Author Topic: What do you think of this paint prep procedure and execution?  (Read 1256 times)
Offline SKOL
This is what I'm thinking and I wanted to bounce it off whoever has some experience/opinions. Please tell me what you think, how you have done it in the past, with both positive and negative results.
I have my case halves, jugs, and cylinder head soda blasted, scuffed with maroon scotchbrite, wiped down with Eastwoods Aluma-prep, and I will give it a final wipe with acetone before painting.
The actual paint procedure, I was planning on assembling the engine, with no guts, using the old case bolts. Painting it, disassembling it, then reassembling it with everything installed, using new case bolts.
I could also tape everything off and paint pieces individually, but then the concern of masking off bolt holes comes into play.
What do you guys think? If I paint the engine pseudo- assembled engine the only things that need to be masked off would be intake/exhaust and the areas the covers would go. If I go this route... have any suggestions for masking off bolt holes/intake/exhaust?
Thanks
Re: What do you think of this paint prep procedure and execution?
« Reply #1 on: May 27, 2016, 07:57:45 AM »
i use foam ear plugs to protect holes while painting.
« Reply #2 on: May 27, 2016, 08:03:52 AM »
I did each individual piece separate.   Didnt want to ufck up my paint while disassembling/moving everything.
It might be tough to roll the engine to get inside the fins/nooks/crannies without ruining paint applied in another area.
3" painters tape and some fresh razor blades masks things quickly.
Offline SKOL
« Reply #3 on: May 27, 2016, 09:20:54 AM »
How did you mask off your bolt holes? Also, I was planning on hanging it from the rear motor mount from the ceiling. So it's kind of suspendEd in air at an angle
« Last Edit: May 27, 2016, 09:27:27 AM by DickBojangles »
Offline SKOL
« Reply #4 on: May 27, 2016, 09:21:15 AM »
That's a great idea
« Reply #5 on: May 27, 2016, 09:27:44 AM »
That's a great idea
+1
You can get these bulk at most big box hardware stores.
Offline CycleRanger
  • No comment about being an
« Reply #8 on: May 27, 2016, 10:00:36 AM »
That's a great idea
I learned it here, pretty sure :)
Offline SKOL
« Reply #9 on: May 27, 2016, 04:07:11 PM »
Reusable silicone plugs
http://www.ebay.com/itm/like/231284369875?
Oh nice, I wonder if there's something like these that would fit ibtake/exhaust ports
Offline CycleRanger
« Reply #10 on: May 27, 2016, 04:13:18 PM »
Just use some aluminum foil or blue tape.
Offline greenjeans
  • 1972 CB750K2
« Reply #11 on: May 27, 2016, 08:43:47 PM »
The rubber caps that go on the legs of cheap fold-up chairs work great for sealing up intake & exhaust ports.  You can get different sizes at Home Depot etc
