015, 11:56:37 AM »
read the thread i linked.
your carb type determines where your tube connects.
Offline bookah
« Reply #14 on: November 30, 2015, 11:58:51 AM »
Ah, yea PD carbs. Thanks!
1978 cb550
« Reply #15 on: November 30, 2015, 12:21:42 PM »
The best kind.  @overflow tubes - makes this test a cinch!
« Reply #16 on: November 30, 2015, 01:06:23 PM »
My PO bent up the float tabs and drilled the jets. Who can say why I bet it's the same reason one put a huge 55/65 watt halogen headlight bulb in a 6 volt CL100
« Reply #17 on: November 30, 2015, 03:06:31 PM »
 Could it be you're just snapping the throttle open too fast and hitting the flat spot caused by a lack of accelerator pumps?
Offline Redline it
  • thread killer
« Reply #18 on: November 30, 2015, 04:05:46 PM »
I would just remove second gear from the trans.
Offline goldarrow
  • one day, i'll be an
« Reply #19 on: November 30, 2015, 04:10:51 PM »
Let me take it out for a test ride for ya
CB550 K0
Offline harisuluv
« Reply #20 on: November 30, 2015, 04:19:16 PM »
I can't really think of a reason why the fuel system would be responsible for something only happens in 2nd gear.  Not saying it's not possible--just trying to think of logically why that would be the case.
« Reply #21 on: November 30, 2015, 04:29:36 PM »
My money is on the transmission, 2nd gear is notorious for wearing out first.
Offline harisuluv
« Reply #22 on: November 30, 2015, 04:31:04 PM »
Aw, that would be a bummer.  I'd rather wrestle the carbs on and off 2-3 times with hard boots than have to split the cases :(
Offline Kenzo
« Reply #23 on: November 30, 2015, 05:48:11 PM »
If the bowls were low I would expect a definite stumble not just feeling of being low on power.
~5,500 to ~8,500 is the sweet spot for producing power...how high are you revving it? The power does drop off when approaching redline. When I get on it hard second gear runs out real quick and reach for third.
It does not sound like a transmission problem.
Kenzo
H-Town, Tejas
>1976 CB550F SuperSport (Work In Progress)
MotoGP Werks Exhaust, Uni Pods
>2006 KTM EXC 453 (EXC 400 w/ Short Stroke Big Bore Kit)
Offline bookah
« Reply #24 on: November 30, 2015, 06:31:24 PM »
I am just at a complete loss. I rode it home from work. Kicked over first kick,  shifts perfectly. No gear slippage,  getting gas all gears no matter how high I take the rpms. Im thinking the fuel issues solved itself (this was only the second rode since I finished the rebuild on thurs) ...then a whole new issue springs up.
I pull into my driveway after the 20ish mins home and the bike dumps about 1/4 qt of oil right when I pull in. Never had leak issues in the past. No oil where I park it at work or where I park it at home. Wtf. And I can't even tell where it came from since the whole bottom is oily. I haven't touched the engine,  no bolt tightening, nothing. It rode just fine when I finished the rebuild of the bike except for the above mentioned fuel issue (which,  to answer some further questions here, simply felt like the bike was running out of gas when I was in the upper rpms of 2nd).
It seems I can't escape issues. Everything that could go wrong,  will.
1978 cb550
