Author Topic: The snowball effect...or, how to maximize a stock 550  (Read 7396 times)
Offline Lostboy Steve
Re: The snowball effect...or, how to maximize a stock 550
« Reply #25 on: December 15, 2016, 09:04:46 AM »
A stock head gasket is +-0.043" so aim for piston top at deck height and the gasket thickness equals your squish clearance. Just remove the least amount possible from the head to straighten. As I mentioned Cometic offers viton coated steel base gaskets in 0.010, 0.014, 0.020" thicknesses, (which give you options) plus MLS head gaskets in a few thicknesses as well, one at 0.040" which would be perfect is your piston crowns end up @ 0 deck.
I've never seen stock pistons as far down the bore as Cal experienced.
I would suggest whatever your pistons are below deck you remove from the top surface of the cylinder.
Don't forget you still need to measure all clearances, before you start, and after each time something is machined before you do another step. It's a process, so leave nothing to chance.
Is using the thickest base gasket to achieve the 0 deck height recommended to give you options in case another skim on cylinder or head is required?
It's damn tough asking a machinist to remove exactly "X" and get it! So I like to use a gasket in the middle of the thickness range when measuring, then go thicker or thinner as needed afterward. OEM base gaskets are good but I really like these viton coated steel gaskets. In my last race engine effort I stacked two different thickness gaskets and they never leaked. (now use 1 x 0.014") So really the minimum thickness with these is 0.010", then 0.014, 0.020", then stacking offers 0.024" 0.028, etc.
With freshly machined surfaces aim to use an MLS head gasket, they are great too.
A lot of Honda car guys stack headgaskets in their boosted projects with success. I didn't use a mls on my 550 and am now regretting it as my fiber one may (or may not) have a slight oil leak. It could be coming from above but I'm not sure and haven't looked too hard.
On a separate note this is a great thread.
1968 Honda Z50
1977 Honda CB550K
2018 Indian Scout
« Reply #26 on: December 15, 2016, 10:12:57 AM »
Steve - pull the valve cover and re-torque the head. I'll wager a dollar to a donut this will probably solve your seep...
Will do! Maybe I should put a cam in it while I'm there. Think it's worth it on a stock bottom end, ported head w/ stock valves?
I should add I followed the specs given to me with the dynoman studs.
1968 Honda Z50
1977 Honda CB550K
2018 Indian Scout
Offline BomberMann650
  • Holy Cow! I'm a
  • Dr. Bovinestein iBa#80333
« Reply #27 on: December 15, 2016, 11:03:37 AM »
Cam upgrade?!  Does a bear sh!t in the woods?!  Get one while they're still on ebay.  Could be a while before the next crop harvest comes to market.
« Reply #28 on: December 15, 2016, 12:40:03 PM »
Another way to maximize the 550 is to reduce as much weight as reasonably possible.  Strip unneeded parts, shave off unneeded mounts etc. on the frame, simplify the wire harness and electrical, use Aluminum wheels, replace steel bodywork with aluminum, etc.
Another way: pop in a 650 engine, with a mild port job and increase compression.
« Reply #29 on: December 15, 2016, 12:41:07 PM »
When plentiful the prices can be lower...when not many are available they tend to go high...  Yes, a 650 cam in a stock bike with no changes perks things up and only requires a valve cover gasket.
Have to sort the tach drive as well to use a 650 or 750 tach if going mechanical or blank port after removing drive gear and using an electronic tach.
  • Holy Cow! I'm a
« Reply #30 on: December 15, 2016, 08:00:27 PM »
I read somewhere the ratio for weight reduction to gain.  Iirc it was 14lb to free up 1 pony with static weight.
Reducing rotating weight had a better gain ratio
I lost 30 lbs before my dune trip and that was the best weight reduction gain ever.
« Reply #31 on: December 16, 2016, 09:25:52 AM »
I was thinking of getting a dynoman 358a and new springs. Idk. I might just leave it. It runs good and (for what it is)has great power even with the bags and everything.
1968 Honda Z50
1977 Honda CB550K
2018 Indian Scout
Offline joeyvans
  • Definitely not a
  • God's Country, Earth
« Reply #32 on: December 16, 2016, 09:49:46 AM »
Kinda got my feelers out for a 650 cam ( I KNEW I should have held on to the one I had....), and I've been reviewing my notes and pics on head porting.
And a fine 650 cam it is, Scott.   ;D
I threw it in when I replaced my valve cover with the updated pinned rocker shaft cover I acquired from Cal.
Sorry.... couldn't resist.
All jabbing aside... great thread and definitely curious to see what you end up doing.  I also have 2 spare 550 motors (one locked and one good) that I would like to "wake up" some day for a potential custom build of the '74 roller I have.
Subscribed!!!!
Kyle
1976 CB550 K2
Non-SOHC4 - 1974 CB450 K7
Non-SOHC4 - 1996 VFR750F
"No matter how much you shake and dance... the last three drops go in your pants."
Offline Scott S
« Reply #33 on: December 16, 2016, 10:10:17 PM »
 You know what? I'm glad you replied. I just spent another $100 to replace it. At the time, my plans had changed. Today....or, over the next year or so....I plan on "maximizing" it.
 Yeah.....I could do better but...
 Just left  the Bonneville Bobber release party. Beautiful new Thruxton... 70 Something TQ....and $15K!!!
 The Bobber wasn't that pretty, to me. New Scrambler was gorgeous.
 Give me a high end $~4K CB 550, though... ;)
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
