Author Topic: B4 putting carbs back on, what should I check?  (Read 1829 times)
Offline juntjoo
« on: November 24, 2017, 06:18:22 AM »
I just want to go down a check list of things that I should check before doing so so whatever happens after I try to start it I can minimize or eliminate the chances I'll have to go back in there. Thanks
-Ben
82 Nighthawk 650..
1982 Honda Nighthawk...
I HAVE A 1982 HONDA NIGHTHAWK FFS! j/k. It's my only bike, my first and last.
Offline evinrude7
  • not a kung-fu
  • something to hüsker
Re: B4 putting carbs back on, what should I check?
« Reply #1 on: November 24, 2017, 06:25:37 AM »
what did you do to the carbs?  thoroughly clean?  set float heights?  set everything to stock spec?
cb750 k6 - ugly
Offline 1976cb750f836
  • 76 cb750f, 836, 78 wheels
« Reply #2 on: November 24, 2017, 06:37:20 AM »
Check rubber intake for cracks.
Throttle return spring.
Throttle cable should be smooth,no snags.
Rubber hoses between carbs.
Bench synk.
Air or fuel screws set to spec.
No trash or debris in air box.
« Reply #3 on: November 24, 2017, 06:47:41 AM »
 A always like to set my carbs upright outside on a bench and hook my slave tank to them and fill them with fueland let them sit for awhile before mounting to check for leaks or other problems. Good time to replace the fuel line also while they are off,much easier now then later someday when they are mounted.
« Reply #4 on: November 24, 2017, 07:43:15 AM »
+1 and while they are on a bench with fuel hooked up might as well go ahead and do the clear tube fuel level check
and +2 for double checking your bench sync
Offline juntjoo
« Reply #5 on: November 24, 2017, 04:29:36 PM »
nothing yet. first thing is replacing the vent tees. waiting on parts.  just getting a list ready. thanks!
-Ben
82 Nighthawk 650..
Offline juntjoo
« Reply #6 on: November 24, 2017, 04:30:28 PM »
thanks
-Ben
82 Nighthawk 650..
Offline juntjoo
« Reply #7 on: November 24, 2017, 04:33:57 PM »
good idea! slave tank? basically something to hold fuel that can drop it down a line into the carbs? would a small can suffice just to test? what do you need, enough fuel to fill the bowls? 5oz +/-?
-Ben
82 Nighthawk 650..
Offline juntjoo
« Reply #8 on: November 24, 2017, 04:35:28 PM »
thanks. what exactly is that test? i think i would like to replace with clear tubes anyway so you can always see whats going on.
-Ben
82 Nighthawk 650..
Offline juntjoo
« Reply #9 on: November 24, 2017, 04:38:34 PM »
Should I do anything with the valves or check compression or timing while it's still out or would none of that be necessary while carbs out? I think not but just checking if there's anything in those checks that's easier with carbs out. also i haven't run this bike at all yet so i don't know the previous conditions pertaining to any of the tests
Also, should I bypass the vacuum pet cock? im in the process of reading up on that and want to fully understand the benefits and drawbacks if any and why was it put in there in the first place if no one wants it?
« Last Edit: November 24, 2017, 04:40:38 PM by juntjoo »
-Ben
82 Nighthawk 650..
« Reply #10 on: November 24, 2017, 07:24:03 PM »
I have an old plastic riding lawnmower gas tank suspended in a frame with a cheap inline on/off petcock installed to regulate the flow of the gas. A splitter also allow me to run two gas lines like a cb750 carb has. You can see it here in this picture.
« Last Edit: November 24, 2017, 07:26:22 PM by ekpent »
« Reply #11 on: November 25, 2017, 04:44:59 AM »
If carbs have been sitting for years, left with fuel in.... They need to be cleaned. Pilot jet and needle jet will be clogged. Maybe the float valve too. I clean mine like this: (ongoing...I have done 2 of 4 so far)
http://forums.sohc4.net/index.php/topic,168243.msg1967262.html#msg1967262
Clogged pilot circuits in the carbs is not fun.
Offline juntjoo
« Reply #12 on: November 26, 2017, 04:13:14 AM »
cool thanks. i just have one line, and well what do you know, i just salvaged parts on my lawn mower i forgot to change the oil on and it imploded so ive got perfect 'slave tank'
-Ben
82 Nighthawk 650..
Offline juntjoo
« Reply #13 on: November 26, 2017, 04:15:56 AM »
I'll check the link thanks. yeah, that's why i took them out. I had just bought it a year ago or so and it had been sitting years and they're all dirty
-Ben
82 Nighthawk 650..
Offline evinrude7
  • not a kung-fu
« Reply #14 on: November 26, 2017, 09:46:15 AM »
juntjoo, if you haven't ran this bike and you are asking about valves and timing you should probably perform the 3000 mile maintenance on the bike.  do you have the shop manual?
cb750 k6 - ugly
Offline juntjoo
« Reply #15 on: November 26, 2017, 03:51:30 PM »
yes I do. thx. I will check that out.
-Ben
82 Nighthawk 650..
