Author Topic: Anyone know tappet clearance for A grind Andrews Cam ?  (Read 1243 times)
« on: July 30, 2018, 08:01:59 AM »
 Checking my tappets. Most are at 6 thou  one at 4 thou  one at 5thou.
 Have not been set since install. I am looking for my install sheet right now.
Re: Anyone know tappet clearance for A grind Andrews Cam ?
« Reply #1 on: July 30, 2018, 08:08:38 AM »
Hey Frank...here are the specs of the cam but I dont see valve clearances...
http://satanicmechanic.org/andrewscam.shtml
« Reply #2 on: July 30, 2018, 09:12:58 AM »
I an  going to leave the 5 thou, set the 4 thou to 6 thou for now,  and check the camchain.
« Reply #3 on: July 30, 2018, 03:33:19 PM »
 I have a mild Andrews in a RC 836 and I believe the spec sheet said both the intake and exhaust was .004. If I can find it I will post it,been a long time since I have fiddled with it or saw the paperwork.
« Reply #4 on: July 30, 2018, 03:41:34 PM »
That could be it. Don't worry about it now, I got something below that making noise.
 Either a piston or a rod. Looks like I got some work to do.
Offline johnyvilla
« Reply #5 on: August 01, 2018, 06:46:33 AM »
Are valve clearances determined solely on cam manufacturer guidelines, or are there other considerations?
« Reply #6 on: August 01, 2018, 10:02:56 AM »
They give recommended clearance,  but I don't have that in front of me.
 Some change from that fearing large clearances. Myself , I trust the cam makers know what works and what doesnt.
« Reply #7 on: August 01, 2018, 10:39:28 AM »
.004? They list 500/550/650 but I don't see 750 on the chart? It is listed as "A" however. And ALL the listed cams are .004 intake and exhaust
http://www.andrewsproducts.com/sites/www.andrewsproducts.com/files/assets/Honda750.pdf
That page is linked under "750"
http://www.andrewsproducts.com/motorcycle-parts/instruction-sheets
« Last Edit: August 01, 2018, 10:42:30 AM by Jerry Rxman Griffin aka MuthaF'er »
« Reply #8 on: August 01, 2018, 11:41:16 PM »
The CB750 cams are listed under wrong subject 550/650.
The cam names can not be mistaken!
I would like to try a D cam. Numbers not far from RC295. I wonder how the lobes look like ;)
Maybe Andrews have a pile of forgotten CB750 cams in an old store house?
