Poll
CB750 Restoration vs. Racer
02z06dave's 1972 CB750K1 Refurbishment/Restoration
24 (39.3%)
slikwilli420 AHRMA Sportsman 750 Racer
37 (60.7%)
Total Members Voted: 59
Voting closed: June 30, 2018, 10:24:22 AM
Author Topic: Vote for Bike of the Month July 2018  (Read 4678 times)
« on: June 16, 2018, 10:24:22 AM »
http://forums.sohc4.net/index.php/topic,171062.0.html
All that Glitters Is GOLD
http://forums.sohc4.net/index.php/topic,158461.0.html
20180603_145532 by Sean Barney, on Flickr
20180603_145540 by Sean Barney, on Flickr
20180603_145603 by Sean Barney, on Flickr
Offline Johnie
Re: Vote for Bike of the Month July 2018
« Reply #1 on: June 16, 2018, 11:05:00 AM »
WOW look at that...the BEST of both worlds. Nice job fellas!!!
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
« Reply #2 on: June 17, 2018, 03:37:13 AM »
Wow, the stocker is running neck and neck with the race bike, must have a strong motor, hahaha.
And yes guys, Don and myself can see the vote as it unfolds.
Sam. ;)
Offline slikwilli420
  • Master of Disaster
« Reply #3 on: June 18, 2018, 07:02:24 AM »
I know people like a quick write-up of the bike for the voting page, so people don’t have to read all 30-something pages unless they really want to.
This started as a 1977 K model that I acquired the stuck engine, frame, rear wheel and beat to death gas tank for $35 about 10 years ago. I had been moving this thing with me and it mostly just took up space. Fast forward to just over 2 years ago, when I watched my uncle race at Road America and decided to build a bike. I had the frame, and I knew the rest would come as time passed. I had lots of parts on hand and got started. I decided that I wanted something that was dialed in suspension and geometry wise but with stock engine as I learned how to race. I chose Race Tech to help with front/rear suspension and designed custom triple trees to get my trail just right. I picked up a fresh stock engine to run that year.
In the days leading up to the first race in June of 2017, I got the bike running but it wasn’t running quite right. Eventually the engine just quit and locked itself up. Come to find out later that it was a spun rod bearing and it needed some help. Luckily I had the stock engine from my street bike to use, so off came the starter, alternator rotor and such to get some weight out of it for racing/ground clearance. Of course it started right up as I had expected it to, and it was only a day or two before race time.
Another fast forward to October 2017, the season is over and I wanted to go next level on the engine. I worked closely with Ken at Cycle X to have custom pistons developed and make the engine as reliable and powerful as it could be. The work was affirmed this year at Road America where I brought home 3rd place in my class both days!
Here is everything (at least that I can think of) that has been done:
Front end:
Goldwing 37mm forks
Race Tech springs/emulators
Custom damper rods
Removed right side caliper mount
GPS racing dirt track hub/stainless Buchanan spokes, Borrani wheel
20mm hollow axle from Honda CBR
Custom triple trees
Scitsu tachometer
Woodcraft clip on bars
Grimeca 2 piston caliper with Ferodo race pads/12mm Brembo master/cast iron rotor on custom carrier
Engine:
Stage 4 cylinder head by Mike Rieck
CX7 cam/adjustable sprocket/cryo treated HD flat plate cam chain
Custom billet 62mm pistons, 12.5:1 compression
Cylinder bored to match with windage windows cut to match cases
Cycle X pork chop crank
Cycle X rods with ARP bolts
HD Cryo treated flat plate primary chains
Rebuilt primary cush drive
Undercut transmission, ISF processed after
HD cylinder and main studs, HD nuts
Cases had starter box removed to make room for breather
MotoGP Werks stainless 4-1 exhaust, custom flanges/rear hanger
Rear end:
Calfab swing arm
20mm hollow CBR axle
GPS racing quick change hub
Ducati Monster rotor on custom carrier
Vortex 7075 sprocket w/ 520 chain
Buchanan spokes and Borrani wheel
Race tech G3S shocks
Frame:
Detabbed, added bracing above swingarm, between downtubes and spine tubes, between engine mounts in front, where tubes meet above swing arm pivot
Fiberglass tail piece, custom upholstered
Airtech Read Titan tank, custom wrap
Slipstream Cycles rear sets, lightened and angle cut for reduced weight on custom brackets
Custom hand formed oil tank with one-off lines running to Setrab 13 row oil cooler, rubber mounted under headstock
I know that’s a lot to read, but there are tons of one-off touches that even I cannot remember. Ill let pics do the talking now.
Bike as it was for the 2017 season
Bike now:
Everything in between:
Oil tank:
Frame:
Close up of rear end:
Engine with breather system:
Chassis awaiting engine:
Big Bob, Steve Pettinger and me at Gingerman:
Proof a CB can compete in the class:
Fly-by at RA, look for me on the left of the track at 0:09 seconds.
https://photos.app.goo.gl/apt8Cimebazn1Epa6
« Reply #4 on: June 18, 2018, 01:22:41 PM »
Great write-up!
« Reply #5 on: June 18, 2018, 06:05:43 PM »
Sam. ;)
Still close.  Vote, people, VOTE.
Offline greenjeans
  • 1972 CB750K2
« Reply #6 on: June 19, 2018, 05:39:50 AM »
Great bikes gents.   These days, I'm a sucker for race bikes, but I've never had a gold 750 before.  Hmmm....
Offline riverfever
« Reply #7 on: June 26, 2018, 06:40:51 PM »
Congratulations guys! Both of these bikes are incredible.
« Reply #8 on: June 27, 2018, 03:47:55 PM »
Voted.   Tough decision, would love to have BOTH in my garage!
« Reply #9 on: June 28, 2018, 10:11:13 PM »
The vote is TIGHT.  Get your vote in!
Offline bill440cars
  • Feeling More & More,
  • Tryin' To Slow Down "Time"!
« Reply #10 on: June 29, 2018, 10:14:56 AM »
  What a pair, to chose from! Both are Fine Examples that you Have to admire.  Took some thought, but I have cast my vote. Good Luck to both, as they Both are Very Deserving.  ;)
Member # 1969
Offline 02z06dave
« Reply #11 on: June 29, 2018, 01:58:33 PM »
I know im late, but heres a few shots back together with the repaired tank.
Offline piefairy
« Reply #12 on: June 29, 2018, 07:45:18 PM »
They both look great, but I love the lines on the racer... the number plates need to go though  ;D
« Reply #13 on: June 30, 2018, 07:35:41 AM »
You realize it's a real race bike right? ;)
« Reply #14 on: June 30, 2018, 10:57:47 PM »
Congratulations to slikwilli420!!  First race bike in a while to win BOTM!
« Reply #15 on: July 01, 2018, 06:06:56 AM »
Thanks very much to everyone who voted! Thanks to Cal for the nomination!
Offline 02z06dave
« Reply #16 on: July 01, 2018, 10:19:33 AM »
Congratulations! Its well deserved
« Reply #17 on: July 01, 2018, 11:20:00 AM »
Thanks Dave!
Offline riverfever
« Reply #18 on: July 03, 2018, 08:33:38 PM »
Congratulations! This bike looks fun!
