Author Topic: Before I start the bike  (Read 1042 times)
Offline evinrude7
  • not a kung-fu
  • something to hüsker
« on: February 22, 2019, 11:31:50 AM »
This is the first time I've pulled the motor and the cam and then reassembled and reinstalled the motor. I've set the cam timing according to Mark's book. I've set the valve lash and I'll static time the points. Is there anything else I need to do before I start this motor?
The purpose for pulling the motor was to replace pucks.
Sent from my LG-H871 using Tapatalk
cb750 k6 - ugly
Re: Before I start the bike
« Reply #1 on: February 22, 2019, 11:45:55 AM »
1qt Oil up top, and the rest in the oil tank.
Spin the starter without starting the bike 5 sec burst 2-3 times....and then start it.
« Last Edit: February 22, 2019, 11:47:34 AM by flybox1 »
« Reply #2 on: February 22, 2019, 12:19:15 PM »
+1,
I like to do this with no spark plugs, until I see oil pressure...
Offline macvit7906
« Reply #3 on: February 22, 2019, 01:44:46 PM »
+1
you could pull the valve adjuster caps and make sure you're getting oil to the top end before starting as well.
Offline evinrude7
  • not a kung-fu
« Reply #4 on: February 22, 2019, 05:07:37 PM »
thanks for the reminders.
cb750 k6 - ugly
« Reply #5 on: February 22, 2019, 11:52:33 PM »
Electrical starter, no spark plugs.
My last build had some issues to make flow. I had to remove oil pump, drown it in oil again, unscrew the oil pressure valve and keep rotating the sprocket to get air bubbles out. Much thinner oil when priming pump can be easier to get it air free.
« Last Edit: February 23, 2019, 12:01:45 AM by PeWe »
Offline Korven
« Reply #6 on: February 23, 2019, 12:14:46 AM »
If having troubles with oil pressure you can try leaning the bike over while running it on starter to try to get air out.
« Reply #7 on: February 23, 2019, 05:41:39 AM »
  You should be fine since it was not a total rebuild. Have a flashlight handy and peek in the oil tank and look for agitation when it starts. Level will drop some and you will see bubbles/movement etc quickly.  Fingers crossed no leaks for you !
Offline evinrude7
  • not a kung-fu
« Reply #8 on: February 23, 2019, 07:51:23 AM »
i thought about the pump and if i'll have an issue since the motor hasn't been run in a while.  pretty sure i won't but if i have to drop the oil pan no big deal.  yeah eric no leaks will be nice if the new pucks do the job.  the old ones were pretty crispy.
cb750 k6 - ugly
