Author Topic: 1204cc - 120rwhp track bike by RPE in Oz  (Read 10614 times)
« on: December 08, 2015, 04:37:01 PM »
I've reposted this here so the HIPO guys can see it... ;)
this one says "130 to 150HP
Power wheelie
There's info on the engines at the start of the top two videos.. ;)
Re: 1204cc - 120rwhp track bike by RPE in Oz
« Reply #1 on: December 08, 2015, 05:28:04 PM »
He's a hard charger. What a riot seeing this bike out there with those others. Snarling, bawky shifting, skinny forked, squealing braked old timer....awesome. Those other riders should be ashamed.  :P
« Reply #2 on: December 08, 2015, 06:02:04 PM »
Yep, I enjoyed it for the very same reasons... ;D ;)
Offline mrbreeze
  • Not your average
« Reply #3 on: December 08, 2015, 07:15:51 PM »
Never get tired of hearing an old SOHC winding up!!
MEMBER # 257
« Reply #4 on: December 08, 2015, 08:03:15 PM »
That sum#$%* sounds ANGRY!
Offline johno
« Reply #5 on: December 09, 2015, 12:48:59 AM »
Thanks Mick,
Thats pure medacine, .......ahh feel better now
GRASSHOPPER SOHC HONDAS ARE THE MEANING OF LIFE.
« Reply #6 on: December 09, 2015, 01:02:00 AM »
Thanks Mick,
Thank Hotdog mate, he posted it in the "Australian" section, I moved it here because i knew you guys would like it... ;)
Offline hotdog
« Reply #7 on: December 09, 2015, 01:10:31 AM »
Offset barrel/rods combo, allowing bigger bore.....???? Is anything bigger than 73mm pistons limited by the studs..?
« Last Edit: December 09, 2015, 04:38:21 AM by hotdog »
Instagram - LUMPY CAM MOTORCYCLES
FB - LUMPY CAM Motorcycles
« Reply #8 on: December 09, 2015, 12:35:28 PM »
Nice sound!
Offline BPellerine
« Reply #9 on: December 09, 2015, 06:08:35 PM »
so with most not recommending big bores for the street,I wonder how that engine stands up to road racing,and yeah I know it takes a lot of skill to build that bike,but a lot of them wont take too many runs down the 1320.bill
1978 CB 750K ard and webers
another anfob
Offline stikman
  • Bit of an
« Reply #10 on: December 10, 2015, 05:27:14 AM »
Very cool!  I doubt I'm the only one who wants pictures of that engine build.
1977 CB750A "High Horse": 836cc, mild porting, custom cam, K5 roundtops, v-stacks...
1973 CB750K D5 plunger frame chopper currently building..
Offline gschuld
« Reply #11 on: December 10, 2015, 06:25:23 AM »
There are some photos, at least of the cylinder boring prep(very unique solution BTW) if you look through Facebook photo archive.
The calssic road racing rules are unique in Australia.  Most notable be is their unlimited displacement and allowance to run methanol in the pre 1972 class.  This has forced competitors to go as big as possible, yet the methanol has a great cooling effect compared to normal race fuel.  That great cooling effect of the methanol presumably gives these engines a much higher tolerance regarding cylinder and head heat control.  Notice how relatively small the oil cooler is considering the displacement and hp levels.
George
Offline bear
  • Leeton in Australia
« Reply #12 on: December 10, 2015, 03:51:37 PM »
Your dead right George.
Most people think methanol in it's self produces big HP, it doesn't.
What it does do is help control temperature allowing us to achieve tighter tolerances,  as you mentioned.
The other big plus with these motors running methanol is the cylinder pressures that you can achive.
In my opinion,  if you want big HP from these motors your better off working on their strengths.
For me that's high cylinder pressures not high rpm.
Methanol helps me achieve that.
It has a high flash point and more importantly a high auto ignition point.
One small correction mate, the engine capacity isn't unlimited we're capped at 1300cc. ;D
Brian
Offline simon#42
  • liverpool
« Reply #13 on: December 10, 2015, 03:53:38 PM »
is that 1300cc per cylinder bear ?
Offline Tintop
« Reply #14 on: December 10, 2015, 04:14:37 PM »
You didn't think it was a total for 4?  Know wonder you Brits don't do so well at Philip Island.  Ozzy rules ;D ;D ;D ;D ;D ;D ;D ;D
1980 CB750F (project)
77 CB550 Cafe build
550/750 Filter Thread
Sidecar Rebuild Thread
Offline bear
« Reply #15 on: December 10, 2015, 04:16:24 PM »
I would argue that it's just the reverse Bill.
We do the equivalent to "a run down the 1320" as you put it, at the start of every race.
Then we flog the siht out of them for another twenty minutes. ;D
Brian
« Reply #16 on: December 10, 2015, 04:19:33 PM »
 ;D  +1
Offline bear
« Reply #17 on: December 10, 2015, 04:26:00 PM »
Don't go poking Simon with a stick Brian.
They nailed us at PI last January,  it's going to be on for young and old next month though. ;D
Brian
Offline BPellerine
« Reply #18 on: December 10, 2015, 05:03:12 PM »
Brian
I did not mean that road racing was easier on an engine bear,just the opposite,the big bores take much more care to dragrace it seems ,just wondering how they get a big engine to last on the roadrace end of things,where they are run hard and for much longer.bill
another anfob
Offline gschuld
« Reply #19 on: December 13, 2015, 05:46:40 AM »
Now that's some creative cylinder/sleeve work.... :o
George
Offline Tintop
« Reply #20 on: December 13, 2015, 07:47:54 AM »
George
+1 8)  Brilliant interpretation of the vintage racing dictum re 'original castings'. ;) ;D ;D ;D
77 CB550 Cafe build
« Reply #21 on: December 13, 2015, 08:28:03 AM »
That's pretty interesting. Why not just Nikasil and forget the iron sleeves? I think there would be enough material for the oil return passages.
« Last Edit: December 13, 2015, 08:32:24 AM by MRieck »
« Reply #22 on: December 13, 2015, 10:17:22 AM »
What about the spigots on the bottom if you nicasil ? Ot do you mean build the inserts with spigots on the bottom.
 How big is the bore and are they offset?
Offline chewbacca5000
  • I polish covers!
« Reply #23 on: December 13, 2015, 11:50:36 AM »
Thanks Mick,
This will help me kick that nasty morning coffee habit that I need to ditch.  Just kept imagining myself out there on the track.  Really gets the juices flowing.  That thing is a monster.  Would like to see the actual dyno numbers though.  Just can see how you can get that much out of a naturally aspirated carb bike?
Thanks for posting.
Offline gschuld
« Reply #24 on: December 13, 2015, 11:52:31 AM »
Mike,
If I had to guess, I'd say that the method they chose for making the cylinder pairs, a casting in house, made the difference.  The photo below if from their instagram site, showing them melting down used up pistons for the pour.  Great recycling BTW.  The resulting cast sections may well have some porosity or other modest contamination that would not allow the perfectly uniform cylinder bore that a block of machine made billet (like you used) would offer.  The casting would be perfectly fine strength wise, with the sleeves not only giving a machined bore surface but also adding rigidity in the critic area between the bores.  It's pretty thin there.  Even if they used billet material instead, I imagine that they were uncomfortable with such a thin aluminum wall between 1/2 and 3/4.
Frank,
1204cc at stock stroke of 63mm is 78mm bore!  The flanges on the sleeves needed to be cut a bit where they meet since they  would overlap otherwise.  Less than 1/8" of (aluminum) meat between those sleeves.  :o
« Last Edit: December 13, 2015, 01:09:26 PM by gschuld »
