Metal Devil, at $40 for the blade it is worth EVERY penny.
As some of you know I am in the bike salavage biz and we needed something that would cut FAST. Die grinders (TOOSLOW), Recip saw (TOOSLOW). We tried a recip saw and the blade to frame ratio was 1 to 1.
This cuts through steel frame tube like butter. This bugger will cut faster than a plasma cutter. By the time you have the machine starting to cut the guy with the saw it done. Cuts faster than my guys can keep up with
With two guys working, we can tear down a junker NOW and slice it up in less than 30 minutes grand total! and recover all of the parts! Plus it leaves all of the ends of the tubes smooth, smoother than a grinder can get it.
I tried it this morning and buried it right in a neck gusset and within 10 seconds it was DONE! I have tried several times with the $5 abrasive blades (worthless). They would last about 3 frames as you watch it get as small as a drink coaster. Plus those guys can explode when the tension comes off the frame and the tube goes to pinch it.
This blade is merciless!!!
This will be awsome in a chop saw when we start building our own frames, works just like good tools should. Fast enough to not throw off the creative juices.
