Author Topic: Cb550 Cam Install Question  (Read 1707 times)
Offline Wreckitralph54
« on: November 11, 2016, 06:36:32 PM »
So I have a cb550 and the top end was taken apart. I set the timing mark on the crank to 1-4 TDC. I then installed the cam with the notch aligned parallel to the mating surface of the valve cover. I then finished assembling the motor and getting it prepared to fire. The motor kept back firing out of the exhaust on cylinder 4 and out the carb on cylinder 1. I swapped the blue and yellow wires coming from the points and the bike fires up.
Obviously I aligned the cam on the wrong stroke so do I just have to rotate the cam 180 degrees to correct the issue?
Offline That 70s Bike
  • Honey I'm not obsessed, see... I'm just an
  • SEE YOUR AD HERE!
Re: Cb550 Cam Install Question
« Reply #1 on: November 11, 2016, 07:28:29 PM »
No, it's correct.
Cam notch horizontal at either 3 or 9 o'clock determines the TDC compression or TDC exhaust stroke for cyls 1 & 4. (valve timing)
Apparently something's going on with the (ignition timing) points wiring as you've found.
Edit: just checked the 550 manual, the blue wire is for points 1-4 and yellow for points 2-3.
So were they on the wrong point sets?
« Last Edit: November 11, 2016, 07:37:28 PM by That 70s Bike »
CB750K6- survivor   CB500K2, CB550K2- projects
Offline BomberMann650
  • Holy Cow! I'm a
  • Dr. Bovinestein iBa#80333
« Reply #2 on: November 11, 2016, 07:35:17 PM »
Pictures help a lot in this situation
Offline goldarrow
  • one day, i'll be an
« Reply #3 on: November 11, 2016, 07:57:09 PM »
Check that the ignition cam at the points plate is installed correctly.  With the crank turn to 1-4 T, the tiny little dot on points cam should point to about 4 o'clock position.
Points advance cam
« Last Edit: November 11, 2016, 08:34:07 PM by goldarrow »
CB550 K0
Offline jonda500
« Reply #4 on: November 11, 2016, 08:37:47 PM »
Points advance cam
+1 it's not the cam alignment it's the points cam like goldarrow says - you have the points cam installed 180 degrees out.
John
A starter clutch thread:
« Reply #5 on: November 11, 2016, 10:16:14 PM »
Thanks guys it's deffinantly going to be the points cam. I'll check it on Sunday when I get back home!
« Reply #6 on: November 11, 2016, 10:21:21 PM »
Is the points cam removable?
  • Holy Cow! I'm a
« Reply #7 on: November 11, 2016, 10:34:11 PM »
Yes, remove the little bolt in the center of the big nut attached to the crank.  Remove the points plate, then the advancing unit comes out.
« Reply #8 on: November 12, 2016, 03:55:12 AM »
think too,,its the ignision cam vho are turned a half rotation vrong.
.its a 100%  for mee..have done it 4 times now..its just pulls aut..and can be mounted vrong vhen you lube it..and thek the springs for tension
« Last Edit: November 12, 2016, 03:58:29 AM by strynboen »
Offline jonda500
« Reply #9 on: November 12, 2016, 03:34:29 PM »
As long as you have swapped the ignition wires to the correct coil as oriented to the points cam, you needn't change anything further. Your bike will be fine just as it is from now on.
True! I ran my 400-4 for many years with the blue/yellow wires swapped after installing the points cam 180 out.
John
  • SEE YOUR AD HERE!
« Reply #10 on: November 13, 2016, 03:08:35 PM »
John
If you never correct it and decide to sell it, at least tell the buyer the points cam & wires are reversed or he could be back here posting about the wire colors conflicting with the manual info.
