Author Topic: Iridium plugs anyone?  (Read 4243 times)
kaysystems
« on: December 05, 2006, 04:49:52 PM »
Anyone using Iridium plugs?
I notice that they are all resistor plugs, whereas our normal plugs are not. Will that cause problems.
At $25 for 4 I may just try a set
David
Offline RRRToolSolutions
  • I love old Japanese bikes!
Re: Iridium plugs anyone?
« Reply #1 on: December 05, 2006, 05:40:03 PM »
I've got them installed. I did it at the same time I added a Dyna 2000, new 2.2 Dyna coils, and Dyna wires, so I can't tell you if it helps or not. I do know that a friend uses them in his big twin because he was always fouling plugs. He's not had a fouled plug in over a year and plans to run the same plugs for ever.
You don't want to try to gap them - some real hard stuff and a small firing tip. Buzz highly recommended them and stated they would substantially increase spark energy. Mike Rieckruns them and gives them a thumbs-up. He jets upward with them because the spark is much hotter.
Have I convinced you?
Regards,
Gordon
Kaws, Hondas, Yamahas, and Suzukis - especially Kaws
« Reply #2 on: December 05, 2006, 06:01:30 PM »
Dave, see the thread..Presious Metal Spark Plugs.
Sam.
« Reply #3 on: December 05, 2006, 06:58:22 PM »
I've heard of some problems in turbo set ups with boost in the 15 to 20lb range. That's it and that's not definitive. Gordon said it all.
Hop on a Honda
« Reply #4 on: December 05, 2006, 09:57:15 PM »
I have had a set of NGK Iridiums in my CB 750 K5 for two years there still very good and start first pop every time.
Dave Australia.
The price of one iridium plug here is ,
Wait for it A $18 EACH!!!
Offline Clutch Cargo
« Reply #5 on: December 06, 2006, 03:47:56 AM »
Are NGK Iridium plugs - resistor plugs?  If yes, are you using zero ohm plug caps?
Mike
1976  CB750K6
1976 GL1000
1994 - ST1100
1985 - HRS21
kaysystems
« Reply #6 on: December 06, 2006, 04:19:07 AM »
Mike
That's what I'm asking. Haven't found any zero ohm plug caps yet. I know that I have problems using normal resistor plugs & resistor caps.
Any idea where to get zero ohm caps.
David
eldar
« Reply #7 on: December 06, 2006, 06:28:58 AM »
You dont need 0 ohm caps. You just use these plugs in place of the normal ones. They have a much better spark and are more efficient so resistance is not a big deal.
Offline bucky katt
  • i am a pastafarian!
    • facebook
« Reply #8 on: April 06, 2010, 07:33:29 PM »
ok so i'm going to be getting jets in a couple of sizes up then when i put the iridiums in tomorrow. fortunately our local honda shop carries jets in dozens of sizes. i have 122.5's in it now with the k+n drop in filter in the stock airbox. i know this is a REALLY old thread but it IS something that i'm addressing and i thought that maybe others here could use the info too.
Mark Twain - Notebook, 1894
Offline lordmoonpie
    • Moonpie
« Reply #9 on: April 06, 2010, 11:49:50 PM »
As you know it was a bit of a saga getting my cr750 to run - switched to iridiums and it's sweet as a nut now. The spark is less prone to spread and is more focussed with them I believe...
1994 Ducati 888 SP5
1951 Ducati 50cc Cucciolo
1981 Yamaha XV750 SE
Offline bucky katt
    • facebook
« Reply #10 on: April 06, 2010, 11:52:28 PM »
did you have to rejet larger when you went to them? if so how much? i'll also be going from a 4-1 header to a modified 4 - 4 from a 77 or 78 750k modified with either no baffles or much shorter ones (cant have it too quiet can we?)
« Reply #11 on: April 07, 2010, 02:49:39 AM »
using resistor caps,and resistor plugs,is kind of going against the grain,,dont you want all the spark energy you paid for going to the gap no matter what plugs you have??not just washed off?iridiums dont as such have a better spark as much as made from a more durable metal,that can withstand higher temps and run hotter thus burning off deposits better for longer.hey kaysystems,,are those ngk?
« Last Edit: April 07, 2010, 02:53:14 AM by dave500 »
Offline bucky katt
    • facebook
« Reply #12 on: April 07, 2010, 03:09:40 AM »
yes they are NGK and all the sources i checked say you do need to run either resistor caps or resistor wires. the plugs themselves are not resistor plugs. i specified that to the dynoman folks when i ordered them.
Offline bucky katt
    • facebook
Re: Iridium plugs anyone? HondaMan help?!?
« Reply #13 on: April 07, 2010, 03:11:49 AM »
well #$%*, i specified i didnt want resistor plugs and i got resistor plugs. should i remove the resistor caps on my stock coils? ok there are no non resistor iridiums available. HondaMan? what do you say about this?
« Last Edit: April 07, 2010, 03:20:07 AM by bucky katt »
Offline CB750F2
  • Pat's first Honda 750 F2
« Reply #14 on: April 07, 2010, 05:19:41 AM »
I have been running iridium plugs for at least two years with no problems at all. The plugs still look good. I think that I removed the resistor caps. I will check tomorrow and let you know for sure. "Hop on a Honda" is right they do cost us $18.00/plug here in Australia - maybe more now. Pat
Regards
Pat from Australia
Offline Duke McDukiedook
  • Space Force 6 Star General
« Reply #15 on: April 07, 2010, 05:22:00 AM »
Denso makes Iridium plugs also- but they ain't cheap, US$11.99 each
https://www.sparkplugs.com/results_appOther.asp?otherMotiveID=58437&mfid=3
« Last Edit: April 07, 2010, 08:18:18 AM by Dukiedook »
Offline bucky katt
    • facebook
« Reply #16 on: April 07, 2010, 07:39:28 AM »
i paid 33.95 for a box of 4 from dynoman
« Reply #17 on: April 07, 2010, 08:00:34 AM »
For Nippon-Densos?
Offline bucky katt
    • facebook
« Reply #18 on: April 07, 2010, 08:09:47 AM »
NGK
Offline steamnjn23
« Reply #19 on: April 07, 2010, 08:33:49 AM »
we ran them for a while in my sons race bike.  never had any problems with them
1976 cb550
Offline CB750F2
« Reply #20 on: April 08, 2010, 09:44:00 PM »
David, I have checked my spark plug caps and they are 5k resistor caps. So I am running Iridium resistor plugs with resistor caps. Sorry for taking so long to get back to you. Pat
Regards
Pat from Australia
Offline bucky katt
    • facebook
« Reply #21 on: April 08, 2010, 10:11:17 PM »
the folks at dynoman also told me to run with the resistor caps.
Offline supersports400
« Reply #22 on: April 08, 2010, 11:30:17 PM »
Hi,
I ran my bike (CB400F '75) with NGK iridium plugs and NGK resistor caps. The plugs performed well, the last 20.000 km. The engine is starting better, and the fuel economics was slightly better from 20.3 (average over 10.000 km) to 20.8 (average over 20.000 km). The advantage is that you don't have to change the plugs every time.
Jensen
« Reply #23 on: April 09, 2010, 04:25:23 AM »
I'll go against the grain and say that I had trouble with the iridiums in my 750. It instantly became difficult to start.
I ran out of patience and replaced them with D8Ea's again and I'm back to the engine starting when it sees my thumb approaching the starter button.
This is a mostly stock engine (stock compression) with a Dyna 2000. It didn't run as well at any rpm as with the stock NGK's. I tried different ignition advance settings and never found the cause. I remember trying Champion Palladiums back in the seventies without success too, I quess this one doesn't like that "precious metal" stuff.  ;D
Offline 333
  • Time for change
« Reply #24 on: April 09, 2010, 05:47:41 AM »
Working a Honda parts counter, I never heard anything good about Iridiums.
CB350F0  "Scrouching Tiger"
CT70K0    "Sneezing Poodle"
www.alexandriaseaport.org
