Author Topic: cb550 kick only wiring is this correct?  (Read 3365 times)
Offline TonUp550
« on: January 02, 2016, 03:54:28 PM »
So I got a new bike and am trying to wire it up. It has a Dyna S ignition and coils. With a single state regulator rectifier from Ricks. Here is my drawing I made up. If this is correct or wrong can you let me know thanks
Re: cb550 kick only wiring is this correct?
« Reply #1 on: January 15, 2016, 06:32:38 PM »
Uh, oh....if you have the Dyna S AND their "green" 3-ohm coils, your 550 will not be able to power them. You will always have a very low battery. The best you can hope for, if running the Dyna S on the 550, is to use either 5-ohm Dyna coils with it, or add one of my 2-ohm Resistor Packs to the 3-ohm 'green' coils (if that's what yours are).
Other than that" you need a healthy switch between the (+) of the battery and the rest of the circuit, so it can be switched on/off?
There must be such a switch between the (+) terminal and the side opposite the battery must feed BOTH the Reg/Rec unit AND the coils, where you show the reg/rec feeding the coils. So, disconnect that wire (Black) from the coils to the reg/rec, connect it to the switch and the (+) wire to the reg/rec, then connect the other side of the switch to the battery.
Is that clear, or mud?
« Last Edit: January 15, 2016, 06:37:20 PM by HondaMan »
« Reply #2 on: January 16, 2016, 04:04:37 AM »
and put some" fuses" in..burned vires is a mess...
