Author Topic: 77 550F supersport Revival  (Read 6184 times)
Offline PGF550F
« on: July 11, 2016, 04:12:45 PM »
Well I got this back in 2012 and can finally consistently ride it without fear of getting stranded.I figure its time to start contributing now that I have enough knowledge and seat time to at least try keep up on here!! ;D
 I grew up riding a Honda big red three wheeler and snowmobiles so I'm no stranger to small motors but never owned a motorbike before. I have had my licence and been riding for about 10years but always just borrowed my father in laws bikes(he got me hooked on motorbikes, its all his fault :D) Ill be the first to admit I was a complete noob when I first got this thing but have been learning quite quickly.
It had about 22000Km on the odometer when I got it and looked pretty scruffy in my really naive opinion, but with a wife and kids and a mortage to pay, the $100 I spent on it seemed about right. I knew I wasn't going to "restore" it so Ill call it a revival.
I was eager to learn so I found this place and joined up and started reading and tinkering as I learned, used the search function as much as I could before asking questions and tried to work on it as often as I could find the time.
I cleaned the carbs, changed the oil, unseized by front brake caliper, and a whole pile of other things. The wiring was hacked up on the right handlebar switch and the ignition so I had to do some learning of the electrics... I was most intimidated by that but circuit by circuit I got it figured out and wired up a replacement ignition and a new start/stop switch.
The tank was rusted so I needed to solve that before I poured any fuel through the cleaned carbs, I read up and tried my hand at electrolysis. That was fun!!
I followed up the electrolysis with toilet bowl cleaner and it actually came out pretty clean!! Good to go with putting gas in it. Got some gas in it and aftrer doing the 3000mile service and some new plugs it roared to life, I was stoked.
From a bike with no key and no idea when it last ran(or if it would run) I got this thing going. I was pretty proud to get it running and that gave me the justification to keep at it and I bought new tires and cleaned up the rims.
New Fork seals and oil
Replaced brake lines with SS braided from Slingshot, new pads+shoes. Also replaced the degraded Carb-airbox rubber boots and clamps. Then got to thinking about paint. The black and red just wasnt doing it for me, along with the cracks and rust spots.
I put a wire wheel on my angle grinder and went after it. I read up alot on proper automotive paint and got it painted and sealed with SprayMax 2K clear. Its not perfect but only I notice the tiny imperfections. I now have another skillset: bodywork and paint.
Got some old 350 tank badges and repainted them and cleared over them too.
Once I was happy with that, I had to do something about the seat. The original one was i think from a 400 Honda and never fit, had no latch, cracked etc. I finally found an F model seat on ebay(quite a task!) and snapped it up. Its not black but I figure I can always change the cover out later.
 I ordered a NOS points plate off Evilbay and installed that. Also put on new plug wire and plug caps.
That pretty much brings me where I'm at now. Currently fighting with her running RICH like crazy, pulled the air filter and it runs better, still burning more fuel than it should.
I' m starting to think that the ETHANOL laced fuel may have eaten up my main jet O rings. Off with the carbs for the ??? time. :P
« Last Edit: June 21, 2017, 09:02:00 AM by PGF550F »
Offline straat-toe
  • Everybody knows about the bird.
Re: 77 550F supersport Revival
« Reply #1 on: July 11, 2016, 08:46:34 PM »
Welcome,
Good work so far! Nice paint.
No School, No Job, No Worries.
Offline flatlander
« Reply #2 on: July 11, 2016, 10:48:13 PM »
good revival so far. once you get the carbs sorted and she runs properly you might want to replace those old shocks. they were #$%*ty even when they were new.
« Reply #3 on: July 12, 2016, 06:16:16 AM »
Nice refresh. I don't think anyone has seen a tan seat cover.
Offline Bankerdanny
  • Endeavor to persevere
« Reply #4 on: July 12, 2016, 09:25:48 AM »
Yea, we definitely need a better shot of that seat.
Offline riffman12
« Reply #5 on: July 12, 2016, 12:00:54 PM »
looks like a fun project!
double check the fork seals are in correctly. If I'm not mistaken, the open side of the seal with the little metal spring should face down into the fork. I can't quite tell from that photo.
Offline Bankerdanny
« Reply #6 on: July 12, 2016, 12:48:37 PM »
The seals likely have springs on both sides. The side with the writing on it should go up I believe, at least that's how I installed them on my '75 550F.
Offline PGF550F
« Reply #7 on: July 12, 2016, 11:36:45 PM »
Yeah, they are AllBalls double lipped fork seals. Hard to see in the photo but the writing on the seal is down in that grove that faces up. The open spring side of the seals are facing towards the fork lower(and the oil). Also, AllBalls says they have to be installed with the double lip facing down which they are as well. They hold oil so far.
 Bearings or seals, I always install them so the markings are facing out on final assembly.
I'll post up a few more photos of my tan seat when I get a chance, it seems there aren't many out there this colour( it's an aftermarket cover) but well made.
Offline Scott S
« Reply #8 on: July 13, 2016, 03:51:38 AM »
 Great transformation!
 A little Windex and 0000 steel wool on that exhaust and header will clean it right up. Follow up with chrome polish and the 0000 steel wool.
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
« Reply #9 on: July 13, 2016, 05:20:05 AM »
Nice job! Welcome to the Blue 550F club...
Offline CBGhia
« Reply #10 on: July 13, 2016, 05:31:42 AM »
Dude, I need to see more pictures of the bike as a whole so I can get a better understanding of how I feel about that seat.
Post more pics.  ;D
« Reply #11 on: July 13, 2016, 01:08:35 PM »
Or the blue 550 club . . .
« Reply #12 on: July 13, 2016, 07:20:03 PM »
Sorry Don, yours is a K!
« Reply #13 on: July 13, 2016, 09:01:21 PM »
Ah, but my 550 frame/650 engine might qualify IF it was blue.
Offline PGF550F
« Reply #14 on: July 14, 2016, 12:07:57 AM »
Yeah, doesn't seem to be too many true F model 550's around. This one was originally candy sword blue so I went back to as close as I could to the original. It came out just a few shades darker but the flake really pops out in the sun. From what I have seen they seemed less popular(or they just built less F models). Either way it's an honour to be a part of the club ;D
Does anyone know where to get good carb kits with needles and seats? I'm thinking it might be time as the float needles don't have much spring left in them, they seem to seal fine but every once in a while I get some gas from the odd overflow tube.
Offline flatlander
« Reply #15 on: July 14, 2016, 08:23:02 AM »
blue f-er club?  8)
« Reply #16 on: July 14, 2016, 08:29:59 AM »
Now it's "TRUE" F___ blue 550s!
  :o ;)
Offline Bankerdanny
« Reply #17 on: July 14, 2016, 10:25:05 AM »
Welcome to the club indeed
« Last Edit: August 07, 2020, 05:26:54 AM by Glenn Stauffer »
Offline PGF550F
« Reply #18 on: July 14, 2016, 11:13:23 AM »
A couple more photos from the other day when I rode to work.
Offline flatlander
« Reply #19 on: July 14, 2016, 11:19:23 AM »
nice pictures.
what's that grab bar with the hoop over the tail light? for hanging bags waaay back or what?
Offline Bankerdanny
« Reply #20 on: July 14, 2016, 01:46:21 PM »
nice pictures.
I was noticing that too. it looks like it came from a much bigger bike like a GL1000, which would use basically the same tail light.
Offline PGF550F
« Reply #21 on: July 14, 2016, 03:40:40 PM »
There was an awesome sissy bar on this thing when I got it that bolted to the taillight/fender. That grab bar was welded together and bolted to the fender on each side. Keep meaning to fix the broken welds but the MIG is out of gas at work so I'll have to borrow my father in laws. Or break down and use the ARC welder.
I wouldn't be surprised to learn the rear fender/ grab bar is off a different bike.
« Reply #22 on: July 14, 2016, 04:56:52 PM »
TrueBlue F'r........and original paint on tank!
Offline PGF550F
« Reply #23 on: July 14, 2016, 07:17:42 PM »
A couple driveway shots. I rode her in the rain the other day so now I need to wash/wax again.
Offline CBGhia
« Reply #24 on: July 15, 2016, 10:18:31 AM »
I think I like that seat.  Now, you do need to get some sandpaper and a polishing wheel and attack those engine covers.
