Author Topic: Terry Bob's redneck F-ing K2 bitsa project!  (Read 210074 times)
Re: Terry Bob's redneck F-ing K2 bitsa project!
« Reply #1500 on: March 18, 2021, 12:19:17 AM »
I think I'll order some, but is there an NGK D7EA equivalent? I'm only running the D8's because I haven't installed an electronic ignition yet? ;D
Terry,will the electronic ignition you're about to install make the plugs run cooler? The D7EA is a one step hotter plug than the D8EA.
Thanks Bill, Hondaman recommends D7EA's with a 1mm gap for bikes with electronic ignitions, and the F2 and K0 run like sexually assaulted Orangutans with Kokusan EI's, Dyna coils and D7EA's. ;D
Lol  ;D  I understand Now ! Lol  ;D
Terry,I would just wonder about top-end with a D7EA being run:they may be too hot for those 180+ kmh high speed blasts for too long of a time..  ::)
« Reply #1501 on: March 18, 2021, 04:42:25 AM »
Thanks Bill, I wouldn't know, I think 90 MPH is around the fastest I've gone so far, so I wouldn't know? But I digress. Does anyone here suffer from Anxiety? I do sadly, and I treat it with an over indulgence in alcohol and Diazepam. That might sound terrible, but I actually enjoy both, so no biggie, I've had several friends and at least one family member who had mental issues and weren't able to assuage them as easily as I do, and for some of them, they lost their battles.
But as usual, I digress, again. Whereas the K0, which I built from a rusty frame and a set of bare cases in 8 weeks has been a real success story, the old K2 bitsa has been a real b1tch. Built over a much longer period in 2017, so far it's had 3 engines, and I've just finished completely rebuilding the third. Whereas the tyres on the K0 have done nearly 2000 miles in the last couple of months, the 14 month old tyres on the K2 might have done 100, but that might be an exaggeration. It's just one of those bikes where, if something can go wrong, it will.
To suggest that it's "Cursed" might sound melodramatic, but seriously, I have not had one ride on this bike that didn't peak my anxiety. (obviously I can't use my anxiety remedy whilst riding, more's the pity...) Yesterday I replaced the oil pump, pan gasket, and sump plug washer. I fired it up today, and it had a "Farty" noise coming from the cylinder head area. Fcuk, is it a blown head gasket? I took a closer look, and was 'rapt, that it was only one of the header pipes not all the way over the exhaust spigot, so the cut line on the headers that expand to allow a tight fit on the spigots wasn't all the way on, and exhaust gases were leaking through the cutouts, making the noise. Easy fix.
After that, it ran like a new bike. Engine idled smoothly, oil pressure was around 70 psi, and life was good. I jumped on, and hit the road. Now unfortunately it was a very warm Thursday afternoon and traffic was heavy. Even out on the freeway, I wasn't able to give it the berries. I got off the freeway, but even on the country roads that are usually quiet on the weekends, there was lots of traffic, so little opportunity to open it up. When I finally got the chance, it started to break down on a couple of cylinders. Bugger.
Now to be fair, I can't remember the last time (if any) that I cleaned the carbs. On top of that I'm running points, Magna (Chinese Dyna ripoff) coils of unknown ohmage (is that a word?) carbon leads and (hopefully) genuine NGK D8EA plugs. Then of course, there's no air filter in my airbox until my new K&N gets delivered next week? Same/same for the new Kokusan electronic ignition. But what was weird, is it'd break down on a couple of cylinders under load, then a minute later, it was fine again, all the way home. Miss, fart, run fine, miss, fart, run fine, repeat.
Anyhoo, I'm gonna push the Bitsa to the back of the garage (and my mind) until next week when the new Kokusan ignition and K&N filter arrive, throw another set of carbs in the ultrasonic cleaner and install new rebuild kits, and wash down some more diazepam with ginger joe. On Saturday, I'm riding the K0. ;D
« Reply #1502 on: March 18, 2021, 05:53:32 AM »
The Bosch equivalent to an NGK D8EA is: X4CS. Anybody ever tried them? Seems like an interesting option.
John,I did a tune-up on a BMW K75 back in the 90's and it had those same Bosch plugs in it:I installed a set of NGK D8EA's into it.Have you ever tried the Bosch in your Honda ?
No I have not. But I am going to see if I can find a set and report back......
« Reply #1503 on: March 18, 2021, 06:01:39 AM »
Terry...... that intermittent ignition “fart” is definitely points. My K4 started doing it late last fall. I didn’t have any new points, so picked the best set I had in my junk bin, squared them off with my blue point “points file” (still have three new ones in a box. Good luck finding one). Installed, gapped, set timing static and then with the light. “Runs like a “RA” since!
« Reply #1504 on: March 18, 2021, 08:04:11 AM »
Bad condensors?
« Reply #1505 on: March 18, 2021, 01:54:05 PM »
Thanks guys, yep I’m pretty sure it’s points too, and another reason to hate them. I do have several sets of NOS points that I’ve had for over 20 years sitting in a box somewhere but can’t be bothered with a less than ideal system when I have an electronic ignition on it’s way. I’ll save them for another build. ;D
« Reply #1506 on: March 19, 2021, 03:32:19 AM »
And just to further piss myself off, I had to move it today to get the K0 past, so I hit the button and it fired right up like a new bike! Baasatard! Oh well, new ignition and K&N filter arrive next week, so hopefully all gremlins have gone. ;D
I finally put the tank I painted for the K0 on today. I installed a new Honda cap and a key lock off another tank, and a new Honda petcock, filled it with fuel and parked it on it's centre stand to see if there were any leaks, but by 6pm it was all good, so I call success! ;D
K0 Friday 19 Mar 2021 by Terry Prendergast, on Flickr
« Last Edit: March 19, 2021, 03:59:53 AM by Terry in Australia »
« Reply #1507 on: March 19, 2021, 03:53:45 AM »
The point problem just disappeared?
That is typical for electrolytic capacitors (condensors), self healing.
Problem will come back if I'm right. Probably after 4000 rpm or so.
When electronic ignition fails you can trust the failure, dead.
Different with points that can start work again as a horn_ ape ;D
« Reply #1508 on: March 19, 2021, 04:03:43 AM »
That sounds right Per, I was riding around the 4K RPM mark when I cranked it on and it missed and farted, then if I backed it off, it was OK (sort of) until I tried to accelerate again. Oh well, I've never had an electronic ignition fail in 40 years, so I'll be happy to throw the points plate in the scrap bin, where it belongs...... ;D
« Reply #1509 on: March 19, 2021, 04:11:41 AM »
Quick fix, change condensors and continue ride until your electronic stuff has arrived.
Offline Trevor from Warragul
« Reply #1510 on: March 19, 2021, 04:16:37 AM »
If you can get a set of good condensors!  Hondaman has posted about modern condensors failing very quickly.  NGK sparkplugs, condensors, what next?
1971 Kawasaki H1A
1972 Honda CB350F
1976 Moto Morini 3 1/2 Sport
1978 Honda CBX
1997 Suzuki Bandit 1200
1999 Ducati Monster 750
« Reply #1511 on: March 19, 2021, 04:21:36 AM »
Yep my point exactly Trevor, why would you bother? Back in the day I could buy a complete Honda points plate assembly from my Honda dealer for 100 bucks, but nowadays they're more expensive than a Kokusan electronic ignition that will last as long as the bike, with no adjustments. The OEM Honda stuff is probably made in China now, so why bother? Throw in an electronic ignition, time it in 2 minutes, and forget about it. ;D
« Reply #1512 on: March 19, 2021, 04:27:06 AM »
Forget what?? ;D ;D
« Reply #1513 on: March 19, 2021, 04:29:16 AM »
Forget what?? ;D ;D
Ha ha, my dad had dementia, and I fear I'm gonna go the same way Per, so I've already forgotten whatever we were talking about........ ;D
« Reply #1514 on: March 19, 2021, 05:11:32 AM »
More fun that way!  See same movie over and over again.
Both my parents got dementia too. 89yo not bad either.
Only the last 3 they were a little bit too lost, not able! ;)
Eat daily sweet potato should help to not get the brain to rotten up/ disappear.
Saw on TV.
« Reply #1515 on: March 19, 2021, 05:14:40 AM »
Saw on TV.
As nice as sweet potato is Per, if I have to eat it every day for the next 28 years, I think I'd rather have dementia......... ;D
« Reply #1516 on: March 19, 2021, 08:18:14 AM »
Saw on TV.
An Apple a day, a sweet potato a day........ Keeps the doctor away...
My mom is 95 and the past 3 years my sisters have been saying she is forgetting more..... Her brother was 99 when he past last year and was showing signs of it too.
Me.... I don't know if my back will last that long...
Oh well. Live as if today is your last day....be it to live or remember.....
No where did I leave my key for my 750......
« Reply #1517 on: March 19, 2021, 08:37:03 AM »
Saw on TV.
How to fix and service a Honda is often discussed.
Here some maintenance tips about us!
https://greatlakesledger.com/2020/03/24/diet-can-limit-the-risks-of-dementia-new-research-showed/
« Reply #1518 on: March 19, 2021, 10:47:21 AM »
Saw on TV.
There's one movie I certainly would not like to see over and over again: Ground Hog Day !  :D
« Reply #1519 on: March 19, 2021, 08:37:29 PM »
You only have to watch around 15 or 20 minutes, then it repeats. .
Offline cbsevenfifty
« Reply #1520 on: March 25, 2021, 12:12:21 AM »
Just watched the K2 bitsa video on YouTube after fitting electronic ignition sounds sweet Terry 👍👍👍
« Reply #1521 on: March 25, 2021, 05:38:08 AM »
Thanks mate, it still needs some minor tuning, but is like night and day now! ;D
« Reply #1522 on: March 25, 2021, 09:59:17 AM »
Yes,"same old,same old"  >:(:like my life with different places I've lived and people I keep meeting:same sorry story-line from them,just different individuals saying it.I wonder if they all go to the same training camps who teach them how to give-up their own good creative imaginations and trade them in for the same old rhetoric.. which never helps anyone.  ::)
« Reply #1523 on: March 26, 2021, 05:27:59 AM »
OK, so it's Friday here in the wonderful land of Oz, which means my thoughts turn to bike riding. The mail delivery man was nice enough to deliver my CB750 oil filters and my NOS NGK D7EA plugs for the bitsa, so as soon as I could climb out of the virtual salt mine, I sneaked outside to install the new (old) plugs.
K2 bitsa Friday 26 Mar 2021 by Terry Prendergast, on Flickr
I bought them on Ebay from a guy selling a heap of different spark plugs that were "Old Shop Stock" that had been sitting on a shelf so long the packets were fading, so I was fairly sure they weren't fake. Of course they could have been really old fakes too, but I think the fake plugs are a fairly new "thing", so here's hoping that these are kosher.
Years ago Hondaman recommended running D7EA's with a 1mm (.040") gap with Dyna ignitions, and I've been doing that with every electronic ignition (regardless of brand) since, with great results. The standard gap was about .5mm (.020") and you can see the difference in this pic. That's a big gap to jump.
K2 bitsa Friday 26 Mar 2021 4 by Terry Prendergast, on Flickr
Years ago I built this "special" plug spanner because the stock one with the 4 holes for a screwdriver blade is a PITA, expecially for the two middle plugs. Only problem is I can't find my 19mm ratchet ring spanner today, so it just wasn't the same using my adjustable wrench. I ended up using my 18mm long reach plug socket and 3/8" ratchet handle on the two middle plugs, which is also a PITA as you need to connect the ratchet handle to the short socket extension after you've put the socket over the plug, then remove the ratchet handle before you can pull the plug. Oh well, life wasn't meant to be easy......
K2 bitsa Friday 26 Mar 2021 2 by Terry Prendergast, on Flickr
Anyhoo, how long can one man talk about installing four spark plugs? I fired it up, and it felt crisper, blipping the throttle with the bike on the centre stand. I climbed back down the virtual saltmine pit for another couple of hours before the desire to ride my bike overcame me, so I slammed down the lid of my laptop, and kitted up. I had to go to the local big box pharmacy to collect a precription for my favourite opiates. The engine feels powerful. It's geared up slightly and has the world's heaviest throttle, so doesn't have the "snap" that the K0 has, but the engine just feels bigger and more powerful all round.
I walked out of the pharmacy and noticed fuel under the bike. Bugger. I'd turned the petcock off, so the float bowl on at least one carb had emptied itself onto the tarmac. Great. It started fine, and even though it felt a little "furry", it accelerated well through the building traffic. When I got on the freeway, it ran like a new bike, tons of grunt, and turbine smooth. I turned off the freeway and stopped at a stop sign, and I could smell fuel. I looked down, and there was fuel dripping on the ground again. Great. I took off, and it missed and farted for a minute or two, then came good again. This went on for the whole 60 mile ride, and I was surprised at how much fuel I'd used when I got home.
I had to switch it off when I got home, then unlock the house, open the gate, then start it again to ride down to the garage. It fired up like a champ and when I blipped the throttle it was perfect. I rode thru the patio, and turned it around in the driveway to back under the carport, and once again, fuel started dripping on the ground and it ran "furry" again. Fcuk my life.
Now to be fair, the carbs are the only thing on this bike I haven't touched in 3.5 years. That wouldn't be a determining factor if the bike was constantly in use, but the sad fact is that this bike has sat for several years with dead engines, so the carbs need to come off, get a thorough cleaning and a rebuild. Not gonna happen, on this bike at least, I've bought a set of K0 carbs from James H because I love the superlight throttle pull on my K0, so I'll park the ol' bitsa until my care package from Britain arrives.
No biggie, I've decided that this bike needs a total makeover, from a laid back 70's cruiser, to a more performance oriented looking K2. The Henry Abes with their fat tyres will go on the "Fake K0 Rat" with the Apes and the stepped seat, complete with sissy bar, and I'll put the Lesters with twin disc front end, lower bars, oil cooler, steering damper, fork brace, better front springs, a stock seat and a few more bits on the K2 to make it more enjoyable to ride at (slightly illegal) speed. I might have to give it a paint job while I'm at it, I'm thinking the factory blue, or even silver perhaps? Should be fun. ;D
K2 bitsa Friday 26 Mar 2021 5 by Terry Prendergast, on Flickr
« Last Edit: March 26, 2021, 05:38:24 AM by Terry in Australia »
« Reply #1524 on: March 26, 2021, 10:52:54 AM »
So, your K2 "#$%*a" is ready for a ride? ;D
Saturday pie ride... mmmm!
