What are your air screws set at?
You have 657b carbs on a K2?
Daiichi points?!? Why?
These bikes can run like a top, if you are methodical in your processes.
Slow down. Ask more questions before guessing....and spending/wasting money.
i'm running 657b carbs, that is right.
My airscrews are set to 1 turn.
I do have pod filters and 4 into 1 exhaust.
I'm running daiichi (japenese, not chinese copy), because my bike fell very hard and the contact points of cylinder 1 - 4 were broke, so had to change them.
To answer the other question, my needle is set at the 4th notch (or 1 notch before the bottom) and needles are stock. Battery is 100% ok, run through all the voltage tests to see if my charging system is correct.
Before falling hardly and changing these points, i had no issue at all with the bike engine dying when braking. I have a small hole at the exhaust level (i can take a picture and show you), this because of the bike fall. Do you think that this can cause a vaccum leak ?
