Author Topic: Oil filter washer  (Read 1624 times)
Offline casperdog
Oil filter washer
« on: November 20, 2018, 02:01:14 PM »
Hi, need to make a new washer that sits between oil filter and the spring. Mine has gone awol.
Can anyone give me the sizes please...outside diameter, inside diameter, thickness.
Many thanks in advance
Phil
Re: Oil filter washer
« Reply #1 on: November 20, 2018, 02:04:21 PM »
Why make it when they are still available and cheap
« Reply #2 on: November 21, 2018, 10:53:11 AM »
 I don't have the numbers but as long as it fits over the bolt and is only wide enough to seat on the filter rubber it's good. They are thin though, I bought machine bushings at a farm store and honed the inside dia. Later, I bought a bag of 5 from cb750.com or Z1 parts. Most of the bikes that go through here have no washer. If I'm in the shop later I'll get a measurement.
Offline Bankerdanny
  • Endeavor to persevere
« Reply #3 on: November 21, 2018, 11:12:49 AM »
Every time I see the subject of this thread I wonder why someone would want to wash an oil filter when they are so cheap, then I remember what it is actually about.
« Reply #4 on: November 21, 2018, 12:21:49 PM »
 1.15" x .800" x .040" as close as I can get with my recently dropped caliper.
« Reply #5 on: November 21, 2018, 12:26:09 PM »
 I'm always cutting open the steel ones off my race car to check the engine condition and wonder why anyone would use an adapter to put a metal case one on a sohc4. Does anyone else let them drain off and then check inside the folds for debris?
 Has anyone else found the spring and washer on the wrong side of the filter?
« Reply #6 on: November 21, 2018, 12:43:40 PM »
According to the former CEO of Castrol The Netherlands all oil filters are in fact oversized as what differs a new engine from a totally worn one, is not more than maybe a teaspoon of metal.
« Reply #7 on: November 21, 2018, 01:17:15 PM »
i have a small magenet.on the inside of the filter end..to indikate if metal is a problem...i alvays have a small fine Black metal dust/ dirt,hanging  on the magenet..so there is alvays a small bit sirkulating..the best vay to hold the engine klean..is often thange the oil..and not use expensive oil..better thange often..and get the dirt aut..expensive oil is longlife..and that is the effekt you pay ekstra for...but it are krazy on a engine vho only run for few auers betveen oil thange..
Offline Johnie
« Reply #8 on: November 21, 2018, 01:48:32 PM »
Of all the early 750's I have done it is always fun to see if that washer is still in place. All were gone. However, the K1 I currently have on the lift had it in place. I almost fainted straight away.
« Last Edit: November 21, 2018, 01:53:56 PM by Johnie »
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
« Reply #9 on: November 21, 2018, 02:12:03 PM »
Lol Johnie...being the irresponsible, disorganized, never planning a head type guy I am, I have often been negligent about replacing the missing washer on my project bikes.  When I finally got the washer in there, I lost it during the very first oil change.  So, I ordered up a large supply of them.  Now, if only I could remember where I put them.
« Reply #10 on: November 21, 2018, 03:20:41 PM »
 Wear isn't usually my problem, it's the needle bearings that came out of defective rocker arms or a broken lifter and were digested by the billet oil pump. Seeing that in your filter will bring a tear to your wallet.
Offline casperdog
« Reply #11 on: November 22, 2018, 01:13:19 PM »
Many thanks for that Don...
My filter was fitted with the spring on the wrong side when i opened it up..not that i knew at the time because this bike is new to me.
Only realised when i looked up on this site on how to refit...
Cheers
Phil
