Author Topic: Will Vaseline help me get it in there?  (Read 7702 times)
Offline cleveland
« on: November 07, 2006, 04:37:05 PM »
Get you heads out of the gutter!  ;D
I am having some trouble getting carbs onto an engine.  I tried using a heat gun and it softened up the boots some, but it's not enough.  I am not sure how much heat I can use before it begins to melt the rubber.  So can I use Vaseline on the inside of the boots to make them slide on easier?  Will it just burn up after a while, or would it give me a problem?
Thanks, cleveland
Offline miles nowhere
  • motorbikeist
    • Miles Hunsberger Tattoos
Re: Will Vaseline help me get it in there?
« Reply #1 on: November 07, 2006, 04:41:43 PM »
i wipe a little bit of oil on the boots...works pretty well
78 cb 750k8, 78 cb 750F3, 78 cb 750F3, 74 cb 750k4
« Reply #2 on: November 07, 2006, 05:01:11 PM »
I use a silicone spray or paste, vasoline may work also, but it may burn off.
Offline mrbreeze
  • Not your average
« Reply #3 on: November 07, 2006, 05:23:17 PM »
I've heard good things about Vasoline...................................................... :D
MEMBER # 257
ktp1598
« Reply #4 on: November 07, 2006, 05:26:38 PM »
Whatever you use, make sure it won't eat at the rubber over time.
Offline aptech77
« Reply #5 on: November 07, 2006, 05:47:05 PM »
I would something like DC4.
Offline hopterfixer
    • My flickr Gallery->
« Reply #6 on: November 07, 2006, 06:03:26 PM »
I use a very thin swipe of DC4 when I do mine.
Offline aptech77
« Reply #7 on: November 07, 2006, 06:05:48 PM »
Offline putnaja1
  • '77 CB 550k -Was gonna cafe, but looks cool stock!
    • Jason's Wacky Website
« Reply #8 on: November 07, 2006, 06:15:26 PM »
I usually heat mine to get them to go on easier
Play Pinball!
My Gallery!
"The world is divided into people who do things, people who get the credit and people who continually criticize.  Try, if you can, to belong to the first class of people.  There's far less competition"
USN20
« Reply #9 on: November 07, 2006, 06:17:20 PM »
I like using Dielectric grease on spark plug and carb boots as it's a rubber friendly product.
(Also works well on side cover grommets)
Offline mwohlenhaus
« Reply #10 on: November 07, 2006, 06:20:08 PM »
vaseline has a tendency to waterproof your hand and your...ummm...err...carb boots, for about a week and a half. :D
Offline Master Ted
« Reply #11 on: November 07, 2006, 06:22:38 PM »
ditto
CB750/K2
Offline hopterfixer
« Reply #12 on: November 07, 2006, 07:01:36 PM »
Sorry, the DC-4 mentioned above is a dielectric grease, Dow Corning #4, widely used in aviation.  I used it on every connection when I disassembled my bike last winter and on most of the rubber parts.  It works great for removing old rubber grommets and other parts without destroying them too.
Steve
« Reply #13 on: November 08, 2006, 04:57:13 AM »
When I re-fitted my carbs I struggled until I used two pieces of planed wood to gently lever the carbs into position, but be gentle so as not to splinter the wood and contaminate the bores of the carbs.
Steve.
Offline Jonesy
  • Shop Rat
« Reply #14 on: November 08, 2006, 04:59:43 AM »
Boiling the carb boots in water is the easiest way to heat them up. Gotta work fast once you remove them from the water, though...
Offline dusterdude
« Reply #15 on: November 08, 2006, 06:37:48 AM »
blow dryer
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Offline Klark Kent
« Reply #16 on: November 08, 2006, 06:41:36 AM »
I just reinstalled my carbs in 45 - 50 degree (F) weather.  no heating up. no vaseline.  and it wasnt that hard.  i dont think its because of my super strength either.  I take off all the intake boots and put the exhaust boots on the carbs.  then i slide the carbs into position and shove the four exaust boots into the head.  eventually they all rock down to flush.  then it is a matter of sueezing the intake boots into the airbox inside ones first then outer ones and shoving the airbox onto the carb intakes, a little rocking again and they flush up.  then i put the metal collars back on the intake boots (the ones on the exhaust side never came off the boots) and tighten everything up.  remount the airbox.  good to go.
with the collars off or totally loose, it doesnt seem all that hard to slide the boots over their ports.  am i missing something?
-KK
-KK
75 CB550k
95 KLR650
www.blindpilotmovie.com
download the shop manual:
you'll feel better.
listen to your spark plugs:
Hop on a Honda
« Reply #17 on: November 08, 2006, 12:01:32 PM »
The rubber boots will be greatly softened by either dropping them in boiling water OR  after boiling them for a 30 second period then dropping them into ATF.
This will allow the ATF to actually get into and penetrate the rubber itself and make it soft and pliable so as you can remove them first but put them back onto the carbys FIRST
This way the rubber boots can be put on to the carby throats correctly with the line to the top the ends are not parrallel.
When the air box is ready to be assembled onto the rubber tubes make sure that you only put the top half on first, This way you can get the boots in through the air box holes much easier than the other way.With the four clamps make sure that the two center ones are at the top. It will pay to replace the  (4) small soft screws too.
This application is just the opposite of using vaseline !!! and it wont hurt!!!
Dave
Offline ofreen
« Reply #18 on: November 08, 2006, 08:33:17 PM »
Last time I installed carbs onto the head, I used Ru-Glide tire mounting lube - yet another use for the stuff.  It worked slicker than the proverbial mucous membrane on a doorknob.
Greg
'75 CB750F
Offline Klark Kent
« Reply #19 on: November 08, 2006, 08:55:37 PM »
you know i never noticed how van gogh was holding that banana until you started talkin lube ofreen.
-KK
-KK
75 CB550k
95 KLR650
you'll feel better.
Offline ofreen
« Reply #20 on: November 08, 2006, 08:59:47 PM »
-KK
http://www.sohc4.us/forums/index.php?topic=13384.msg130020#msg130020
Greg
'75 CB750F
Offline mrbreeze
  • Not your average
« Reply #21 on: November 08, 2006, 09:02:58 PM »
Getting back to the main topic though.......Vaseline will ALWAYS help you GET IT IN THERE!!!!!........(like I said earlier...I've heard good things about Vaseline!!!)
MEMBER # 257
Offline jabbadeznuts
« Reply #22 on: November 09, 2006, 12:54:20 AM »
depends on how tight she is ;) ;D
'75 CB550
'82 Suzuki GN125 - glad to be rid of that thing.
cafetero1
« Reply #23 on: November 09, 2006, 06:37:24 AM »
Since we are on the topic of carb boots, can any of the experts out there (I'm a rook) pipe in on alternatives (if any) on having to purchase these carb boots from the dealer?  It looks like I will need to replace mine.  I inquired from the dealer as to cost and availability and I just about crapped my pants when I heard what these would cost?
Thank you in advance for any feedback.
Offline Lumbee
    • My pics...
« Reply #24 on: November 09, 2006, 07:20:26 AM »
...lay on it with the heat gun until they are soft enough...the head gets pretty hot, so I don't think you have to worry about damaging the boots...if you se smoke, then stop...   ;D
"I'm not a welder, but I play one on HondaChopper.com"
