Author Topic: Kickstart lever swap out  (Read 3487 times)
AirCanuck
« on: October 30, 2017, 07:53:25 PM »
My CB550k has a 550f pipes and thus a 550f brake arm to fit the piped. This means that the kickstart is kicked it scrapes along the brake arm. If I pull the trigger on a 550f kickstart lever (around $40USD?) will it just be a straight take off/bolt on swap?
Cheers :)
Offline BomberMann650
  • Holy Cow! I'm a
  • Dr. Bovinestein iBa#80333
Re: Kickstart lever swap out
« Reply #1 on: October 30, 2017, 10:26:12 PM »
Yep.  Same splines.
The F kicker has an extra bend about it where it will rest upon k model side covers.
AirCanuck
« Reply #2 on: October 31, 2017, 03:54:01 AM »
Yep.  Same splines.
So it normally rests on side covers? Mine doesn’t have side covers - is that a problem?
  • Holy Cow! I'm a
« Reply #3 on: October 31, 2017, 11:50:47 AM »
The k lever would go almost straight up and hang near the carbs.  Never touching the side covers.
The f lever’s kink moves it over the frame triangle.  With the small f-series covers, they don’t contact.
I only noticed it as an “issue” because I’ve fit k covers to my f bike.
If you have no side covers, it won’t matter.
Online spotty
« Reply #4 on: October 31, 2017, 07:27:46 PM »
I've used one off an RD250LC and an XT or XR , same splines but shorter in length so easier to get your hoof up to the kicking bit. as a bonus it looks a lot less antique then a stock one and its black
i blame Terry
AirCanuck
« Reply #5 on: November 01, 2017, 07:57:30 PM »
Hmm. Which do you most recommend?
Online spotty
« Reply #6 on: November 02, 2017, 03:41:27 PM »
the LC and XT ones are the same so if you can find one go with that, the XR one was slightly longer and straighter from memory
i blame Terry
Offline jonda500
« Reply #7 on: November 05, 2017, 02:57:11 PM »
Cheers :)
sorry to shatter this idea for you, but the 550F kickstart wont work with your 550K foot peg - 550F has a folding foot peg which must be folded up before kickstarting and which has a mounting stud on the frame that is unique to the F frame...
John
A starter clutch thread:
  • Holy Cow! I'm a
« Reply #8 on: November 05, 2017, 03:23:54 PM »
Cheers :)
John
Damnit, jonda is right.  The foot peg even presses against the kickstart hinge.  Totally forgot about that.
AirCanuck
« Reply #9 on: November 07, 2017, 05:12:02 AM »
Cheers :)
John
Drat! Well at least I found out before I pulled the trigger... what now I wonder?
Offline Swoop
« Reply #10 on: November 07, 2017, 05:36:15 AM »
If it doesn’t have to move far, is it feasible to heat up and bend the one that you have?
AirCanuck
« Reply #11 on: November 07, 2017, 02:45:58 PM »
I may be back to that option.
AirCanuck
« Reply #12 on: November 28, 2017, 07:39:08 PM »
What year model do you recommend for this?
AirCanuck
« Reply #13 on: November 28, 2017, 07:47:50 PM »
Doing some eBay checking I may need to tweak you on this at some point. Do you know for a fact that these will fit with 550f pipes and brake arm?
Online spotty
« Reply #14 on: November 29, 2017, 03:20:10 PM »
sorry, my bad, I only know these to fit on 750s, if you were closer i'd send you one to try but freight to and from canadia is both prohibitively expensive and slower than a side valve Harley
i'd bet on it fitting on the shaft but as for clearance with the pipes .....
i blame Terry
Offline FuZZie
« Reply #15 on: November 29, 2017, 04:54:12 PM »
I think i have both the k + f could put them side by side for a pic it would help?
maybe a 500 too if i dig a bit...
AirCanuck
« Reply #16 on: November 30, 2017, 04:55:27 AM »
Problem is as someone pointed out the F needs to have a folding foot peg which only mounts to an F frame so that won’t work. Maybe I’m back to hearing and bending... which a mechanic already tried after I told him not to and now it looks like #$%*
AirCanuck
« Reply #17 on: November 30, 2017, 04:57:28 AM »
Hmm... does anyone know if the 750 and 550 have the same splines and thus the RD250 LC would work? I see one on eBay but it’s about 80 bones so I’d like to be sure...
Offline FuZZie
« Reply #18 on: November 30, 2017, 02:53:06 PM »
You have a pic of what he did?
AirCanuck
« Reply #19 on: December 23, 2017, 12:46:24 PM »
Finally, yes!
https://imgur.com/gallery/3NwJ2
« Reply #20 on: December 23, 2017, 01:09:49 PM »
Cheers :)
John
funny thing is...I can see this stud that Jonda is talking about on your frame now that we have some pictures to work with
AirCanuck
« Reply #21 on: December 23, 2017, 01:34:44 PM »
Cheers :)
John
As in, this may be an F frame?
« Reply #22 on: December 23, 2017, 01:59:41 PM »
Cheers :)
John
I don't know 550's that well, but that little pin that keeps your footpeg from rotating is the same one a 400f peg uses which I am assuming is the same for 550f.
To confuse matters even more the 750f uses that same little peg to prevent the footpeg from rotating.
AirCanuck
« Reply #23 on: December 23, 2017, 02:15:41 PM »
I feel totally at sea about this. I may be back to bending a 550 kickstart in a press...
« Reply #24 on: December 23, 2017, 04:15:34 PM »
real men bumpstart evertime anyway
