Author Topic: 1975 CB750 Restoration  (Read 4905 times)
Offline derbydave
« on: April 14, 2017, 10:22:00 AM »
I recently purchased a non running 1975 CB750 for $250.  I plan to restore it as close to original as possible. There are a few missing and broken parts but it is mostly all there.  Should be a fun project.
« Last Edit: April 28, 2017, 02:57:32 PM by derbydave »
1975 Honda CB750
2003 Suzuki GZ250
Re: 1974 CB750 Restoration
« Reply #1 on: April 14, 2017, 10:24:15 AM »
Nice buy especially if it has a title.
Is the motor free or seized?
Offline derbydave
« Reply #2 on: April 14, 2017, 10:27:04 AM »
Motor is seized and no Title (yet).  In KS the bike qualifies as an antique which allows me to get a title with just a bill of sale and VIN inspection.
1975 Honda CB750
2003 Suzuki GZ250
« Reply #3 on: April 14, 2017, 11:34:08 AM »
That's a plus.
I'm sure calj737 will chime in on his "cocktail" for freeing up a seized motor.
Online CycleRanger
  • No comment about being an
« Reply #4 on: April 14, 2017, 08:58:09 PM »
Looks like you have a good candidate there!  :)
Offline Jnel
« Reply #5 on: April 15, 2017, 08:27:02 AM »
Marvel mistery oil and #2 fuel oil.  Fill the cylinder thru the plugs holes.  Let it sit for as long as you can. Keep topping it off. This worked for me on several occasions.   Be patient.  Try to turn it by hand.  Both ways.
Sent from my SAMSUNG-SM-G935A using Tapatalk
« Reply #6 on: April 15, 2017, 08:49:02 AM »
Or ATF/acetone....worked for me.  After setting a few days, put in 3rd gear and rock it back and forth.   Had a 17' long geyser shoot out of it, set the record!
Offline Jnel
« Reply #7 on: April 15, 2017, 01:22:40 PM »
Yes, this is not a indoors sport. Definitely do the final move outsid. Don't forget your safety gear, and do a JSEA pror to starting the job.
Offline derbydave
« Reply #8 on: April 25, 2017, 07:34:49 PM »
I got the engine freed up this evening.  I took the stator cover off and used my breaker bar on the end of the crank to rock it back and forth until it freed up.  Didn't take near as much as I was expecting.
1975 Honda CB750
2003 Suzuki GZ250
« Reply #9 on: April 25, 2017, 08:41:42 PM »
Good news
Offline derbydave
« Reply #10 on: April 26, 2017, 07:10:46 AM »
I put PB Blaster in the cylinders when I first got the bike.  I will probably add some MMO later.  Since I am planning a full restoration the engine is going to come out of the frame and get a full inspection and a rebuild if the inspection warrants it.
1975 Honda CB750
2003 Suzuki GZ250
Offline Jnel
« Reply #11 on: April 26, 2017, 07:50:26 AM »
Good job.  What was the mixture you went with?  PB Blaster alone?
Offline derbydave
« Reply #12 on: April 26, 2017, 07:53:11 AM »
Yup, just straight PB Blaster.
1975 Honda CB750
2003 Suzuki GZ250
Offline derbydave
« Reply #13 on: April 26, 2017, 07:38:30 PM »
My Honda loaded in the back of my Honda ready to go get a VIN inspection tomorrow and hopefully an antique title.
« Last Edit: April 26, 2017, 07:42:53 PM by derbydave »
1975 Honda CB750
2003 Suzuki GZ250
Offline derbydave
Re: 1975 CB750 Restoration
« Reply #14 on: April 28, 2017, 03:00:20 PM »
So when I went to get my VIN inspection I found out that my 74 is really a 75.  I was unaware that despite the 7/74 build date it is considered a 75 Model year.  Whoops
1975 Honda CB750
2003 Suzuki GZ250
« Reply #15 on: April 28, 2017, 03:56:10 PM »
Hodel didnt use "model years", you either have a K4 or a K5, the VIN will help you determine that.
Now, you could have had a K4 built in '74 but was sold and titled in 1975, with a title stating it's a '75.     Got it?!
Offline derbydave
« Reply #16 on: April 28, 2017, 04:22:19 PM »
It is a K5.  I did some research and looked up the model differences.  The turn signals, indicator light panel, and rubber tipped kickstand are all K5  :D  That being said Kansas designates it a 1975 since it was built after May 74
1975 Honda CB750
2003 Suzuki GZ250
Offline Tews19
  • I am no
« Reply #17 on: May 01, 2017, 04:14:58 PM »
Subscribed
1970 Honda CB750 survivor.
Offline derbydave
« Reply #18 on: May 10, 2017, 02:44:16 PM »
The bike is no longer Titleless.  I successfully got my Antique title today from the DMV.  The lady doing the title work gave me a funny look when I didn't have the original title for the bike but with some help from a supervisor and after looking up the antique title rules (which I printed just in case) all was good.  She said hey I learned something today.  :)  I can begin the real work now that all the paperwork is out of the way.
1975 Honda CB750
2003 Suzuki GZ250
« Reply #19 on: May 10, 2017, 04:33:28 PM »
What is an "antique title"?
I've made them scratch their heads and grab the big book before too!
Offline derbydave
« Reply #20 on: May 10, 2017, 05:26:35 PM »
Antique titles and the associated plates are a special class of registration reserved for vehicles 35 years or older in Kansas.  The vehicles major components must be from the same model and vintage for the year of the vehicle,  for example a modern drive train installed in an antique body or frame does not qualify.  The upside is the taxes are only $17.00 per year and I get a special antique plate when I put it on the road or I can use a plate from 1975 and register the plate so I can legally display the period correct plate.
1975 Honda CB750
2003 Suzuki GZ250
