Author Topic: Better late than never so here I am with the first of two Honda CB's.  (Read 3106 times)
Offline PorQueNo1970
Ciao folks! I'm a newbie and a putz with flashes of genius who's been told that I'm going through a mid-life crisis after happily taking a disassembled 1978 Honda CB750K for free and beginning the adventure of putting it back together. After some initial tear down and some copious amounts of research I thought that I should get a second two-wheeler to ride and ended up with a 1976 Honda CB550.
I've been getting the CB550 ready to ride while I slowly reassemble the 750. I'll start a new thread for the 76 CB550 rebirth/build but I thought I'd share my eagerness with you.
Here are some photos from the pickup (12/2016) to now....
So far the only thing I've done to the frame is remove the old paint, de-rusted and painted with primer to store away while I build the engine. Nothing has been modified on this yet. Probably not much will happen because the idea is to keep the 750 as a cruiser/tracker, not a cafe racer setup...
The carburetor before I rebuilt it...
After...
Oil pump...
I'm working on (but don't have pics yet) on reassembling the cylinder head. I've already verified that my new bearings for the rods and crankshaft are correct. I've got to do some more media blasting with a cheap portable blaster I picked up at Harbor Freight.
So far it's been a great stress decompression when I find the time to work on it. I'm hoping for wrapped up product in Spring of 2018.
Thanks for all the great info out there!
Welcome! Looks like someone parked that bike in a bayou and left it for dead  :o
Really important that if you are media blasting the head, cylinders and cases, you do an exceptional job of clearing the oil galleys afterwards. Looks like you're off to a great start.
Not only rinse the blasted parts (twice) but blow compressed air through every passage/galley.
Ciao.....subscribed to the bayou build...
Online grcamna2
Welcome to the forum PorQueNo1970
75' CB400F/'bunch o' parts'
Offline Can550
Welcome to the forum. Wealth of knowledge and beauty of sharing it
Thanks for encouragement! It's been a blast so far.
I've got a question that maybe you can help me out with. I've researched, on this forum, having a port & polish on the cylinder head. But after looking into it, I figured it wouldn't be worth it, and the possible loss of performance, so I decided against it. In any case while refurbishing the cylinder head I found what I think are unusual mods to intake side, numbers 1 & 4. Could someone take a look and tell me if this is factory or not?
I'm not the best photographer but you can see, in the lighted area, some polishing. Is that from the factory?
I'm pretty sure this engine has an adjustable cam sprocket as well.
The guy who gave me this bundle of joy (no sarcasm intended) used to be a Honda mechanic in the 70's. They used to have a shop drag bike that they worked on Saturdays and raced on Sunday. I'll ask him tomorrow when we're back at work.
Online grcamna2
Could you take another pic w/o the tape?
I think it has been. Here are some more from the combustion chamber on the intake side as well. I thought you shouldn't do this?
Online grcamna2
Who did the porting work ?
I don't know. I just wanted to verify that it was ported before I ask the guy.
Thanks for verifying that's what I was seeing!
« Reply #10 on: August 02, 2018, 03:33:12 PM »
I’m still at!
Re: Better late than never so here I am with the first of two Honda CB's.
« Reply #11 on: August 02, 2018, 04:30:41 PM »
Those welds are seriously buttered on.  I guess you wanted to make sure there was little room for pinholes.
« Reply #12 on: August 02, 2018, 05:35:38 PM »
The cut marks in your intake ports were done at the factory in their rushed production schedule as a mostly futile attempt at port matching where the intake spigot meets the port...this is the most obvious flow impediment that any head porter needs to clean up.
The cuts in the combustion chamber, however, I do not recognize.
« Reply #13 on: September 13, 2018, 05:17:36 PM »
My mold for the carbon fiber seat pan!
