Author Topic: Cold header pipe # 1 cylinder - eventually kicks in  (Read 6495 times)
Offline b1jackson
Re: Cold header pipe # 1 cylinder - eventually kicks in
« Reply #25 on: June 03, 2016, 05:37:53 PM »
I did the repair job on the two wires before I did the meter readings.  There was also a slightly bare wire on one of the black/white wires connecting the coil to the harness so I fixed that too.
I forgot to mention that my plugs are all new and NGKR DR7EA
Old Honda Rescue Centre
ohrc_vintagemoto on Instagram
« Reply #26 on: June 03, 2016, 11:52:14 PM »
http://blacksquaremotorcycle.com/ignition-coils-test/
Using this as my guide
Thanks for the link. It's an excellent guide and can be used for those to come. In defense of Clymer I must say that ohmmeters in the early 70s were not as cheap as they are now.
When I reread, I see that you have both 5KΩ sparkplugcaps and R(esistor) sparkplugs that are usually around 5KΩ as well. Even if that was OEM for Canada models, it's a bit much. Most of us prefer either 5KΩ sparkplugcaps or R(esistor) sparkplugs. I'm not saying this is the cause of the problem, but all in all you have a bit much resistance there. With everything else OK, it will run however. The problem is that these resistors have the nasty habit to increase in resistance over time and then you'll have little or no margin left. My advice would be to run the normal D7EA plugs when you have the 5KΩ caps. For the moment you can use what you have and check carefully if there's any 'firing' between caps and head (= ground) or HT leads and ground. Best seen in the dark and listen for little cracklike sounds. On the other hand four NGK D7EA plugs is not a big investment and you could help us if you tested both sets and communicate the results. After all there is the chance the #1 sparkplug is no good anymore and simply replacing could be the cure. Mind you, we're still in step 1 of trying to analyze what is possibly wrong. BTW, I recommend to use the Honda plug wrench that is probably in your toolset. I've made it a habit everytime I replace a sparkplug to put a tiny little bit of coppergrease on its thread (Not all needs to be covered. Far from it).
« Last Edit: June 04, 2016, 04:41:14 AM by Deltarider »
Offline b1jackson
« Reply #27 on: June 04, 2016, 03:14:32 AM »
[/quote]
Snap a clear picture of the coils, meter with leads and the wires you're connecting to all in one picture if you can.
[/quote]
Offline b1jackson
« Reply #28 on: June 04, 2016, 03:34:33 AM »
Yes, it is.  My black probe is busted so I just have to make connection with the wire tip.
Offline b1jackson
« Reply #29 on: June 04, 2016, 03:55:12 AM »
Yes
Offline DaveBarbier
« Reply #30 on: June 04, 2016, 06:38:23 AM »
Above the yellow wire and to the left of the green wire, is that a solid white wire or a black/white wire?
So you're touching the yellow wire and the black/white wire with the meter leads. Ok. What is your meter set to in the ohms scale? The picture isn't very clear.
Do you have any known resistors laying around that you can test and confirm the meter is correct? But you tested the plug caps and got good results...
Offline b1jackson
« Reply #31 on: June 04, 2016, 10:23:21 AM »
Above the yellow wire and to the left of the green wire, is that a solid white wire or a black/white wire? Thats from the other coil I believe.
So you're touching the yellow wire and the black/white wire with the meter leads. Ok. What is your meter set to in the ohms scale? The picture isn't very clear. 20 ohms. Same as when I did the plug caps
Do you have any known resistors laying around that you can test and confirm the meter is correct? But you tested the plug caps and got good results...yes, meter is fine
« Reply #32 on: June 04, 2016, 10:56:16 AM »
Just figured out your's must be a K3. Now I know, I have some more advice but first things first.
Offline b1jackson
« Reply #33 on: June 04, 2016, 01:15:32 PM »
Ok.  Here is an update.  A weird one...but an update anyway.
I hooked all the coil wires back up and swapped in new plugs in 1&4 (same kind as what was in it).
Before I hooked the fuel tank back up, I decided to bump the starter and run it abit. Fired right up and # 1 pipe warmed up right away #2 stayed cold, and 3&4 were warm.  So I swapped in a new plug in number 2 and trimmed back the spark wire abit.  Then reinstalled the tank thinking I was in the clear.
Backed it out and ran it about 5 min.  #1 dead cold and all others hot.  What?  Frigs sake.  I think that I am going to trim back the spark plug wires abit and see if that isn't the issue.  Perhaps with a weakening old coil, it doesn't take too much to prevent a full spark where the wire goes into the boot.  Blasted carb cleaner into the line to before the tank went on.
FURTHER UPDATE - wires all trimmed back now and caps retreaded back on.  Ran it again and same thing..cold #1 header all other perfectly hot.  Pulled #1 plug and then cranked it.  Lots of spark and it ran briefly on three cylinders with one plug removed and spark running through me. bzzzzzzz. Haha.
« Last Edit: June 04, 2016, 02:12:27 PM by b1jackson »
Offline b1jackson
« Reply #34 on: June 04, 2016, 05:40:02 PM »
Tomorrow's job will be to try a valve adjustment. ::)
« Reply #35 on: June 05, 2016, 01:55:57 AM »
If you haven't done that before, maybe it's wise to have somebody attend that has experience.
BTW, still haven't read that you checked for arcing between plugcaps/HT leads and enginehead when everything is in it's place. Best observed in the dark
Offline b1jackson
« Reply #36 on: June 05, 2016, 02:22:10 AM »
Yes. I did check last night looking in the dark and could not see any arcing anywhere.
Regarding a valve adjustment, is it possible that one cylinder could be so far out of adjustment that it won't even fire while all others work and perform perfectly?  I know I have to check them all but it seems strange that I'm still having problems with only one cylinder and I know it's capable of firing because the pipe #1 was hot as per post 36 above.
« Last Edit: June 05, 2016, 02:27:33 AM by b1jackson »
« Reply #37 on: June 05, 2016, 03:31:03 AM »
I do not think it has to do with the valves because it wouldn't explain the 'kick in'. But maybe it is a good opportunity to exercise a valve gap check. When you do it for the first time, I always advice to have somebody attending that knows how to do it and can check what you've done.
But I'd rather start with a simple test to see you have the correct fuel level in the bowls and fuel flow is constant and not intermittent. Are your fuellines OK, without kinks and without 'extra' filters? Reason I ask is that decades ago I had this 'kick in' effect and it was caused by an extra inline fuelfilter. K3 carbs sometimes have their vent tubes blocked or pinched closed by the main stand. These are all simple tests that won't take much time and you have to do them anyway. If you mistrust coil 1+4, you could swap it  with coil 2+3 and see if problem follows the move. Hope leads will be long enough. Coils rarely go bad but if they can't get rid of their energy for a too long period they will.
« Last Edit: June 05, 2016, 03:57:14 AM by Deltarider »
Offline b1jackson
« Reply #38 on: June 05, 2016, 03:56:04 AM »
I talked myself out of a valve check with the fear of messing something up.  I have done them before but with a simple 1 cylinder scooter engine bench.  Somewhat easier.  I did pull the valve caps for a look and put the engine at TDC.  Sliding in the feeler, I see no need to adjust as I have good drag on the gauge.  I'm tend to agree that valves are not the issue since I have had fire in this cylinder before.
I checked the pilot screw on carb number 1 since it's reasonably accessible without yanking the carbs.  I turned it flush with 1.5 turns.  Then took it out and blasted a good dose of carb cleaner into the carb.  When I put it back in, I turned it out 2.5 turns from flush as I read somewhere that that is a safe starting point.
I do have a small clear inline filter which isn't clogged.  I need the filter as my tank is a bit cruddy inside.
I'm just going to let it since for an hour or so before buttoning things back up and seeing if the pilot screw clean and tweak did anything.
« Reply #39 on: June 05, 2016, 04:00:58 AM »
Are the minuscule rings still there?
  As long as there's a good filter on the petcock, no extra filters are needed and they can cause the fuel flow to become erratic.
Offline b1jackson
« Reply #40 on: June 05, 2016, 04:11:03 AM »
Yeh, there is no filter on the petcock.
I did notice rings but they may have stayed in the carb.  Maybe I am incorrect in calling this the pilot?  It's the needle looking bit with a spring that is under the carb closest to the engine.
« Reply #41 on: June 05, 2016, 05:54:22 AM »
Yes and it should be set as prescribed. There should be a small O-ring.
Offline b1jackson
« Reply #42 on: June 05, 2016, 06:27:34 AM »
I'm losing ground now! : >:(.
Put it back together and fires righ up.  Kept hand on the throttle for about 2 min or so and now #1 and #2 are cold.
WTF is with this sporadic cylinder fire?  Can't wait to hear how good it sounds when all 4 are firing!
Offline b1jackson
« Reply #43 on: June 05, 2016, 06:49:53 AM »
I guess that is where I should move to next then.
Offline b1jackson
« Reply #44 on: June 05, 2016, 07:25:01 AM »
« Reply #45 on: June 05, 2016, 08:58:46 AM »
Man, thought you already had been there. Two easy checks anyone can do.
Condensors. When idling look for possible arcing. Some tiny sparks are OK.
For clarification see this video. In this video left condensor (1+4) is bad and causes arcing which means little or no spark at plugs 1+4, right condensor (2+3) shows only very little sparks and is good.
Breakerpoints. Check carefully none of the connectors at the breakerpoints is too close to the plate and so can make ground intermittently when engine vibrates. Failure of a breakerpoint or condensor would affect two cilinders however, 1+4 or 2+3.
Looking at your plate I see the original TEC plate and aftermarket, Daiichi breakerpoints. If timing is right, folks that say you can't get the adjustment right with Daiichi, should have look at your picture. So to see, setting of all plates and breakers is nicely in the middle of the range. Unless you suspect the timing to be off, I'd leave it as it is.
Could there be any water in your fuel?
I've given it liberal doses of seafoam as well.
I don't know Seafoam and I don't know if one can be too liberal with it although I suspect not.
« Last Edit: June 05, 2016, 12:12:23 PM by Deltarider »
Offline b1jackson
« Reply #46 on: June 05, 2016, 12:51:21 PM »
This has been a fantastic learning experience and I thank you all very much for the tips and tricks along the way.  So taking off the points cover, here is what I found:
- could not see any obvious sparking or arcing out of the ordinary.  Actually on the right point set, it was very tricky to even see any and on the left set, it was dancing around on the surface of the points contact but not arcing outside the plates.
I switched the condensers to see if the issue would move to the other cylinders but it didn't seem to.
So I rubbed cleaned up the points abit with some emery cloth.  A trick that I saw my dad do dozens of times working on old engines. The right one really wasn't that clean.  Put the cover back on, and yay...firing on all 4.  Went for a good little rip and it ran great, idled and everything.  You could tell the seafoam was making its way into the previously non firing cylinders as it was smoking abit out the tail pipe as it was burning out the gunk.
So I think for now I am going to set the points to the proper spec and maybe swap in a new set later on.  I'm not going to touch timing as I have no indication that there is any problem with that.
« Reply #47 on: June 05, 2016, 01:41:06 PM »
But you are aware that setting the points to the proper spec will change the timing?
Offline b1jackson
« Reply #48 on: June 05, 2016, 01:42:53 PM »
Points needed very little adjustment.  I think they are just worn out and weak.
Any suggestions for a real good set of points and condensers?  I wouldn't object to buying the whole plate if practical and not too costly.  Screw holes, screw heads, etc may be getting a little worn
« Last Edit: June 05, 2016, 01:54:33 PM by b1jackson »
Offline b1jackson
« Reply #49 on: June 05, 2016, 05:43:08 PM »
Is any brand as good as the other?  I don't want to have to mess or modify anything and prefer quality.
