Author Topic: Berryman's Carb dip safe for pistons?  (Read 4406 times)
Offline ts354
« on: November 13, 2017, 12:38:52 PM »
My pistons are very heavily carbon deposited on the tops.  Can you dip them in Berryman's carb dip or is it bad for pistons?
Thanks,
Todd
Re: Berryman's Carb dip safe for pistons?
« Reply #1 on: November 13, 2017, 01:06:28 PM »
 I say dip away,stuff is getting pretty weak compared to the old days. Might be some other ways to remove carbon and slag if that is your objective.  Are the rings loose or out yet ?
  A friend of mine recounts a story of when he was a diesel mechanic at a repair shop and a co-worker apparently left some 350 Chevy pistons of some kind of his personnel project on a Friday to soak in a parts cleaner bin over the week-end and when he came back in Monday they were pretty much gone.Apparently that stuff was the real deal they had in there way back then and not alloy friendly.
« Last Edit: November 13, 2017, 01:11:56 PM by ekpent »
Offline BomberMann650
  • Holy Cow! I'm a
  • Dr. Bovinestein iBa#80333
« Reply #2 on: November 13, 2017, 01:16:40 PM »
Yep, absolutely awesome at cleaning carbon out of the ring grooves!
Offline DaveBarbier
« Reply #3 on: November 13, 2017, 03:44:30 PM »
Yeah I agree with the new stuff not being that great compared to what it used to be. If you have a vapor blaster near by that'll clean them up brand new in about 30 seconds.
  • Holy Cow! I'm a
« Reply #4 on: November 13, 2017, 04:56:57 PM »
L
But will they do it for under $30?
Offline Fezzler
« Reply #5 on: November 13, 2017, 11:11:49 PM »
Cheaper and easier to drop them in a pot of antifreeze and boil them. It will completely clean them up and the antifreeze is dirt cheap, widely available, and won't spoil if re-used. And completely non-corrosive to your pistons.
After that your pasta will never taste the same!
1975 Honda CB550f in parts in progress
1978 Honda CB550 Four K4
1971 Honda CB500 Four K0
2008 105th Anniversary Edition HD Road King
(Sold) 1998 Honda Shadow ACE Deluxe VT750
1973 Schwinn Stingray (Blue Deluxe - RIP Jack and Rose)
Offline pjlogue
« Reply #6 on: November 14, 2017, 01:39:02 AM »
Be sure to do this in a well ventilated area!  The Ethylene Glycol in antifreeze is poison (2 tsp) can kill you through kidney failure.  While it is not as volatile as water it still goes into vapor with boiling.  If you ever had a leak from a heater core in your car you can see it condense on the inside of the windshield and appears as a greasy film.
-P.
« Reply #7 on: November 14, 2017, 02:46:09 AM »
I cleaned my pistons and head combustion chambers with pure muscle power. Not that strong but it what I had home.
Offline garyS-NJ
« Reply #8 on: November 14, 2017, 04:40:31 AM »
Actual carbon on the tops is very inert and I would be surprised if any solvent or cleaner works at all.  I think I wire wheeled mine but attacking with thermal expansion might work, say get the piston hot then quench the crown in oil or hit with freeze spray.  Ring grooves I can't remember but I think it was chem dip and a pick.  You can heat the chem deep bath also but don't breath too much of that either..
Sent from my VS987 using Tapatalk
76 harley stroker FL
83 Yamaha XJ550 Maxim
78 CB750F3
Offline Lostboy Steve
« Reply #9 on: November 14, 2017, 05:31:15 AM »
Berryman's works great. I add a bit of time to the recommended amount. Before rinse I give it a bit of a scrub with a nylon brush.
1968 Honda Z50
1977 Honda CB550K
2018 Indian Scout
