Author Topic: 1981 CB650 engine rebuild question  (Read 1793 times)
Offline Calaya
« on: March 13, 2017, 08:12:58 AM »
Hi, everyone.  With the aid of my father-in-law (who is a truck mechanic) we tore down the engine, however; several bolts were seized but we got them loose.  In making plans to reassemble it in the near future, however, we noticed that the manual doesn't indicate whether to use oil, grease, or anti-seize when reinstalling the (12, long) cylinder head bolts.  Does anyone have any experience or advice related to this?  If the manual doesn't specify (with this and other instructions) do we just simply reinstall?  Thanks for your help.
Re: 1981 CB650 engine rebuild question
« Reply #1 on: March 13, 2017, 09:13:29 AM »
A light oil wipe is fine. Step them into the block to their final torque (8# I think). The cylinder nuts get stepped to about 16-18# in stages.
FYI -- the 650 uses bolts instead of studs and nuts.
Offline Calaya
« Reply #2 on: March 13, 2017, 11:19:28 AM »
Thanks, guys.  So a little light oil on the bolts is fine?  Any problem with anti-seize, as the steel bolts are going int an aluminum head. Of course, when we're finished with the bike it won't be sitting outside like it had previously, which was probably 95% the cause for such oxidation/rust.
« Reply #3 on: March 13, 2017, 02:14:42 PM »
I don't know if I'd want to use even the blue Loctite.  If you have the need to remove the head or cylinders in the future, and you are using stock bolts (as opposed to heavy duty studs on a 550/750), why make them tougher to remove?  I get that it has sealant properties, but especially if Calaya is reusing stock bolts, I wouldn't want to subject them to unnecessary extra stress.
Offline Calaya
« Reply #4 on: March 14, 2017, 08:23:52 AM »
Thanks for the info and perspectives.  I think we'll just put them back in without any lubricants, especially since the manual doesn't specify to use anything.  While my experience is that most manuals err on the side of caution, I wanted to check with the real-world experiences of members on this forum.
I really appreciate the willingness of everyone here to share their expertise.  I makes a world of difference on a project like this.
Offline Gwindt
« Reply #5 on: June 01, 2019, 12:02:04 PM »
You will definitely want to oil the threads.  Use a pipe cleaner to clean out the bolt holes or same size tap set.  Torque specs are for oiled bolts not dry...  I learned this the hard way on my 81 cb650c and snapped a head bolt off.  Big nightmare having to drill out the broken stud.  Then finding new replacement head bolts was a nightmare.
