Author Topic: Tuning mixture screws  (Read 632 times)
Offline cuz
« on: April 21, 2016, 06:48:15 AM »
I am making final adjustments on my cb750k7 before my maiden voyage after a two year restoration.  The timing is adjusted and carbs are synced.  I'm wanting to fine tune the mixture but am unclear of the process.  The bike runs pretty good at the suggested 1.5 turns out.  It fine tune do you adjust one carb at a time until you observe a change in idle or tweak all 4 at a time, bit by bit?  The manual suggests you aim for the highest possible idle.  So too lean or two rich and it will stumble? Am I just aiming for a sweet spot? Lots of questions in one paragraph there, sorry.  Thanks in advance for any advice given.
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
Re: Tuning mixture screws
« Reply #1 on: April 21, 2016, 06:57:05 AM »
That high idle, etc, is really hard to find by ear.
Go by plug colour.
Get the bike nice and warmed up with a fan running in front of it. Then shut it off and put a FRESH set of plugs in. Let it idle for a few minutes, and then take the plugs out. See what colour they are. Should be a dark tan. This is a good idle mixture. 0
Post the pics here and we can help you tune if necessary.
White = lean
Black = rich
Tan = just right
--Evan
1975 CB750K "Rhonda"
« Reply #2 on: April 21, 2016, 07:02:23 AM »
Go by plug colour.
White = lean
Black = rich
Tan = just right
THIS ^^^
your ears are not calibrated for A/F mixture tuning  ;)
idle plug color
