Author Topic: Cylinder Studs  (Read 1068 times)
Offline RodSOHC750
  • Restoring Vintage Honda Motorcycles
Cylinder Studs
« on: January 23, 2016, 11:58:52 AM »
Rebuilding a 1975 CB750F Supersport.  Stock compression.  Debating whether I should stay with the stock cylinder studs.  I'm fearful I'll run into an issue removing the old studs or break one off.  I'm leaning towards using the stock ones unless there is a good reason to remove and upgrade them.  Comments are welcomed.
« Last Edit: January 23, 2016, 12:02:02 PM by RodSOHC750 »
1979 Honda CB750L Limited Edition
1975 Honda CB750F Super Sport
1972 Honda CL450
1970 Honda CT70
Re: Cylinder Studs
« Reply #1 on: January 23, 2016, 02:48:48 PM »
 Anytime you can get more torque on the studs the better....no matter what gaskets etc.
Online Jerry Rxman Griffin aka MuthaF'er
Re: Cylinder Studs
« Reply #2 on: January 23, 2016, 05:06:34 PM »
Was it oozing oil around the head gasket? Were ANY of the head nuts less tight than the specified torque? Answer yes then go with HD studs.
Re: Cylinder Studs
« Reply #3 on: January 24, 2016, 02:38:34 AM »
Replace the old ones. The HD ones will allow you to use higher torque values and prevent possible weeping gaskets.
