Author Topic: CB550K Cannot adjust tappet on No2 Cylinder  (Read 980 times)
Offline Bristledisk
« on: May 29, 2017, 10:00:04 AM »
I have a 1976 CB550K which I'm starting to restore. It does run but when adjusting the tappets, I have a problem adjust the exhaust valve tappet on No2 cylinder. No matter how much I turn the tappet adjuster screw out, I still can't get any feeler gauge in the gap. All other tappets have been adjusted fine. I'm using the Motion Pro adjuster so it should be pretty straightforward.
Any suggestions for next steps before I consider pulling the engine?
1977 CB400F, 1976 CB750F1, 1974 CB550K, 1975 CB550K, 1976 CB550K2, 1973 CB350F
Offline nicks2319
  • Youngstown, OH
Re: CB550K Cannot adjust tappet on No2 Cylinder
« Reply #1 on: May 29, 2017, 10:46:43 AM »
This is the only tappet that you're having the issue with?
Just wanna make sure you know you have to do 4, turn the engine, then do the other 4.
« Reply #2 on: May 29, 2017, 11:07:10 AM »
Could be a sunken valve..higher up in seat for whatever reason.
Offline BomberMann650
  • Holy Cow! I'm a
  • Dr. Bovinestein iBa#80333
« Reply #3 on: May 29, 2017, 11:42:19 AM »
what position is the crank in?
Offline strynboen
« Reply #4 on: May 29, 2017, 12:38:31 PM »
old 550 and 500 eats the valve shafts..or more korrekt..they veat the bores in the valvecover oval..so the adjusting gets imposibel..you adjust..and after rotate the engine 1 spin..it all are gone..and can not be adjustet...as the bores are get larget and the shafts svim in the big oval bores...
or is the threds #$%*ed up in the adjuster pin
i hate all this v-w.... vords
