Author Topic: Rear brake hub lining  (Read 1594 times)
Offline davido
« on: April 19, 2017, 12:18:53 PM »
Im new to the site and havent found my way around yet,so forgive me if this has been asked and answered but what to do with the brake lining in the rear hub? Is it possible to get a hub re-lined? I only saw a front hub listed on Dave Silvers are the rear available anywhere else?
 CB500/4 (72 I think)
Re: Rear brake hub lining
« Reply #1 on: April 19, 2017, 02:06:49 PM »
What is wrong with your hub?  +1 buy a used one...
« Reply #2 on: April 20, 2017, 07:27:01 AM »
Agreed, should be able to get a good used one somewhere. Also, this isn't the best forum for this question. The broader "SOHC /4 Bikes" or one of the classified forums might serve you better.
« Last Edit: April 20, 2017, 07:28:43 AM by MCRider »
« Reply #3 on: April 24, 2017, 10:39:20 AM »
korosion behind the cast material..cracks the liner. or bearings crash the inner fitting..be shure to get a erly type hub..or a komplet hveel.(.there is 2 types of senter hub..erly and late to make it simpel..i got a vrong one shopping on e bay..)..
for test..i have turnet the cast material aut on my lathe..and got a nice smooth bored hole..the problem is to find a drumbrake from a small trailer..to turn dovn and heat the hub..and drop it inn..and vhen it cool dovn it holds(..like reaivay train hveels )..but better bay a used part..easyer and more safty
« Last Edit: April 24, 2017, 10:43:58 AM by strynboen »
« Reply #4 on: April 25, 2017, 11:02:35 PM »
Common problem on 500 the hub change was in 77/78 so any 500 0r 550 k up to 76 should be ok and any complete wheel with brake panel can be made to fit by altering spacers either side
