Author Topic: CB 750 K5 - Shifting hard/clunky  (Read 9088 times)
Offline andyvclifford
« on: January 22, 2016, 03:29:22 PM »
Hi!
My name is Andy Clifford, i have a 1975 CB 750 that is entirely stock minus the exhaust ( of course :( ! ).  Ive had it for a few months now and it has 15,000 miles on it.  I noticed over the course of the time I've had it the shifting seems to become hard / clunky at times and other times its completely smooth.  By hard / clunky i mean it makes a loud noise or wont pop into gear without a little bit "grinding".  Although sometimes its perfect, and goes right in without any noise.   I am trying to figure out where to start troubleshooting this problem before I tear apart the engine to get to the transmission.  What are some good things to do to test out what this might be?
Thanks!
Andy
Re: CB 750 K5 - Shifting hard/clunky
« Reply #1 on: January 22, 2016, 03:35:29 PM »
Hi!
Thanks!
Andy
It sounds like you've been bitten with some of the modern low-zinc motor oils: these gearboxes require zinc to operate smoothly and release the clutch easily. If you just changed the oil and don't want to do it again, get some zinc additive (ZDDP, in little 4 ounce bottles) and add a bottle to the oil. That will help after about 50-100 miles.
After that, use only oils rated 20w50 and LOW DETERGENT, with zinc. Examples are: Bel-Ray EXL Mineral, Spectro (synthetic), Torco Motorcycle Oils for Offroad Use Only, Motul, or a few others. DO NOT use high-detergent car oils, like Castrol XL or XR, Valvoline "V-Twin" oil or other oils for Harleys or V-Twin motorcycles, or thin oil, like 10w40. The CB750 engine needs 20w40 at the very least, and 20w50 is the recommended summertime oil weight.
Offline RevDoc
« Reply #2 on: January 22, 2016, 08:41:15 PM »
Andy, if you've been following the forum for any time before you decided to become a member then you probably realize that Mark (Hondaman) is the Grand Wizard of tech details for these bikes and will always steer you in the right direction. Besides the oils he suggested, another option that I have been using is Rotella Diesel. Diesel oil is low detergent which reduces the chance of foaming, (which these clutchs do not like!) and is a high zinc level that is crucial for these clutchs to work smoothly.
I see on your profile that you are in New Haven. If you have any Pep Boys stores up there, they stock it in gallons for a very reasonable price. I've only seen 15-40 on their racks but they could probably get the 20-50 that would be better for summer heat.
Dana
'78 CB550K--Angie
'82 CB750 Custom--Eva
As soon as you straddle a bike expect every other driver on the road to suddenly start competeing for the title "Dumbestsonofa#$%*inallNorthAmerica!!"
« Reply #3 on: January 22, 2016, 08:44:57 PM »
Wow thank you I will try this ASAP.  I am well aware of Hondaman i actually bought his book a week after buying my CB 750 and am flirting with the idea of rebuilding the engine this winter :0.
« Reply #4 on: January 22, 2016, 08:51:24 PM »
It may simply be a matter of adjusting the clutch, as well as experience with shifting a wet clutch, constant-mesh transmission. As far as rebuilding the motor, if it ain't broke, don't fix it.... ;)
« Reply #5 on: January 22, 2016, 09:30:50 PM »
Scottly has a great point: I may have overstepped my diagnosis? First adjust, THEN go after the oil, if it doesn't fix it...
« Reply #6 on: January 23, 2016, 12:25:10 AM »
Not finding neutral when engine is warm is another "problem" that correct oil can make better.
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
« Reply #7 on: January 25, 2016, 08:30:09 AM »
I find that if I don't preload my shifts a bit the transition from 1-2 (through N) is quite clunky. Just a bit of preload is all you need... you don't want to  pop into N while accelerating! Shift "slowly" from 1-2, also. Don't slap the shift. Push it.  ;D
Last year I ran BelRay, and this year (spring) I will be running the Rotella T 15W40. I'll be interested to see if I notice any differences.
--Evan
1975 CB750K "Rhonda"
« Reply #8 on: January 25, 2016, 11:11:14 AM »
You have received sage advice from extremely knowledable people. Over 15 years, I have found that the oil has
an effect. Also, as the mileage on the increases shifting changes. One other thing I have observed, these are old and strong but crude gearboxes, in addition you are also not the first owner. They do get a bit cranky on and off.
« Reply #9 on: January 25, 2016, 11:32:02 AM »
Sloppy drive chain will also cause clunky sound when shifting to 1:st from neutral. Other gears too if shift unloaded
The initial description can be as earlier written, clutch adjustment inside clitch cover  where the arm must have correct play and cable clucth cable adj.
Plus the oil that must have zinc. Search for oil in the forum when this has recently been discussed so most of the modern variants have been discussed.
« Reply #10 on: January 25, 2016, 12:08:00 PM »
+1 good point about the chain.
Offline Kenzo
« Reply #11 on: January 25, 2016, 12:59:50 PM »
Shell Rotella T and 4oz of Rislone per oil change has been working great on my 550.
Kenzo
H-Town, Tejas
>1976 CB550F SuperSport (Work In Progress)
MotoGP Werks Exhaust, Uni Pods
>2006 KTM EXC 453 (EXC 400 w/ Short Stroke Big Bore Kit)
« Reply #12 on: January 25, 2016, 04:26:06 PM »
Thank you very much -  I bought some Rotella T engine oil today and I have the day off from work tomorrow so I will do an oil change and check the clutch adjustments.  Checking the drive train would require taking the engine apart correct?  Is there any way to diagnose that part without taking it apart first?
Thank you for so much information!
Andy
« Reply #13 on: January 25, 2016, 04:32:58 PM »
Checking the chain part of the drive is simple: put the bike on the centerstand, then spin the rear wheel several turns. If the chain is in good shape, it will have a slack in it, which should be about 3/4" in the center of the lower width of the chain. If it goes tight-then-loose, over and over, it is unevenly worn. This can cause clutch shift problems, as can a too-tight chain (with no slack at all). A rusty chain, with kinked links that don't lay straight easily, will also cause 'chatter' when running (coasting) which will also make for erratic shifting.
« Reply #14 on: January 25, 2016, 04:37:16 PM »
Great!  I will add this to the list tomorrow.  Looking forward to diagnosing this problem!
« Reply #15 on: January 25, 2016, 06:17:51 PM »
Start with adjusting the clutch. Your symptoms point towards a dragging clutch.
I prefer to check the chain slack off the center-stand, sitting with the tire on the ground and weight on the seat; this will put the chain at it's tightest position. It's far better for the chain to be a little loose than a little tight! ;)
Offline Redline it
  • thread killer
« Reply #16 on: January 25, 2016, 11:34:46 PM »
Andy, if you don't know exactly what Scotty is saying here, about chain adjustment, without any guessing or measuring, is you have 3 shafts to line up, the counter shaft, pivot shaft (swing arm,) and the axle shaft, when those three are in a line, that's the tightest point of the chain unless the chain is kinked, adjust with some but little slack. The reason for the slack is, if it's too tight, it can break a counter shaft, or case, the chain is strong. And the easiest way to get the 3 shaft in line, are with a tie down connected at the upper frame to the swing arm, somewhere near a shock, compressing it, then you can set the chain tension and the alignment and know it's right, even after the axle is matching the reference marks on both sides of the swing arm, snug up the axle nut a little, and sighting down the chain from the rear,then spin the wheel, you'll be able to see if it's not straight, but double check that  the rear sprocket teeth are riding in the center and not off to either side. Sometimes the marks wont be accurate if there's slight bends in the frame.
« Reply #17 on: January 26, 2016, 01:15:24 AM »
Please, do not forget to tell us what solved the problem:)
« Reply #18 on: January 26, 2016, 01:35:49 PM »
Hi guys!
Here is what I've done so far:
Adjusted the clutch as per the Honda manual - removed clutch cover, loosened clutch cable, removed the clutch locknut and turned the clutch in until it met full resistance and then turned it back out 1/4" turn, and finally reassembled the cable to proper tension.  I included a video below of the clutch being operated without the bike on as reference to see if it looks normal!
I am still waiting on the oil filter to do the oil change, and I cannot find the zinc supplement in any auto store, so that may need to be ordered online, however I do have the Rotella T 15w-40 triple protection oil ready to be put in once i get the filter.
Unfortunately the problem persists after clutch adjustment but I think I've pinpointed how it occurs and included a video below.  Whenever I turn  the bike on, pull in the clutch, put it in neutral, release the clutch, and then pull the clutch back in and shift into either 1st or 2nd there is a loud "clacking" sound / sometimes a grinding sound before it pops into gear.  After this inital "clack" if i shift from 1st to 2nd or 2nd to 3rd ect it shifts perfectly normal.  It mainly occurs when i have put the bike into neutral, released the lever, pulled the lever back in and then shift.
Also i checked the oil cap and noticed a "tan frothy substance" on the dipstick pictured below.  I assume this is condensation?  Is this bad?
Thanks!
Andy
Offline RevDoc
« Reply #19 on: January 26, 2016, 02:31:57 PM »
Yup!, get your fresh oil in and I'm thinking you'll see much smoother shifting. My 550 was like that when I first got it and had not changed the oil yet. Regarding the Rislone supplement I have found it at AutoZone stores if you have any in your area.
Dana
'78 CB550K--Angie
« Reply #20 on: January 26, 2016, 02:34:09 PM »
What RPM is it running when going from neutral to first?
« Reply #21 on: January 26, 2016, 03:04:56 PM »
RPM - Running at idle around 900-1000 usually once its all warmed up
« Reply #22 on: January 26, 2016, 04:12:14 PM »
Does it grind the gears/clunk at less than 1000rpm, say, 800rpm or just when cold at higher rpm?
« Reply #23 on: January 26, 2016, 04:29:24 PM »
Pretty much always whenever i shift as described above.  It seems have something with setting the bike to neutral and then getting back in gear
Offline Kenzo
« Reply #24 on: January 26, 2016, 05:25:06 PM »
The neutral, first, neutral shifts look good to me...clutch not dragging too much. The question is how well will it hold under power. I'd get some new oil in it and yes most chain auto parts stores carry the Rislone.
Kenzo
H-Town, Tejas
