Support the site. Your contributions keep this site running.
I think that those numbers are just what the seller uses to label his parts. There is only one seller that uses them. It's a salvage yard. I've bought from them a bunch and that code means nothing to you. Sent from my Nexus 5X using Tapatalk
Searching EBAY for used 1975 CB750 oil pumps. I don't understand the HM751, HM345B, HM184, HM305, HM128B, HM640 etc. in the pump descriptions. What are these codes?
Thanks. I was able to make a good one out of three. None of the three pump lobe tip clearances met the Honda spec of .002 inch. Most ranged from .004 to .008 inch. Not much choice since I can't buy new lobes. Picked the smoothest lobes and replaced all rubber parts.
