Author Topic: Honda cb350f top speed  (Read 11217 times)
Offline markreimer
Re: Honda cb350f top speed
« Reply #25 on: July 05, 2017, 01:18:19 PM »
I'm no expert on plug colour so I'll leave that to someone else. But 85 mph at 107kg sounds like your motor is running pretty well to me.
Online grcamna2
« Reply #26 on: July 05, 2017, 03:09:41 PM »
I was tucked in today and got 85 mph I weigh about 107 kg
I did a plug chop as well the first one is at full throttle and the second is at idle
Here is the pictures ,what are your opinions
Those plugs look a little oily imo,possibly your piston rings haven't broken-in yet.This is difficult to see/identify by only pics.
Offline Scooterhead
« Reply #27 on: July 06, 2017, 11:12:43 AM »
Is it the right sort of tan?am I heading in the right direction with the mixture screw and main jet
« Reply #28 on: July 06, 2017, 11:33:13 AM »
1/5th turn richer (in) on those air screws
Offline Scooterhead
« Reply #29 on: July 06, 2017, 11:41:20 AM »
Thanks flybox1 I have done that ,it feels a little flat at wot and I can only get about 85 ish mph my speedo is dead accurate at 60 mph
The mains are 80 but as you know exhausts are non baffled 4-4
The plug chop at wot shows slightly tan core ,what colour tan should it be,should I up the mains slightly?
« Last Edit: July 16, 2017, 03:08:26 AM by Scooterhead »
Offline Scooterhead
« Reply #30 on: July 16, 2017, 09:20:00 AM »
Tried 88 mains jets instead of 80 and the result was not better but worse
At wot it stumbled a lot until I backed off,if I added some choke it got really bad
I guess this means it's now to rich but the plug chop at wot only really showed a black like rich spark plug ring slightly confused
I think the claimed 98 mph top speed is out of the question here it must of been a plastic dummy riding it.
Online grcamna2
« Reply #31 on: July 16, 2017, 11:34:58 AM »
Do you run the stock airbox ? I've always liked using the stock airbox along with a high flow Uni foam aftermarket filter element;the stock air box helps the engine w/ the proper power curve.I would think your 80 mains are good.. imo.
Offline Scooterhead
« Reply #32 on: July 16, 2017, 12:19:37 PM »
Yes stock air box and filter,it didn't like the 88 mains at 3/4 to full throttle I think I'll go back to 80 mains
Online carnivorous chicken
« Reply #33 on: July 17, 2017, 04:21:53 PM »
You're not going to get to 98. Depending on your weight, engine compression, etc., I'd say getting to 85 is doing just fine.
« Reply #34 on: July 17, 2017, 04:40:41 PM »
The horsepower gain/weight reduction diet is something everyone oughta try at least once.
I religiously drop 2lbs before every ride
Into the toilet?!
Offline Scooterhead
« Reply #35 on: July 21, 2017, 12:08:30 PM »
Does anyone know what the compression should be  for 350f
« Reply #36 on: July 21, 2017, 03:01:43 PM »
About 170 psi if you use the Honda guage or a small engine tester.  Much lower if you use an automotive or diesel compression tester intended for larger displacement engines.
You might consider a leak down tester instead.  Particularly if you can't obtain a small engine tester.
Offline innovativems
    • Innovative MotoSports
« Reply #37 on: July 21, 2017, 03:09:51 PM »
With your bike are all four cylinders within 10% of each other?
2007 KTM 990 adv
2003 Honda RC51
2000 Yamaha YSR50
1978 Honda Express
1975 Honda CB400f
1974 Honda CB350f
1974 Kawi H2
1974 Honda CB550f
1971 Kawi h1
1973 Kawi h1
1974 gt 550
1974 gt550
Offline Scooterhead
« Reply #38 on: July 22, 2017, 05:21:06 AM »
Yes I have a small
compression tester that I got off eBay
They all measured about 150 psi well within 10% of each other
Re built engine with new piston rings the book says 150-170 psi and it done 600 miles since re build.i was hoping for the 170 psi especially after r build
« Reply #39 on: July 22, 2017, 05:59:48 AM »
I wouldn't worry about that compression.  Do a leak down and check your valves sealing
2007 KTM 990 adv
2003 Honda RC51
2000 Yamaha YSR50
1978 Honda Express
1975 Honda CB400f
1974 Honda CB350f
1974 Kawi H2
1974 Honda CB550f
1971 Kawi h1
1973 Kawi h1
1974 gt 550
1974 gt550
Offline Scooterhead
« Reply #40 on: July 22, 2017, 08:36:20 AM »
I sorry mate but how do you do a leak down test
Offline MoMo
  • Ride like you're invisible
« Reply #41 on: July 22, 2017, 04:06:49 PM »
First you need a leak down test kit.  HF does sell one...Larry
« Reply #42 on: July 24, 2017, 07:45:17 AM »
