Author Topic: Clear tube float check  (Read 5869 times)
« on: July 13, 2018, 09:35:05 AM »
I know this isn't new but I wanted to update on the status of my K3. After getting it back on the road it ran well but I was not happy with the idle in spite of vacuum gage settings and ignition settings seeming to be right on.
I bit the bullet and did the clear tube check of the floats and they were not correct, some were a bit low. This seems to have had a pretty big effect on idle. Since I set the floats with the clear tube setup, the cold start is easier and the idle is more stable than it has ever been. I guess my clumsy hands just could not get them set right the old fashion way.
Re: Clear tube float check
« Reply #1 on: July 13, 2018, 09:36:39 AM »
Bravo!  ;D
Offline WhyNot2
  • I'm finally an
« Reply #2 on: July 14, 2018, 06:45:19 AM »
kewl............you did it off or on the bike?
« Reply #3 on: July 14, 2018, 07:38:28 AM »
Measure float level by clear tube is the real way doing it right. Float height "should" work if the valves and floats themselves works fine and correct.
The measured level is the total of all factors combined  and the only thing that matters.
This reminds me about my old K6 carbs I cleaned and set for my K2 stock project. I set floats to 26mm, 25mm is probably better. They were like that before I cleaned them after +25 years with gummed up old fuel and adjusted them with almost stock setting. They got new aftermarket float valves (Cruzinimage) that might have stiffer springs than stock and therefore need higher float setting (lower value)
« Reply #4 on: July 14, 2018, 09:47:11 AM »
I did my clear tube check on the bike, air cleaner removed, pretty easy actually.
« Reply #5 on: July 14, 2018, 10:16:21 AM »
Photo of clear tube check
Offline WhyNot2
  • I'm finally an
« Reply #6 on: July 14, 2018, 10:18:20 AM »
Guess I just need to modify one of my bowl screws
« Reply #7 on: July 14, 2018, 10:34:55 AM »
I used an old drain screw. I drilled it from inside to outside and soldered the little copper tube into it.
Offline WhyNot2
  • I'm finally an
« Reply #8 on: July 15, 2018, 05:52:26 AM »
Alrighty man, thanks for the tip.
« Reply #9 on: July 15, 2018, 09:52:20 AM »
The piece of hardwood in the photo above is what I used to hold the jet to drill it. It fit snugly in the hole so the drill would be nice and centered and would go straight through on my drill press.
« Reply #10 on: July 16, 2018, 08:05:19 AM »
you got a carb vacuum sync screw?  those work.
No drilling needed with a PVC fuel line connector either.
« Reply #11 on: July 16, 2018, 08:53:44 AM »
Great idea, I never thought of trying one.
Offline WhyNot2
  • I'm finally an
« Reply #12 on: July 17, 2018, 06:07:03 AM »
Carb Vacuum sync screw????????????
« Reply #13 on: July 17, 2018, 08:24:47 AM »
Yeah....this thing
« Reply #14 on: July 17, 2018, 08:31:24 AM »
I never checked to see if they were the same thread, the short one should work fine.
« Reply #15 on: July 17, 2018, 10:46:24 AM »
I made similar pipes by free copper pipes I threaded in one end.
But bench sync worked really fine too. Most uneven engine run I have seen was caused by ignition, both 1:4 and 2:3 must be correct and both points same dwell checked at higher idle 1200-1400 when warm. This must be correct before synching carbs. I know sine I had to redo the synch after ignition was adjusted.
