Author Topic: The South Side Dive Bar  (Read 3436599 times)
Offline Joel
« Reply #3525 on: March 13, 2008, 10:23:41 PM »
only here because i see i'm almost at 700
not that it means anything :P
Better hurry up, you've still got 15 to go.
Offline neil young
  • striving to be an
« Reply #3526 on: March 13, 2008, 10:37:33 PM »
14 ;D
1972 CB500 k1
1974 CB550
1977 cb 550
2008 Triumph Scrambler
Offline neil young
  • striving to be an
« Reply #3527 on: March 13, 2008, 10:41:59 PM »
not sure i want to use this as a stepping stone to OLD TIMER ::)
1972 CB500 k1
1974 CB550
1977 cb 550
Offline Klark Kent
« Reply #3528 on: March 13, 2008, 10:48:01 PM »
old man, look at my posts.  i;'m a lot like yoooooou.
-KK
-KK
75 CB550k
95 KLR650
www.blindpilotmovie.com
download the shop manual:
you'll feel better.
listen to your spark plugs:
« Reply #3529 on: March 14, 2008, 04:52:19 AM »
Old timer? Pfffft! I was around before the goldrush! ;D
troppo
« Reply #3530 on: March 14, 2008, 05:12:50 AM »
pre eureka?????????
my god, i didnt realise the RAAF had a retirement plan that good ;D ;D ;D ;D
Offline nickjtc
  • I was numero dieci
  • Yamaha XT500 'Gromit'
« Reply #3531 on: March 14, 2008, 05:20:21 AM »
It's hard to believe that it is only 17 months since this thread started, thanks to burmashave.
Nick J. Member #3247
2008 Triumph Tiger 1050
1977 Suzuki GS750
Offline sandcastcb750
« Reply #3532 on: March 14, 2008, 09:51:48 AM »
Should the Shameless thread have term limits?
Washington wouldn't
Grant couldn't
Roosevelt shouldn't
Shameless............
Offline mark
« Reply #3533 on: March 14, 2008, 10:24:42 AM »
what post?
F you mark...... F you.
« Reply #3534 on: March 14, 2008, 10:28:05 AM »
YES!  Although, in keeping with the spirit of the thread, the limits will be minimums.
Madam Chairman  ;D  I propose as follows:
This thread must receive two or more shameless postings, per slacker involved with this undertaking, every twenty-four hours, at least four days per week, or the offending under-poster shall be forced to read this thread from the beginning.  As further punishment, they shall lose all priveleges of viewing the Babe thread for a period of twelve minutes.
All in favor, promptly ignore this post.
Those opposed, same sign.
 :P
Ok I have now posted again. I can be as shameless as any of ya.
Offline neil young
  • striving to be an
« Reply #3535 on: March 14, 2008, 10:31:28 AM »
I didnt say i was opposed to using this to get to 700 ;D
1972 CB500 k1
1974 CB550
1977 cb 550
Offline Roach Carver
« Reply #3536 on: March 14, 2008, 11:17:38 AM »
My spoon is too big!
thats not what I heard  :-[
« Reply #3537 on: March 14, 2008, 11:59:09 AM »
Hey Fire, Speaking of madams........
Apparently, the Brazilian madam in NYC knew Eliot Spitzer a couple of years ago.
She got deported that evening he said he would resign, March 13
Offline 333
  • Time for change
« Reply #3538 on: March 14, 2008, 01:56:37 PM »
I love cats.  I just don't want to eat a whole one myself.
CB350F0  "Scrouching Tiger"
CT70K0    "Sneezing Poodle"
www.alexandriaseaport.org
Offline mystic_1
  • 1970 CB750K
« Reply #3539 on: March 14, 2008, 02:00:25 PM »
“A designer knows he has achieved perfection not when there is nothing left to add, but when there is nothing left to take away.”
- Antoine de Saint-Exupéry
« Last Edit: March 14, 2008, 02:03:48 PM by mystic_1 »
- John Augustus Shedd
Offline mystic_1
  • 1970 CB750K
« Reply #3540 on: March 14, 2008, 02:02:51 PM »
elegant: adj.
[common; from mathematical usage] Combining simplicity, power, and a certain ineffable grace of design.
« Last Edit: March 14, 2008, 02:05:38 PM by mystic_1 »
Offline mystic_1
  • 1970 CB750K
« Reply #3541 on: March 14, 2008, 02:08:56 PM »
hack
    [very common]
    1. n. Originally, a quick job that produces what is needed, but not well.
    2. n. An incredibly good, and perhaps very time-consuming, piece of work that produces exactly what is needed.  "Nice hack!"
    3. vt. To bear emotionally or physically. “I can't hack this heat!”
    4. vt. To work on something (typically a program). In an immediate sense: “What are you doing?” “I'm hacking TECO.” In a general (time-extended) sense: “What do you do around here?” “I hack TECO.” More generally, “I hack foo” is roughly equivalent to “foo is my major interest (or project)”. “I hack solid-state physics.” See Hacking X for Y.
    5. vt. To pull a prank on. See sense 2 and hacker (sense 5).
    6. vi. To interact with a computer in a playful and exploratory rather than goal-directed way. “Whatcha up to?” “Oh, just hacking.”
    7. n. Short for hacker.
    8. See nethack.
Offline mystic_1
  • 1970 CB750K
« Reply #3542 on: March 14, 2008, 02:11:09 PM »
kluge: /klooj/
    [from the German ‘klug’, clever; poss. related to Polish & Russian ‘klucz’ (a key, a hint, a main point)]
    1. n. A Rube Goldberg (or Heath Robinson) device, whether in hardware or software.
    2. n. A clever programming trick intended to solve a particular nasty case in an expedient, if not clear, manner. Often used to repair bugs. Often involves ad-hockery and verges on being a crock.
    3. n. Something that works for the wrong reason.
    4. vt. To insert a kluge into a program. “I've kluged this routine to get around that weird bug, but there's probably a better way.”
    5. n. A feature that is implemented in a rude manner.
Offline mystic_1
  • 1970 CB750K
« Reply #3543 on: March 14, 2008, 02:13:53 PM »
256 (two hundred [and] fifty-six, CCLVI) is the natural number following 255 and preceding 257.
In mathematics, 256 is a composite number, with the factorization 256 = 28, which makes it a power of two.
It is also equal to:
    * 16², the square of 16
    * 44
    * 4↑↑2 using Knuth's up-arrow notation
Two hundred fifty-six is also:
    * The number of characters in the new Braille 8-dot system.
    * The number of different values in one byte, which makes it the typical number of different values in each color channel of a digital color image (see color space encoding).
    * The number of columns in a standard Microsoft Excel worksheet.
    * The year AD 256 and 256 BC.
    * The Split-Screen Level in Pacman
    * The number of counties in Texas.
    * The number of characters in Mikhail Bulgakov's novel The Master and Margarita.
    * An area code in Alabama.
    * The number of regular season football games in the NFL.
    * The frequency of Middle C in hertz under philosophical pitch.
    * The number of the Amarna letter (EA256), which, according to David Rohl, was written by Ishbosheth and contains mentions of King David, Jesse, and Joab.
Offline 333
  • Time for change
« Reply #3544 on: March 14, 2008, 02:55:02 PM »
Dweeb /noun
     37.  To use a dictionary to boost posts in a shameful manner.  Not really shameful as it doesn't take a rocket scientist to cut and paste drivel.  (see also: moron or maroon)
Offline mystic_1
  • 1970 CB750K
« Reply #3545 on: March 14, 2008, 03:07:20 PM »
Dweeb /noun
There's a theme there, if you look.  I think the terms are ones easily transferred from that realm to this one.  Also, we're on page 256 so I thought a hacker-ish theme was appropriate.
Sorry of my drivel annoyed you :)
mystic_1
Offline mystic_1
  • 1970 CB750K
« Reply #3546 on: March 14, 2008, 03:09:55 PM »
Also, from the original post:
# Pointlessness could be encouraged, instead of merely appreciated as is now the case.
# Members could post here without regard to coherence, sobriety or even intelligibility.
I like pie!
mystic_1
Offline 333
  • Time for change
« Reply #3547 on: March 14, 2008, 03:23:11 PM »
But you were coming dangerously close to making a point without something like.....
Shoehorn!!!
Offline neil young
  • striving to be an
« Reply #3548 on: March 14, 2008, 03:35:31 PM »
cant think off anything profound to say at the moment :P
1972 CB500 k1
1974 CB550
1977 cb 550
Offline nickjtc
« Reply #3549 on: March 14, 2008, 03:44:41 PM »
Neither can I.
I took the new headlight shell that will be going on Sophie to the powder coaters the other day.
1977 Suzuki GS750
