Author Topic: Project Honda CB750 & Kawasaki Z900 Coffee Table  (Read 2566 times)
Offline Rocky2010
  • Live in Strayla
« on: April 01, 2017, 12:58:10 AM »
Probably sounds a bit whacky but I have decided to make a coffee table for the man cave out of old parts which I have been collecting for sometime now.
Managed to get lots of cheap usable bits, there will be no internal parts in these engines.
Not sure whether to do the engines silver with polished covers or paint them black with polished covers and if they are black I will sand the fins on these engines just to give them a good contrasting look.
Not sure on the configuration as yet whether to have the engines both facing forward or back to back.
I guess it will be a 1650cc coffee table :)
Here as some photos for starters
« Last Edit: April 01, 2017, 01:04:42 AM by Rocky2010 »
2010 Harley Fatboy Lo
1972 Honda CB750/4 Under Restoration
1971 Honda CB500/4 Original Condition
1972 Honda CB350/4 Original Condition
1972 Honda XL250 Motorsport Under Restoration
1967 Honda C90 Original Condition
1968 Honda S90
1962 Triumph Speed Twin
1952 Triumph Speed Twin
1970 Bultaco Sherpa T
1971 Bultaco Alpina
1958 Moto Guzzi Zigolo
1970 Moto Guzzi Ambassador Original Cond
1973 Yamaha RD250
1948 Velocette x 2
1942 WLA Harley Davidson
2006 Kawasaki ZX12R (Sold)
1980 Corvette
Offline innovativems
    • Innovative MotoSports
Re: Project Honda CB750 & Kawasaki Z900 Coffee Table
« Reply #1 on: April 01, 2017, 04:50:00 AM »
Can't wait to see how this turns out!
2007 KTM 990 adv
2003 Honda RC51
2000 Yamaha YSR50
1978 Honda Express
1975 Honda CB400f
1974 Honda CB350f
1974 Kawi H2
1974 Honda CB550f
1971 Kawi h1
1973 Kawi h1
1974 gt 550
1974 gt550
« Reply #2 on: April 01, 2017, 01:30:44 PM »
Back to back meThinks..
Offline kerryb
  • Not a very
« Reply #3 on: April 01, 2017, 01:46:06 PM »
Sounds cool...I'm envisioning back to back with 4/4  head pipes cut off to be legs.  Might need a little pedestal hiding under the bottom to support the weight.
Offline Rocky2010
  • Live in Strayla
« Reply #4 on: April 03, 2017, 06:13:27 PM »
Decided to go with both engines facing forward as they seem to flow much better that way.
Started making the base for both engines to mount on to.
I will post some photos later of the progress
1968 Honda S90
1971 Bultaco Alpina
1973 Yamaha RD250
1948 Velocette x 2
1980 Corvette
« Reply #5 on: April 03, 2017, 06:49:00 PM »
subscribed
Offline Camrector
« Reply #6 on: April 03, 2017, 08:32:01 PM »
Some one that needs cases is going to be pissed.Lol
Offline Rocky2010
  • Live in Strayla
« Reply #7 on: April 05, 2017, 04:48:31 PM »
The CB750 cases look great from the outside but the threads for the crank bolts are almost gone due to corrosion as the engine being in water sometime in its life. Picked up the CB750 whole engine from a swap meet for $90 managed to salvage some parts that is why its going in the man cave as part of a coffee table.
As for the Z900 cases they have a few issues or I would have used them to rebuild and put in a frame for use again.... Unfortunately they will life the rest of their life on display and will look in great condition when this project is finished :)
No use throwing away these parts they will be put to good use but in another way.
1968 Honda S90
1971 Bultaco Alpina
1973 Yamaha RD250
1948 Velocette x 2
1980 Corvette
« Reply #8 on: April 05, 2017, 09:04:29 PM »
 I think Russ Collins had the Triple engines as a coffee table at the shop in Gardena.. Russ Jr would know..
« Reply #9 on: April 06, 2017, 04:10:55 AM »
He did Frank.....I remember seeing a picture of it in a bike magazine many years ago.
« Reply #10 on: April 06, 2017, 09:51:30 AM »
This reminds me of the crushed 2010 Buell Blast becoming a coffee table base.
« Reply #11 on: April 06, 2017, 12:07:40 PM »
I would probably try connecting rods, cap removed for feet..bolt them to the motor mounts..
Offline Rocky2010
  • Live in Strayla
« Reply #12 on: April 18, 2017, 04:06:35 AM »
Managed to find some time to get back into building fabricating the coffee table.
The base has now been fabricated & the engine mounts are now made and welded onto the base so I am now able to install the engines so I can continue.
Fabricated the top section of the coffee table, next part will take some time to mock up so I can make the mounting points from the base to the top which will be made out of solid round bar.
Fabricated a T-section which will be the top section of the table using 2 different sizes of flat bar which will hold the glass in place so the engines are visible from the top also.
Both engines will not have any internal parts, top ends will be assembled on both engines.
All the engine covers will be installed and they will be highly polished.
Posted some more photos of the engines sort of assembled, also the top of the table is sitting on the floor to show the difference in size to the base which is 100mm x 150mm bigger in size.
Now I have to work out the bends for the round bar which will support the top of the table to the base.
« Last Edit: April 19, 2017, 01:40:11 AM by Rocky2010 »
1968 Honda S90
1971 Bultaco Alpina
1973 Yamaha RD250
1948 Velocette x 2
1980 Corvette
