As the title says, this bike is consuming Condensers quite quickly.
The Motor was built about 10,000 miles (1 year) ago and new points and condensers went in then.
All of a sudden the popping and backing started during a 300 mile journey (in the rain) to the point it would just idle but couldn't be driven.
Bright sparks present on both contacts so got the bike trucked home and fitted new points, condensers (Japanese) and plugs (D8EA).
Bike went great again for about 200-300 miles, until the odd spit got progressively worse over say 30 miles at motorway speeds (70-90) and it was running rough again. Pulled in to re-fuel and 2-3 contacts were sparking again. Borrowed a spare condensor off a friends GS750 and it was still sparking at the points.
Pushed on with the journey, and found it would run ok upto about 45-50mph. Got to the destination (60mile on) and now both contacts are lighting up. Since fitted another set of condensers and they are both sparking now.
Any one got any ideas about why I'm going though these things all of a sudden?
Wiring is basic :-
Dedicated 12V feed from Ign switch, though a fuse to the +ve on the coils. (no signs of a short to the frame)
Blue and yellow from Points plate to -ve on coils. (no signs of a short to the frame)
Coils are showing 4.3 ohms on the primary. (1 year / 10,000 mile old)
Caps are NGK and all show about 5 ohms.
