Author Topic: Velocity Stacks vs. Pod Filters?  (Read 7495 times)
Offline Xander^
Re: Velocity Stacks vs. Pod Filters?
« Reply #25 on: February 19, 2019, 03:48:57 PM »
i just bought the cognito moto airbox for my 77 cb750k.. on initial start up was pretty sweet. still need a bit of tuning.. but im having a fitment issue on the box/carb itself.. cant get it to sit all the was down on top of the carbs. only one side is fitting all the way.
1977 CB750K cafe
Offline slikwilli420
  • Master of Disaster
« Reply #26 on: February 20, 2019, 07:51:12 AM »
Here is my setup on my race bike.
The stacks are from Weber DCOE 40 side draft carbs, cut down and with 3 small set screws. Never had an issue with the screws coming loose. For extra protection, I have Ram Air filters that fit over the bells and I just keep them slid back. Bike made 80hp at the wheel on 760cc, has nice throttle modulation (lumpy cam in there though) and Im in the setup for under $150.
Silk,
Nice set up. Is this your round top carbs on F2 cylinder head set up?
Or, have I confused you with someone else..?
Have you deleted alternator and flywheel...? Idle speed..?
Motor is a 76' K, but the round tops are stock, so still have idle. The system seems to modulate nicely, and I think any low RPM fault is with the cam more than intake setup. My cam comes alive at 6K, going from pretty good to HOLD THE F*CK ON at 6001 RPM.
Offline sixthwisconsin
« Reply #27 on: February 21, 2019, 07:06:22 PM »
Looks like you are running this as 4 into 2 filters vs 4 into 1 like a breadbox design. Any thoughts as to the difference?
Offline Scott S
« Reply #28 on: February 22, 2019, 04:10:08 AM »
Silk,
 Not quite the same, I know, but this is the set-up the OldSkoolSuzuki guys swear by; stock rubber velocity stacks and RamAir filters. It's what I will be using on my GS550/GSX750 mash up.
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
« Reply #29 on: February 22, 2019, 06:30:20 PM »
I ended up using the TinTop velocity stacks with the Steel Dragon breadbox. The Steel Dragon stacks were fine but really hard to install. It all fits perfectly.
« Reply #30 on: February 23, 2019, 12:13:51 AM »
you got the early carbs aswell,#$%* them pd bastards.
