Author Topic: 1977 cb750  (Read 6609 times)
Offline Jollydude
1977 cb750
« on: December 30, 2016, 01:18:11 AM »
I'm building a 77 cb750 with a vfr750 single sided swing arm I'm looking for a twin brake  front fork setup that I could use the the stock vfr750 front wheel and rotors?
Sent from my iPad using Tapatalk
Offline Jollydude
Re: 1977 cb750
« Reply #1 on: December 30, 2016, 04:48:31 AM »
I'm thinking about pressing in a cb750 stem into the vfr front forks. I want to keep the wheel matched up with the rear but that vfr donor has a ridiculous linked brake setup.
Offline Jollydude
Re: 1977 cb750
« Reply #2 on: December 30, 2016, 05:22:43 AM »
Thanks I'm going to look into that bearing conversion kit. Somebody just sent me some info on delinking the vfr brakes it would be awesome if that works they are Nissin brakes
Re: 1977 cb750
« Reply #3 on: December 30, 2016, 09:26:01 AM »
I am a fan of single-sided swingarms, but is the juice worth the squeeze?
The VFR swingarm is quite a bit longer than the stock swingarm.  This will obviously affect handling, assuming that you can properly dial in a shock to provide proper suspension travel for the weight of the bike and rider. Your bike will now require more effort to turn. In addition, I highly suspect that the VFR swingarm is heavier than the stock CB swingarm.  IF the swingarm is heavier than its stock counterpart, are you going to improve the power of the engine to compensate?  Even so, the bike will have more inertia and require additional effort to change direction.
If the purpose of the bike is to drag or just for looks, most of the foregoing can be ignored -- except for figuring out how to dial in the suspension to that the rear properly hooks up on acceleration.
Just curious.  Maybe you've already taken off of this into account.
Offline Jollydude
Re: 1977 cb750
« Reply #4 on: December 30, 2016, 02:16:29 PM »
Offline Jollydude
Re: 1977 cb750
« Reply #5 on: December 30, 2016, 02:26:19 PM »
I'm also considering this stock swing arm setup.  I really dig how clean it looks. http://www.kineticmotorcycles.com/monoshock-conversion/cb500-monoshock-kit-coming-soon
Offline palepainter
    • Mike Learn custom paint and airbrush.
Re: 1977 cb750
« Reply #6 on: December 30, 2016, 02:43:21 PM »
Is it truly a monoshock suspension when it has two shocks.  :P  I like what you have going on.
Offline Jollydude
Re: 1977 cb750
« Reply #7 on: December 30, 2016, 09:41:13 PM »
With the kinetic setup ya can run the twin or mono. Ya dig the vfr swing arm tight fit lots of small issues to over come to make it work defiantly gives this ride some attitude. I'm also putting on a Gordon quick disconnect backbone kit for the frame, a set of halo demon headlights and a 850 bore job on the motor
Offline Jollydude
Re: 1977 cb750
« Reply #8 on: January 02, 2017, 07:45:35 PM »
Offline Jollydude
Re: 1977 cb750
« Reply #9 on: January 02, 2017, 07:47:30 PM »
Offline Jollydude
Re: 1977 cb750
« Reply #10 on: January 02, 2017, 07:49:29 PM »
Started the Gordon's frame kit and chopped my tail off for a frame loop I'm adding
Offline cb750tr
Re: 1977 cb750
« Reply #11 on: January 03, 2017, 02:19:40 AM »
I've delinked some Nissin brakes in my project.
Link: http://forums.sohc4.net/index.php/topic,157587.msg1819177.html#msg1819177
Offline Jollydude
Re: 1977 cb750
« Reply #12 on: January 03, 2017, 05:38:02 AM »
I got a cbr600rr front end complete I'm putting on. Im looking at using the stock rear caliper with a new Nissin rear master. I'm really digging the inverted front end with dual brakes
Offline Jollydude
Re: 1977 cb750
« Reply #13 on: January 03, 2017, 05:46:24 AM »
Pay careful attention to tire/frame conflict at the loop under full suspension compression. The stock bridged gusset is raised for a reason.  ;)
Ya I've been mocking it up on the cross bar so the it's a 17inch rear which gives me a inch less then stock and I also have a couple of more inches longer trail and the shock mount is a bit lower then stock. Sitting on it with it all mounted it feels pretty good.
Offline posmtownScott
Re: 1977 cb750
« Reply #14 on: April 23, 2017, 11:44:57 AM »
DUDE!!! that looks freaknawsm. You are off to a great start. I'm doing the same thing with my 76'. GSXR front and same vfr800 rear. have you posted any more on this build? I'd love to see more. how does it handle?
