I've recently had my '76 CB750K cylinders bored, (the cylinders were rusty from many years of neglect) to accommodate the "Cruizinimage" 836 pistons, but when I picked them up the fellow at the engine shop mentioned that they had put a taper in them to make it easier to install the pistons.
I'm worried now that they may have botched the job. I understand car engines can tolerate a taper, at their lower rpm, but motorcycle engines can not. How do I go about measuring these properly to determine what they've done?
I should mention I asked them to bore the cylinders with .0010 clearance on the outside two and .0012 on the inside two on information I received here.
Hondaman has already provided some great advice, if I was closer I'd certainly head on over... hell, I may anyway, he's only 12 hours straight south!
Is there a gauge I can buy or borrow?
