Author Topic: Venting tappet covers?  (Read 5019 times)
Re: Venting tappet covers?
« Reply #25 on: March 03, 2019, 07:43:07 AM »
Offline slikwilli420
  • Master of Disaster
« Reply #26 on: March 03, 2019, 09:14:55 AM »
Valve for valve cover breather. How will that help?
http://www.yamiya750.com/index.php?main_page=product_info&cPath=246_21_249_49&products_id=3974
Looks like a pcv valve. Can be had for a few dollars at an auto parts store.
Offline Cb750 Racer
« Reply #27 on: March 03, 2019, 05:25:20 PM »
I think the worry with these venting covers is oil flinging off the valve/retainer and not falling back down as it would with the stock caps. This problem is really dependant on which caps you switch and the way the hose is routed off the vented caps. A valve right above the vent would definitely help. But then again when the pressures high enough to open the valve oil will be flinging out regardless. Not really sure where to stand on that debate but I think a fine screen above the vented ca would be the best solution IMO.
Turbo Billet Block cb750
1975 Honda CB400f
1972 Suzuki GT750J
1984 Kawasaki GPZ900 Mr.Turbo Top Gun build
2002 Suzuki Bandit 1200 Turbo
1979 Honda CBX
1990 Mr.Turbo Kawasaki ZX11
And Dozens More...
Offline Bill/BentON Racing
    • BentON Racing
« Reply #28 on: March 04, 2019, 07:55:05 AM »
Yes, clutch cover works well.
BentON Racing Website
BentON Racing Facebook
« Reply #29 on: March 04, 2019, 10:14:49 AM »
I have had years of small oil weep between cases at front due to no knowledge of this simple modification.
Plus more recent problems when testing additional vent via the rear hose to oil tank and even more with an earlier oil tank.... most oil just disappeared, rear end rust protected ;D
That little vent thru clutch cover fixed it alone, even with 71.25mm pistons. 836 on a street bike need this vent too, at least mine. Business for shops selling covers with welded hose connection.
« Reply #30 on: March 04, 2019, 06:30:58 PM »
I have found no need for additional venting on my 836 with a K1 oil tank, with properly routed hoses?
« Reply #31 on: March 05, 2019, 02:56:06 AM »
My 836 got minor oil weeps around cases during holidays thru Germany, Austria and finally Italy. Another year via Germany, France to Spain. All day long on highway in speeds around 100mph or more helped oil to creap out.
Even shorter trips but still higher rpms most of the time ended up in dirty cases. I blamed the Hylomar blue sealer back then and years after.
It became more visual and quicker when bike got billet block with 1005cc 2017. Inspired riding often passing 8000 rpm showed weeps after around 50-100km.
This is completely fixed with the clutch vent and stock K6 oil tank without extra plumbing ;)
