Author Topic: 74 CB550 Rear Wheel Size?  (Read 4226 times)
Offline Sox Fan
« on: April 23, 2016, 07:17:30 AM »
Ordered tires for my 74 CB550 and the rear tire is too big for the rear wheel I have. Everywhere I looked online said the rear wheel is 18" on these bikes. Ordered an 18 x 4.00 tire and I am guessing now that I have a 16" or 17" rear wheel?
Already removed and tossed the old tires so can't look at the tire to get a size.
Did CB550s come with different rear wheel size options or did some previous owner put a non stock wheel on this bike? Here's a pic of the wheel.
Offline grcamna2
Re: 74 CB550 Rear Wheel Size?
« Reply #1 on: April 23, 2016, 07:23:39 AM »
That does look like a 16" rim which will take a 130/90-16.Do you see any stamped numbers on the rim itself ?
The other tire number that fits from back then was MT90-16
« Last Edit: April 23, 2016, 10:35:15 AM by grcamna2 »
75' CB400F/'bunch o' parts'
Offline Sox Fan
« Reply #2 on: April 23, 2016, 07:59:38 AM »
No markings on it. it measures 4" wide. Running a tape across the wheel it measures 17 3/8". I think I have a 16" x 4" wheel?
Did some searching and it sounds like this was a mod some people did back in the day?
Would prefer the 18" rear wheel but already had this one powdercoated so will see if I can find a tire to fit.
« Reply #3 on: April 23, 2016, 11:21:01 PM »
That's not a stock sized wheel.
Offline 700504
« Reply #4 on: April 24, 2016, 01:41:28 PM »
I acquired a 550 with the same set up; 16 harley rim laced to honda hub, mine came with an avon mkII on it.
1978 cb750k
1977 cb750f2
1974 cb750k
1973 cb750k
1981 cb650 (rip)
1969 ct90
Offline Sox Fan
« Reply #5 on: April 25, 2016, 09:51:08 AM »
OK - so it looks like a 130/90-16 or 5.00 x 16" tire should fit?
Thanks for all the responses.
Offline grcamna2
« Reply #6 on: April 25, 2016, 10:02:37 AM »
You could put a nice Avon RoadRider 130/90x16 on it.
Offline 700504
« Reply #7 on: April 25, 2016, 02:28:21 PM »
Correct, if you look on Avon's website they have charts for this. They list the minimum and maximum rim width that the tire will tolerate, all being 16 in diameter.
1978 cb750k
1977 cb750f2
1974 cb750k
1973 cb750k
1981 cb650 (rip)
1969 ct90
« Reply #8 on: April 25, 2016, 04:36:45 PM »
I'd put an 18' wheel on there.  It will handle better plus it wont have the large gap between the tire and fender [if all else is stock]
Offline Gene
  • Chat enuf you too can be a
« Reply #9 on: April 25, 2016, 04:58:26 PM »
Stick some of those firestone balloon tires on there and there won't be a gap. . .  BUT SERIOUSLY - DON"T GET THOSE BALLOON TIRES!  I'm only joking around - that's a tiny wheel though.
*1973 CB750K3 (Bow)
Offline grcamna2
« Reply #10 on: April 25, 2016, 05:08:37 PM »
+1
« Reply #11 on: April 25, 2016, 11:31:17 PM »
+1
++++1
