Author Topic: CB 500/550 fork leg dimensions  (Read 2742 times)
Offline dragracer
  • CB750F Dragbike
« on: February 14, 2017, 05:13:48 PM »
Can anyone tell me the length of the lower leg for a CB500/550? Measuring from the top edge at the seal down to the centerline of the axle.
I know the diameter of the tubes is the same as the 750. I need to get my dragbike project as low as possible in the front without raking the neck. I need to leave some clearance between the top of the fork and the bottom of the lower triple for fork travel. If the lower legs of the 500/550 are shorter than the 750, it would allow me to lower my frontend on the bike once the forks are shortened ( internally) to the limit. I'm not interested in putting a frontend on the bike with smaller diameter tubes but just want to know if anyone has an answer to the measurement of the lower leg.
Thanks.
Re: CB 500/550 fork leg dimensions
« Reply #1 on: February 14, 2017, 05:49:36 PM »
Same as 750's Frank.
« Reply #2 on: February 14, 2017, 05:55:46 PM »
You probably mean the 750 K from 73-76 the 77/78 K is longer ..maybe same length as the 77/78 F forks.
« Reply #3 on: February 14, 2017, 06:06:21 PM »
Sure the 77/78 year legs are longer for the 550 too.
Offline dragracer
  • CB750F Dragbike
« Reply #4 on: February 14, 2017, 07:21:29 PM »
Hmm. I bought this particular setup advertised as a F1. So I assume that's what I have. I'll measure my F3 legs to compare the length. I wonder if the CB 450 legs are shorter. The diameter is 35mm as well.
« Reply #5 on: February 14, 2017, 07:23:00 PM »
450 legs will be the same length as early shorter 750 K's as well.
Online scottly
« Reply #6 on: February 14, 2017, 07:27:29 PM »
The early 750 lower legs are about 12.5" from the top edge to the axle centerline, while the late 750 legs are about 14".
Offline dragracer
  • CB750F Dragbike
« Reply #7 on: February 14, 2017, 07:49:05 PM »
I'll measure the legs on the project bike to see what I have now.
Thanks guys, its a starting point to eliminate some of my options to getting the front end of the bike lower.
1) shorter fork legs- seems like there is a difference in early and later 750's. Will explore others.
2) use a 17" front wheel- good option but the wheel is 3.5" wide, tight fit inside the forks with a rotor. Have 2 on hand.
3) rake the neck- a workable option but it increases wheelbase from the front. Not my preference.
4) move the neck up/ short neck - can be done with an aftermarket neck. Would lower frame on trees without raking neck or increasing wheelbase. More work and expense then I want to expend.
« Reply #8 on: February 15, 2017, 03:30:20 AM »
Do you add a spacer on the damper rod? It shortens installed height but obviously travel as well.
« Reply #9 on: February 15, 2017, 08:48:18 AM »
Will not the tire be the limiting factor, not the length of the forkleg ?
Offline dragracer
  • CB750F Dragbike
« Reply #10 on: February 15, 2017, 09:35:27 AM »
I added spacers under the dampner to shorten them to my initial length for mock up. As you can see, I pulled the forks up in the trees at the minimum travel I'd need between the lower tree and fork legs. Its about 3" I will need to compensate for when I add additional spacers. Still, it might not give me the proper ride height. The forks are stiff so I'm allowing some compression for the weight of the engine etc.. Again, I'm looking at options to put into place in case the weight I'm adding doesn't bring it down more. I'm going to tack up the shock/ pivot mounting points, put the roller on the ground and drop a dummy engine on the frame to see exactly what I have as far as ground clearance and fork travel.
Offline gschuld
« Reply #11 on: February 15, 2017, 11:09:50 AM »
Cb500/550 fork TUBES are shorter than the cb750 tubes.  By +/- 1.25" I believe.
George
Offline dragracer
  • CB750F Dragbike
« Reply #12 on: February 15, 2017, 01:39:13 PM »
George
Upper tubes are shorter or are the lower legs shorter??
Offline gschuld
« Reply #13 on: February 15, 2017, 04:17:35 PM »
Upper tubes.  Not your issue though.  I see, your problem is that you can't get it lowered enough without having too short of space for travel before your lowers and lower trees contact.
George
Offline Old Scrambler
« Reply #14 on: February 15, 2017, 05:50:19 PM »
Frank..........CB350 twins (also CL) appear to have shorter legs. CYCLE-X sells new fork tubes in shorter lengths.
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
