Author Topic: Cb 750 k2 fromt brake replacement  (Read 968 times)
Offline topperharley
« on: April 03, 2016, 08:29:27 AM »
Im looking for a bolt on type of solution. Org. front brake is bit powerless.
Do i only need to change the disc or replace everything? Im not looking for a superbrakes just a bit of a emprovement.
A list of bikes with fitting parts would be nice.
Re: Cb 750 k2 fromt brake replacement
« Reply #1 on: April 03, 2016, 08:37:38 AM »
A GL front end is your simplest "bolt on" improvement.  It has twin discs.
Is your bike that fast that you feel you need better brakes?
« Reply #2 on: April 03, 2016, 08:47:22 AM »
:D no its not. (Rebuilt from 900cc to 750cc) It just lags power. The brake i mean. Im gonna try new pads and new brake hose. If it makes no difference il change the disc.
« Reply #3 on: April 03, 2016, 09:15:14 AM »
Rebuilt from 900 to 750? You went the wrong way!
Highly doubt a disc change will improve your brake.  Do you have a good firm lever when braking?
« Reply #4 on: April 03, 2016, 09:17:57 AM »
 Deglaze you disc a little bit while you do your other maintenance.
« Reply #5 on: April 03, 2016, 09:59:29 AM »
David silver has new front disc that is written to be better than the bad Honda disc. New pads too. If your master cylinder is bad, they have a good replacement for not that much.
« Reply #6 on: April 03, 2016, 11:00:59 AM »
I had to. I gave up trying to find parts for my Henry Abe 900cc kit. There is not. Not for my wallet anyway.
« Reply #7 on: April 03, 2016, 11:02:25 AM »
« Last Edit: April 03, 2016, 11:04:25 AM by topperharley »
